Drives: AE86, 2x GT86, TE27
Work Meisters BBK clearance
I almost didn't buy Meisters, as when I asked Work NZ to check which disk I needed to clear a couple of bbk options I considered, they said neither o or a disk would fit, and I'd have to go r disk, which aren't available in 5x100.
If you didn't know, the disk types give different bbk clearance, at the sacrifice of dish. O disk gives the least bbk clearance, but the most dish. Off the top of my head, A disk gives 10mm than O disk, and R disk gives 25mm or so more than O disk. Now we don't have a lot of room for crazy offsets, so I didn't want to get custom r disk, or get a disk and run a spacer. Luckily, a friend had S1Rs, in A disk. I borrowed a wheel and took a lot of measurements and believed that Work were on meth, as I had more than 10mm clearance with A disk, with the bbks I was measuring up. I also had a friend come and check my measurements to be 100% sure. Anyway, went back to Work NZ, told them about my findings and asked that they double checked with Work Japan, they came back a few days later saying Work Japan agreed with their findings. I asked to be sent a CAD drawing so I could measure more accurately on my work PC, they refused to supply, citing that they don't want to give that info out. Confident in my own measurements, I ordered O disk. Much to Work NZs disgust at ignoring their advice. Fast forward 3.5 months to today, and I picked my wheels up this morning. First think I did was measure up the BBK I have already ordered, the Wilwood 6 piston. Now I can confidently confirm that Willwood 6 piston fits. Close point being outer radius point of caliper to spoke, about 4mm clearance AP racing Sprint fits. Close point being inner caliper point to spoke. Clearance about 2.5 - 3mm AP racing Endurance might fit. I don't have a template for this kit as it wasn't one I was considering. Seeing as critical point will be inner caliper point to spoke, and it is slightly further from centre compared to the sprint kit, as that combined with the curve of the spoke, I believe it will fit. Wilwood 4 pot front kit (the one that is specified for a wrx) fits with shitloads of clearance. Can upload pics in a few days if needed. To confirm, wheel is 18" S1R Meister and O disk (least clearance/most dish) Wheel is 9inch wide and +35 offset, not that either of these will affect any of te above, as the disk shape for a certain wheel size remains constant irrespective of width / offset. Unsure whether I'll gloat to Work NZ or not. I'll probably wait till they ask me, heh. |
| The Following User Says Thank You to diss7 For This Useful Post: | JEFFSTYLE (01-17-2014) |
#2 |
Drives: 2005 Toyota Camry
I have a feeling all the brakes are for 17" wheels "minimum clearance".
Since you're running 18" wheels, the curvature of the Meister S1 spoke + where the calipers sit make a huge difference. You'll find much different results if you used the 340mm+ rotors (min. 18" wheel clearance) as the guide to measure, I think. -alex |
| WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** | RavSpec | Wheels and Tires | 18 | 12-10-2013 05:19 PM |
| FS: 2013 Scion FR-S - Work Meisters - BC coilovers - Perrin - Whiteline | ebphoto | Cars for Sale/Trade | 22 | 08-09-2013 01:57 PM |
| Wtb: work emotion or meisters s1r | Sandman3zb | Wheels and Tires | 0 | 07-01-2013 11:18 AM |
| Anyone seen Work Meisters? | Sandman3zb | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-04-2012 02:49 PM |
| work meisters 17inch cant find it | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 02-01-2012 10:23 AM |
