Southern California SoCal
Old 11-17-2013, 10:10 PM   #1
Gen
Drives: Scion FR-S
Local custom exhaust
Anyone have a recommendation on someone local that can fabricate a small piece of the exhaust for me? (San Diego) I had to tilt my radiator back in order for everything to fit on my turbo setup. The downpipe is ever so slightly touching the fan, and it won't last forever like this. I need someone that can fabricate something straighter. It would also be nice to use some larger fans, as the slim fans don't really do the trick in the hotter months.
Gen is offline   Reply With Quote
Old 11-17-2013, 10:28 PM   #2
DAMotorsports
Drives: 2013 Scion FRS "Raven"
What turbo kit are you running
DAMotorsports is offline   Reply With Quote
Old 11-18-2013, 12:49 AM   #3
regnak
Hit the guys up at Performance Tube Bending, solid work from them.
regnak is offline   Reply With Quote
The Following User Says Thank You to regnak For This Useful Post:
Gen (11-18-2013)
Old 11-18-2013, 12:59 AM   #4
Gen
Drives: Scion FR-S
FBM. The pipe has this wonky curve, presumably to give the MAF ample room. Once you start adding things up front, it becomes problematic. It all fits fine with the stock radiator, but that's not really up to the task of a turbo charged car. There's also a 25 row Setrab oil cooler up there, so it's all a tight fit.
Old 11-18-2013, 01:34 AM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I think fullbown should address the issue and it might be an install thing
@FullBlown
Old 11-18-2013, 04:50 AM   #6
Gen
Drives: Scion FR-S
@FullBlown
Definitely not an install issue. Koyo Radiator had to be titled in order to allow everything to fit up front. In the stock configuration it clears. With the stock radiator, or even just the koyo radiator, it works.
Old 11-18-2013, 05:28 PM   #7
DAMotorsports
The bad about tilting your radiator back is it changes the air flow design. You might be better off changing to a one piece unit for cooling both oil and water. Now sure if you have thought about that. You can also move the oil cooler and make a ducting for air flow
The Following User Says Thank You to DAMotorsports For This Useful Post:
Gen (11-18-2013)
Old 11-18-2013, 08:11 PM   #8
Gen
Drives: Scion FR-S
Yes, I actually have the APR ducts for just that reason, but the shop I go to was insistent airflow would not be good enough. The radiator was more shifted back more than titled, but there was some tilt to it. If can get a straighter down pipe, I expect to be able to tilt it back to a more stock configuration.
shop/local installing MXP exhaust catback & front pipe jgonx213 Southern California 7 11-06-2013 02:55 AM
Brand new AFE exhaust for local pick up genometuning Engine, Exhaust, Bolt-Ons 25 09-17-2013 12:22 AM
MD: ARK GRIP EXHAUST $800 (LOCAL) Ric Flair Engine, Exhaust, Bolt-Ons 7 07-28-2013 10:38 PM
