KR-S, MisterSheep, Tcoat
Old 11-16-2013, 01:26 AM   #267
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Originally Posted by Malt View Post
You'll love the increase in the cars performance once you get your tune! Not only will you get more HP that you (and all of us love), but your car will be running safer as well!
Just a quick question on your mods. You listed a throttle body spacer as one of them. Where did you purchase this? I've always heard TB spacers were snake oil but I'd love to look at them again if there is any factual data available on them.
na ive had them on other cars and the spacer makes a difference that you can feel i got it from a shop in ny . a spacer is worth it for the price. easy install and removal for dealer visits. dont forget the sound of the vortex as you hit the throttle! if a bigger tb was cheaper than 1800 bucks id get a big tb instead but thats way 2 much $$$. im trying to find a used stock tb for a decent price then pay ~$80 to get it p&p. but a new tb for the twin is 600 buks so a used one aint 2 cheap.
NYCsubaruBRZ is offline   Reply With Quote
Old 11-16-2013, 02:23 AM   #268
Fast_Freddy
Drives: Passat
Yeah, most people with a TB spacer say that they really feel it. Oddly though, most dyno results show a slight loss of power.
Fast_Freddy is offline   Reply With Quote
Old 11-16-2013, 05:31 AM   #269
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
If your after a * new* bolt-in replacement specifically for our cars, TODA do a cheaper TB than CUSCO. Still pricey though. Should be getting mine next fortnight.. then go for a tune and hopefully crack +50rwhp from stock.
I'll be happy with +40 though. (on BP Ultimate 98)
http://www.toda-racing.co.jp/en/prod...-throttle.html
Edit: Here's a dyno graph from 3 weeks ago
Base "STOCK" 86: ~132 hp
My Modified 86: 168.1 hp
DELTA: ~36.1 hp
STOCK CAR DETAILS:
Toyota 86 GTS(Black) - NON MODIFIED
MY MODIFIED 86 DETAILS:
Intake
- HKS Cold Air Feed(with 3x ducting holes cut out in front bumper)
- TRD USA Intake
Exhaust
- HKS 4-2-1 Equal Length Headers(NO CAT), has O2 Sensor bung to fool computer there is a CAT
- MOTIV Concepts Overpipe
- MOTIVE Concepts Front Pipe(with HFC)
- HKS Spec-L Cat Back Exhaust
MISC Mods
- The DriveShaftShop Carbon Fibre Drive Shaft
Needs to be retuned, added/adding:
- Okada Projects Plasma Direct Coilpack
- HKS Super Fire Spark Plugs Iridium & Platinum NGK10 rating
- CUSCO Earth Grounding Kit
- TODA Big Throttle Body
- Changed to AVO *non oiled* air filter(see below)
- Changed intake to STOCK intake with resonator delete and Reflect-A-Gold heatwrap
(previously used TRD USA air box, but the filter is oiled)
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
NYCsubaruBRZ (11-16-2013)
Old 11-16-2013, 06:13 AM   #270
Turdinator
Señor Member
Turdinator's Avatar
[IMG]
[IMG]
DELTA: ~36.1 hp
STOCK CAR DETAILS:
Intake
- TRD USA Intake
Exhaust
MISC Mods
That is a great before and after dyno for bolt ons. I am interested to see how much the TB changes things. Also curious to see what it will look like after a tune.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
stevo_12v (11-16-2013)
Old 11-16-2013, 06:31 AM   #271
stevo_12v
I have you to thank that for.. I found the link off you LOL
I'm keen to see what a retune will do too, esp with the intake mods. Apparently MAF sensor placement(distance) from TB/Mani makes some difference hence retaining stock intake setup - bar the snorkel of course.
Old 03-30-2014, 12:52 PM   #272
wootwoot
Drives: FRS
NVM...Just found this one:
http://www.ebay.com/itm/KC-TBS-Scion...item2a34c0dc45
The Following User Says Thank You to wootwoot For This Useful Post:
Gilwith1l (03-30-2014)
Old 04-04-2014, 06:29 AM   #273
BRZpower
what is the record whp for a NA twin on 93? NOT E85. I think ive seen somewhere on here 203whp NA 93 octane. anyone care to chime in?
BRZpower is offline   Reply With Quote
Old 04-04-2014, 02:53 PM   #274
wrxgoose
WUB WUB
Drives: 2013 Firestorm
I managed 200.5 with a visconti tune. I think I remember seeing someone got a little higher, but I'm not 100% on that
Sent from my VS840 4G using Tapatalk
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
BRZpower (04-06-2014)
Old 06-10-2014, 03:57 AM   #275
Marco_86
Drives: 14' Frs Raven
Anyone here know this questions answer? As I'm pretty curious myself to know the record.
Marco_86 is offline   Reply With Quote
Old 06-13-2014, 03:27 PM   #276
GhostShield
Drives: 2013 silver FRS
Non of you guys have mentioned Crawford BPB!!?
I'm running a Perrin inlet tube, k&n filter, Perrin cat back and OFT OTS stage 1. Drastically improved over stock feel. Easier to drive and pulls harder.
Waiting on my motiv over pipe, ft86 SF catted UEL header and invidia mid pipe, then I'll flash to OTS stage 2 UEL. Should pick up more power.
Then I want to get Crawford BPBs and I wouldn't doubt if I was at or over 200 on 91 pump gas.
With oft I can easily flash to an e85 tune, only 1 station near me tho :/
GhostShield is offline   Reply With Quote
Old 06-13-2014, 03:55 PM   #277
J_kennington
Drives: 2013 asphalt scion FRS
You only made 132 on stock? Almost every stock dyno I've seen has been in the 150-160 range...
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-13-2014, 04:26 PM   #278
stevo_12v
Not my car. I never bothered to dyno my car 'stock'.
Dyno figures don't really matter to me as ALL dyno's read differently.
It's the HP difference above stock or percentage gain relative to stock that's more important.
Track times are the best measure of performance gain anyways.
Old 06-13-2014, 04:29 PM   #279
stevo_12v
I'll be ordering one of those Crawford blocks sometime next week. Haven't spent any money on my car in over 2 months now :/
I'll get some before and after dyno plots while I'm at it, since my car is fairly modded stock-wise(bar the HKS pistons/cams/rods/stroker) it will be a good indication of how much powa you can get from these 'power blocks' on a stockish motor.
GhostShield (06-13-2014)
Old 06-13-2014, 05:10 PM   #280
GhostShield
Post the dyno runs here, I'm curious to see them myself!
