Old 11-18-2013, 09:57 PM   #1
DarkCard
Drives: Asphalt Scion Frs 6MT
License plate lights, has anyone ever tried these?
http://www.ebay.com/itm/Direct-Repla...-/130822947850
The led's I have are shot.. I've gone through two sets already and I'm getting fed up so I think I might order these.
Anyone have em? Pictures?
DarkCard is offline   Reply With Quote
Old 11-18-2013, 10:47 PM   #2
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Maybe you should use better quality LED's as I've had the same globes in for 18 months.
These are nice though
Ryan86 is offline   Reply With Quote
Old 11-18-2013, 11:16 PM   #3
DarkCard
I thought they were quality. I wont mention the vendor but this is getting annoying..
What ones do you have?
Old 11-18-2013, 11:23 PM   #4
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
You should mention the vendor. That helps us consumers.
husker741 is offline   Reply With Quote
Old 11-18-2013, 11:50 PM   #5
DarkCard
Dealing with a warranty claim so I'll wait for the turnout.
Reguardless I'm gonna most likely change to a better quality bulb
Old 11-19-2013, 11:51 AM   #6
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
I'd have to look, but usually its cheaper to just get the LED Bulbs that fit those lights. SuperbrightLEDs should have them.
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline   Reply With Quote
Old 11-19-2013, 12:30 PM   #7
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
HID_Powerhouse is the way to go !
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 11-19-2013, 09:12 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
just looking over them, i don't think they should be too bad.. the biggest factor is going to be the actual quality of the led's themselves..
usually the main problem with plug-n-play led bulbs is that they are so small and compact, there isn't enough thermal mass to get heat away from the led's.
that design claims to use 1210 led's, and only uses 8 of them, so there should be enough space to keep the led's relatively cool for extended run times.
but personally, i've learned to despise and pre-made led bulb, so i'm making my own because it's the only way i can be sure that something better than bargain-bin components are being used in it's assembly...
Old 11-19-2013, 10:30 PM   #9
DIM
I bought 10x led bulbs from ebay for under $10. And they held up on my old car for 2+ years and my FR-S for a little 6 months.
DIM is offline   Reply With Quote
FS: LED License Plate lights fourvalleys Exterior Parts (Aero, Lighting, Etc.) 0 11-18-2013 06:44 PM
License plate relocator and redded out tail lights for sale ph0en1xtk Exterior Parts (Aero, Lighting, Etc.) 4 06-12-2013 11:29 AM
License plate lights B-R-Z Cosmetic Modification (Interior/Exterior/Lighting) 4 06-11-2013 09:41 PM
License plate covering front plate effect cooling? Wolfkiller Scion FR-S / Toyota 86 GT86 General Forum 4 05-04-2013 07:19 PM
Intro Pricing on BRZ/FR-S LED License Plate Lights JWMotoring Exterior Parts - The Rest 10 09-25-2012 11:30 PM
