Old 09-01-2013, 09:37 PM   #155
whataboutbob
AutoX-10/10ths every run
Originally Posted by Area86 View Post
Awesome build journal Bob!! What tuner did you go with for your supercharger? Delicious tuning??
Sent from my DROID RAZR using Tapatalk 2
Thank you! I am currently running the Innovate basemap. It is the second version that I've received from them. I believe that Bill @ Delicious Tuning provided this map.
Build thread:Here
Old 09-02-2013, 02:40 AM   #156
whataboutbob
A few photos from my last couple events in San Diego. Shot with 194 on door is Jon Lugod driving my car with me riding along.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
M-17 (09-03-2013), normancw (10-16-2013)
Old 10-07-2013, 09:08 PM   #157
whataboutbob
40K Monday
Nice way to start the week. Lots of seat time.
Build thread:Here
Old 10-15-2013, 08:43 PM   #158
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Wow. Lots of seat time for sure.
Makes me a bit jealous. I got 6500 miles after 3 events and 5 months. I thought I was doing good. Now I feel like I'm slacking
The Following User Says Thank You to TylerLieberman For This Useful Post:
whataboutbob (10-19-2013)
Old 10-19-2013, 10:29 PM   #159
whataboutbob
Couple of shots from the AutoX practice today in SD at the Q.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
suaveflooder (10-20-2013)
Old 10-20-2013, 11:03 PM   #160
whataboutbob
2nd place in SM today in SD
Close race in SM today. Managed a 2nd. Best placing so far in SM since the SC upgrade.
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
FRSapex (10-21-2013), suaveflooder (10-20-2013), Turbowned (12-07-2013)
Old 10-21-2013, 01:20 AM   #161
FRSapex
FRSapex's Avatar
Drives: JDM 240Z, FR-S, GTI, Miata ND Club
Sweet result!
I have to say it was great to have met-up with you at practice on Saturday. Your meat-sled is most impressive and I appreciate your sharing your track insight.
FRSapex is offline   Reply With Quote
The Following User Says Thank You to FRSapex For This Useful Post:
whataboutbob (10-21-2013)
Old 10-22-2013, 10:50 PM   #162
whataboutbob
Nice shots here of me sliding backwards across the finish on my 2nd run last weekend.
https://plus.google.com/photos/10568...24895093545041
Build thread:Here
Old 11-02-2013, 12:52 AM   #163
whataboutbob
Will be mounting some Winmax W3 pads on the front and rear of the car next week.
http://www.winmaxusa.com/Articles.asp?ID=251
Build thread:Here
Old 11-02-2013, 12:55 AM   #164
whataboutbob
Oh yeah, passed 43K this week too.
Build thread:Here
Old 11-11-2013, 08:59 PM   #165
whataboutbob
Picked up a couple of used Hoosier A6s in 245/40R17 that I'm going to run on the rear of the car for a few events. Plan on getting a full set of R Comps for next season. Here's some photos of test fits on front and rear of car.
Just for reference, RCE yellow springs on factory struts, RPF1s 17x9et35. The tires aren't clearing the spring perch on the front factory strut. Guess it will be time for some coilovers.
Build thread:Here
Old 11-11-2013, 09:00 PM   #166
whataboutbob
Still more r comp photos.
Build thread:Here
Old 11-14-2013, 10:24 PM   #167
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
-1 3/8 on front, -1.6 and -2.0 on rear. Don't remember which side had what.
Is your front camber as far in as you can take it, or is -1 3/8 what you chose to set it at? If it is as far in as you can take it, is it limited by the camber bolts being maxed out or how close to the spring perch the tire is?
Also, those yellows are supposed to provide the same drop all around, any idea why the rear is lower than the front? Is it something else in the suspension you changed? It also looks a bit lower than most other RCE yellow drops I've seen, but I guess that could be due to a 40 series sidewall vs. the 45. I love the drop though; I didn't think the RCE's were enough until I saw this thread.
Any issues at all with rubbing so far? I'm going to be running a 17x9 et38 with a 235 or 245 PSS, RS3 or ZII, with mainly track use, so I'm hoping not to have any rubbing issues when running the RCE springs.
smbstyle is offline   Reply With Quote
Old 11-15-2013, 01:56 AM   #168
whataboutbob
I'm running the RCE springs, Whiteline camber bolts, and COMCs. Right now I am at -2.75 in the front. I don't think I can get any more neg camber with the parts I have. With this setup and my race wheels I still have a pinky finger's worth of clearance between the lower spring perch and the tire/rim.
I've got 2 12" subs in the trunk with a box. I've also got the Whiteline rear LCAs, and have the lower eyelet of the stock struts on the outermost mounting hole. This causes the rear end to ride a bit lower, not sure exactly how much. My rear is currently set to -2.5 camber.
My DD tires are 225/45R17 Michelin Pilot Super Sports on the factory wheels. My AutoX setup is 17x9ET35 RPF1s on 245/40R17 Z2s. Neither rubs at all on my car.
Build thread:Here
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
Showstoppers Firestorm FR-S Build ShowstoppersUSA FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 10-09-2014 05:26 PM
Firestorm/black project build deedz Member's Car Journals 47 11-19-2012 04:06 PM
Firestorm FR-S Available mattyboy311 Mid-Atlantic 1 09-26-2012 10:36 AM
Firestorm Frs DAFRS88 Southern California 0 08-03-2012 04:11 AM
