Old 11-14-2013, 07:46 PM   #15
FR-S Matt
Grimmspeed gaskets are what I use on my JDL UEL. Very high quality stuff. I highly suggest their gaskets as they are very fair priced too. Snagged mine at FT86 Speedfactory as well. They seem to drain my bank account a lot....
Old 11-14-2013, 07:59 PM   #16
ramiram1984
Drives: 2016 STi DGM
Yesi plan on it. Still stock gaskets considering I went to RW header to HKS header. When my stock manifold bolts on right side came off completly, that gasket was pretty black . Will take the advice and order
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 11-14-2013, 08:33 PM   #17
pche
Guy on internet
Drives: Slowly
I reuse them all the time, they're pretty durable, but only when I'm putting the same manifolds(headers) back on. Replace gaskets and clean cylinder heads surface when replacing with new part.
pche is offline   Reply With Quote
Old 11-14-2013, 09:02 PM   #18
JakeFromStateFarm
JakeFromStateFarm's Avatar
Drives: 2015 WRX
I have reused mine and have no issues so far, How can you tell if there is a leak or not?
JakeFromStateFarm is offline   Reply With Quote
Old 11-14-2013, 09:28 PM   #19
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
With a high quality gasket like ours, I wouldn't worry too much about reusing a gasket as long as you're bolting the same two flanges back together. If you're swapping parts/headers/catback/whatever, the flanges may meet just a bit differently and if your fire ring has already been deformed from a previous setup, you'll be risking an exhaust leak. For me, it's not worth the $20 to have to get back under the car and replace the gaskets later on, but if you don't mind the labor, it's your call!
First of all, awesome username.
I just did a quick google image search, so it's not the best, but what you see below is indicative of the deposits that you'd probably see if you have an exhaust gasket leaking. See the black?
Matt Beenen
Engineering
GrimmSpeed is offline   Reply With Quote
Old 11-14-2013, 09:43 PM   #20
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Exactly why we have the package. It's a no brainier and should be done.
FT-86 SpeedFactory is offline   Reply With Quote
Old 11-14-2013, 10:18 PM   #21
NickFRS
Drives: 2013 Asphalt FRS
I'm about to order some GS from FT86 on payday.... Better to be safe then sorry. Personally Getting under my car is a pain in the ass. So id rather not have to get back under it. Ya feel me? $20 bucks could be spent in many ways.... But id rather be in my bed sleeping for a extra hour or two then under my car at midnight fixing it before work the next day..... Don't even want to post the pics of my reused header gaskets. My gasket that connects the over pipe to the header was crumbling to pieces.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Gaskets & Headers question Bach415 Engine, Exhaust, Transmission 16 06-30-2015 05:27 PM
Gaskets Hawk77FT Engine, Exhaust, Transmission 2 09-27-2013 07:45 PM
fs: Used Borla UEL with free GS gaskets! FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 6 09-18-2013 01:41 PM
HKS Stopper Head Gaskets for FRS and BRZ Hal@Dynosty Engine, Exhaust, Bolt-Ons 7 07-03-2012 07:48 PM
Header gaskets Motordyne Engine, Exhaust, Transmission 1 06-23-2012 04:31 PM
