Old 10-28-2013, 04:03 PM   #85
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by Calum View Post
By all means, guys, ask these questions. But, Innovate hasn't logged in since 2.5 hours after they created this thread, almost 10 days ago. They're not using this forum as a means of 2-way communication. If you do contact them through other means, I'm sure a lot of people would like to see their reply.
We apologize for our perceived lack of availability. While we are very busy with continued development on the supercharger, our electronics product line and preparing for SEMA; feel free to contact us directly via our website, (email or phone) if you have any immediate needs and we will assist you.
Thanks again for your enthusiasm for for the product, as a little teaser we have a few other neat toys in the pipeline for the turbo guys.
mines13 is offline   Reply With Quote
The Following 4 Users Say Thank You to mines13 For This Useful Post:
EAGLE5 (10-28-2013), Sportsguy83 (10-28-2013), whataboutbob (11-20-2013), WolfpackS2k (10-29-2013)
Old 11-19-2013, 01:27 AM   #86
DriftEm
DriftEm's Avatar
Originally Posted by tom@kartboy View Post
K got some weights in this morning. Waiting for the roofing company to finish our complex in the next few days before i can uncover the BRZ
Core is 5.5 pounds
Rad is 4.5
Misc hardware 1.75
Hoses & rez 3.0
SS Mounts 1.0
Pump 0.5
Coolant 75oz 4.0
Total should be right at 20 pounds.
Tom
Hey Tom, have you installed it? how long did it take? did you remove the charger from the intake manifold or removed the whole thing?
DriftEm is offline   Reply With Quote
Old 11-19-2013, 11:35 PM   #87
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've just established I have a leak as CEL PO0171 came up 3 times. Battled to ascertain where the leak was coming from, until I was advised to check the 2 grey L connectors that screw into the rear of the charger.
There seems to be air escaping through the thread of the plastic L piece.
The irritating thing is you can't remove and replace with Teflon tape without removing the entire manifold.
Recommend before installing remove the 2 L connectors apply Teflon and ensure tight before you do installation, as a prevention. The pipes that go on are extremely tight to get on so the locktite from factory comes loose and hence creates a leak.
So far I picked up following issues with hardware
Bosch MAP sensor is terrible with this kit
Pin missing from map harness
Incorrectly wired map harness
Leaking L connectors
I'm a little pissed with what I have gone through with the Spritex kit.
Ryan86 is offline   Reply With Quote
Old 11-20-2013, 12:24 AM   #88
sw20kosh
Drives: 2013 Black FR-S
You can take that intake plenum off without removing anything else. You dont have to remove the blower nor the manifold. I did it to tighten those elbows. You will have to work blind on some of those allen bolts with an allen wrench so it takes patience. I applied Amazing Goop thread sealer to them and tightened them 1 extra turn than they came initially.
The interesting thing is my leak was not those elbows (even though they were clearly loose). The leak was at the rear laminova fluid nipple. The retaining bracket/clip was not bolted in on one side thus tilting that nipple to one side a bit allowing air to enter/escape.
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 11-20-2013, 01:00 AM   #89
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I'm kinda glad my kit hasn't arrived yet.... all these problems you guys are experiencing and posting about is gonna make my install MUCH more thorough.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 11-20-2013, 11:19 AM   #90
Ryan86
Road Warrior
Ryan86's Avatar
Please can you post a pic, so I can verify while I'm repairing
Old 11-20-2013, 11:24 AM   #91
Ryan86
Road Warrior
Ryan86's Avatar
I've had 3 months of hell with this kit, to the degree I wish I never bought it.
Hopefully once I ensure all is tightened with Teflon, it works.
Will certainly lodge a complaint with Sprintex when I'm done, cost me a lot of money try to sort this out.
Old 11-20-2013, 11:34 AM   #92
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Are most ppl with issues doin self installs or very experienced shops installing and still major issues?
lbroskee is offline   Reply With Quote
Old 11-20-2013, 11:54 AM   #93
Ryan86
Road Warrior
Ryan86's Avatar
My entire install has been done by my dealership. The mechanic has stripped a 86 motor before and fitted SC.
Bosch map sensor was first issue, did not pick up CEL car would not idle
Once the stock map sensor fitted CEL indicate MAP faulty, picked up a pin missing from the map harness, removed the harness.
Car started running, installed FA20 tune and Could not get car to run after a week of trying.
Sprintex requested I take the throttle harness and map harness off and verify color wires matched, try nuts the wiring mixed. Replaced harness.
While all the above was happening, I was told my tuner and installer was the issue, I then out to prove it was not I paid for Delicious Tune.
Bill connected up on first log, found issue which we fixed and second log found I have leak.
So in no way have I done this install on my own.
Hardware issues have caused problem after problem.
Hopefully after we reinstall tomorrow I'm finally up and running properly.
The Following User Says Thank You to Ryan86 For This Useful Post:
lbroskee (11-20-2013)
Old 11-20-2013, 12:40 PM   #94
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
It's worth mentioning that Ryan86 has a Sprintex kit, not an Innovate kit, and I assume he is receiving Sprintex support, not Innovate support.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Team STILLEN (11-21-2013)
Old 11-20-2013, 12:41 PM   #95
sw20kosh
Sorry you have run into issues. It is the nature of aftermarket forced induction unfortunately. We are adding non oem complexity to a complex motor + complex ecu. Turbo kits are even more complex!
What exactly did you want a picture of?
Old 11-20-2013, 01:39 PM   #96
Ryan86
Road Warrior
Ryan86's Avatar
That is correct, we get in direct from Sprintex.
However my problems should be noted by you guys as Innovate is supplied by Sprintex??? So I'm merely pointing out to double check these items before installing
As much as I'm pissed, it's part of modifying a car I do realise.
Old 11-20-2013, 01:41 PM   #97
Ryan86
Road Warrior
Ryan86's Avatar
Where you mentioned you picked up a leak?
Old 11-20-2013, 02:33 PM   #98
sw20kosh
See the big nipple for the intercooler coolant? There is a retaining clip that puts pressure on that nipple so it stays put. The retaining clip is secured by two allen bolts. One of mine had backed out and so the retaining clip was not putting even pressure on the nipple.
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 01:49 AM
Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! Xero-Limit Forced Induction 12 03-10-2014 09:56 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 02:06 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 10:14 PM
FS: Innovate Motorsports OT-2 pixel67 Engine, Exhaust, Bolt-Ons 0 01-05-2013 11:13 AM
