Drives: I own an FR-S. . . whatelse!
Are new gaskets required with new headers?
Just wondering. Even if it isn't required, is it a good idea to replace the OEM ones?
#2 | |
Drives: '12 Toyota 86 (RED) MT
#3 |
Drives: 2015 WRX
You could always choose to install the thinker Forester turbo gaskets as well. They are so cheap why even risk the chance of having an exhaust leak?
#4 |
Drives: Asphalt FRS
It can depend. I reused my OEM ones when I installed my header, but they ended up leaking after about 6 months. Threw some Grimmspeed ones on there and its perfect now.
#5 |
Drives: 2016 STi DGM
i need to replace mine too.still using stock ones. replaced the bolts and lock nuts tho.
-2014 SSM BRZ MT
#6 |
I'd recommend always replacing header gaskets when taking off the header and always using factory gaskets. We've had some bad luck with aftermarket gaskets.
#7 |
Don't care
Drives: 2013 Whiteout FRS
Is $20 worth 4 hours of your time? Up to you
#8 |
Drives: 85 corolla gts
You already have it off, do it right the first time. New gaskets are cheap.
#9 |
Site Moderator
Drives: ichi 86 Project
Replace it w new ones
No "but", "why" or "someone didn't do it" Just do it |
#10 |
So I am guessing it is a good idea to replace the gaskets.
So new question, which ones should I buy? Grimmspeed made some that are thicker than the stock ones and cheaper, or should I just buy some from Subaru? |
#11 | |
Cheers! Matt Beenen Engineering |
#12 |
GS- do your gaskets really work better than stock? I want to purchase some
-2014 SSM BRZ MT
#13 | |
With that said, the GS gaskets are a bit thicker (more layers of steel gasket) and feature a stainless steel fire ring to create the actual seal. A lot of our customers find that our gaskets solve their exhaust leak issues, but it's difficult to generalize about what caused their issues in the first place, so I won't go making assumptions for you. So, in some situations, the OEM may seal just as well as the GS and in others, you'll find that the additional thickness and different materials in the GS gaskets offer a better seal and better longevity. Either way, at almost double the cost, I personally wouldn't bother with OEM gaskets. Whichever you decide, make sure that you're buying a pair (OEM head to exhaust manifold gaskets are usually sold individually). Of course, if you have any questions or issues, give me a call and I'd be happy to help. Matt Beenen Engineering (612-379-0000) |
#14 |
Drives: 2013 Ultramarine FRS
I just ordered a borla UEL with @GrimmSpeed gaskets from ft86speedfactory. I figured if they are going to make a package deal out of it, maybe its a good thing to replace while i'm down there, better safe then sorry. It'll be on the car on Monday, i'll let you know how well it works out.
| Gaskets & Headers question | Bach415 | Engine, Exhaust, Transmission | 16 | 06-30-2015 05:27 PM |
| Gaskets | Hawk77FT | Engine, Exhaust, Transmission | 2 | 09-27-2013 07:45 PM |
| fs: Used Borla UEL with free GS gaskets! | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 6 | 09-18-2013 01:41 PM |
| HKS Stopper Head Gaskets for FRS and BRZ | Hal@Dynosty | Engine, Exhaust, Bolt-Ons | 7 | 07-03-2012 07:48 PM |
| Header gaskets | Motordyne | Engine, Exhaust, Transmission | 1 | 06-23-2012 04:31 PM |
