CANADA Canada
Old 11-12-2013, 01:45 PM   #15
Ben_G
Drives: Blue BRZ
Originally Posted by Suberman View Post
That happens to every car. Unfortunately there's no fix apart from an ice scraper.
yea...a few minutes after I posted, I realized that it happens to all cars...except that it was never an issue with framed door...duh....
Ben_G is offline   Reply With Quote
Old 11-13-2013, 08:52 AM   #16
acremer
Drives: Scion FR-S
I've been experiencing that problem too. How do I reset the mechanism if the window doesn't go down (because it's frozen?
acremer is offline   Reply With Quote
Old 11-13-2013, 09:12 AM   #17
Ben_G
Drives: Blue BRZ
Unfortunately, resetting requires that the window be unfrozen..........
Old 11-13-2013, 09:33 AM   #18
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Mine finally froze last night, time to disable that POS option once again.
Rayme is offline   Reply With Quote
Old 11-13-2013, 12:36 PM   #19
Captain Stall
OK, here we g...oh, wait
Captain Stall's Avatar
Drives: '13 Hot Lava 6M
Mine have frozen 3 times now in Moncton: twice two weeks ago in the frosty mornings, and again last night.
Captain Stall is offline   Reply With Quote
Old 11-13-2013, 12:41 PM   #20
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
spent all of 2011-2012 winter without a single hickup
last night first time weather dropped into the negatives and it already got "stuck"
gonna clean my window, clean the rubber seals, apply some sort of jelly/protectant and see whats up.
sad panda
Old 11-13-2013, 03:01 PM   #21
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Had it happen two nights ago when the temperature dropped quite a bit from when I started work to when I finished work. A little snow brush action and a little warming up did the trick. As long as you can get the window down, you can reset. With car door closed, lower the window to the bottom and then raise all of the way and hold for 3 seconds - voila - all good.
Demandred7 is offline   Reply With Quote
The Following User Says Thank You to Demandred7 For This Useful Post:
Suberman (11-13-2013)
Old 11-13-2013, 04:36 PM   #22
Suberman
Drives: Subaru BRZ Sport Tech Satin White
sad panda
You don't want anything on your window glass. That will get onto the scraper/seal and then your side window will always be messed up.
Use silicone type spray for rubber seals on the door seals. It soaks into the seal and won't mess up the glass. Be very careful,what you put on your window glass as once ya contaminants get onto the scraper/ seal at the top of each door it is a rpita to get it cleaned off.
Suberman is offline   Reply With Quote
Old 11-13-2013, 09:21 PM   #23
Garstang
Garstang's Avatar
Drives: FRS
Aerospace 303 on the door seals.
Garstang is offline   Reply With Quote
Old 11-14-2013, 04:23 AM   #24
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
easy fix parking the car for the winter dont want any salt on her anyways. playing in the snow could have been fun tho
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 11-14-2013, 01:25 PM   #25
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
You need some spray silicon or tire shine (same thing really). Think of it as putting lip balm on your car. It's cold, so the rubber will dry out and when it's dry and tacky, it will stick to the glass.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 11-14-2013, 01:53 PM   #26
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
would Armor All do the same thing?
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 11-15-2013, 11:14 AM   #27
Suberman
Yes, it's silicone based. Makes things shiny and slippery. I'd use Aerospace 303 if you can find it but Armour- all would work on the door seals.
The Following User Says Thank You to Suberman For This Useful Post:
FLYFISHR (11-15-2013)
Do I go with Windows 7 or 8 R_E_L Off-Topic Lounge [WARNING: NO POLITICS] 27 08-09-2013 04:24 AM
summer or all-season tires? freezing temps? rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 04-07-2013 02:11 PM
Alright to tint windows in winter (cold)? Chinadian CANADA 19 03-21-2013 03:31 PM
Windows freezing? L3P47 Scion FR-S / Toyota 86 GT86 General Forum 11 12-22-2012 01:49 PM
Ice + windows... brzninja BRZ First-Gen (2012+) — General Topics 23 10-09-2012 10:29 PM
