Old 06-18-2012, 03:04 AM   #1
koyv90
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
Ej Swap
So we know this swap is possible but has anyone found any information on how it is actually done?
I.e do you need a swap kit? or engine and tranny enough? can you use the transmission currently in frs/brz with the ej engine? Does it direct bolt on?
I haven't found any information on these with search and such was wondering if anyone else had better luck
koyv90 is offline   Reply With Quote
Old 06-18-2012, 03:25 AM   #2
dabocx
dabocx's Avatar
Drives: Scion FRS
The car has been out for a month
Be patient
dabocx is offline   Reply With Quote
The Following User Says Thank You to dabocx For This Useful Post:
Godzilla35 (06-18-2012)
Old 06-18-2012, 04:40 AM   #3
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
If youre asking these questions you arent serious about it. For the love of holy christ search; and while youre at it tell all your friends to search too.
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
wcbjr (06-18-2012)
Old 06-18-2012, 02:54 PM   #4
vividracing
vividracing's Avatar
Yes it is a drop in sort of deal. A few cars have already been done.
http://www.tune86.com/ft-86-forum/17...o-d1-toyota-86
vividracing is offline   Reply With Quote
Old 11-13-2013, 12:10 PM   #5
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Any real in depth info on this swap?
hmong337 is offline   Reply With Quote
Old 11-13-2013, 12:15 PM   #6
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Search Hibino's 86. There have been a ton of article about this.
hmong337 (11-13-2013)
Old 11-13-2013, 12:35 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I wonder if anyone considering downgrading from an FA20 to an EJ series motor has looked at what each has been capable of doing both in stock form and built form. FA20 seems like leaps a bounds an improvement over the EJ motors design.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
Ammonia (11-13-2013), andrew20195 (11-13-2013), Deadspool (11-13-2013), JustBoostin (11-14-2013)
Old 11-13-2013, 12:39 PM   #8
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
So i was wondering if anyone saw a thread on wooden wheel swaps?
Deadspool is offline   Reply With Quote
The Following 3 Users Say Thank You to Deadspool For This Useful Post:
SirBrass (11-13-2013), Sportsguy83 (11-13-2013), wparsons (11-14-2013)
Old 11-13-2013, 12:51 PM   #9
nalc
Drives: 13 BRZ Limited 6MT GBS
I'm working on it. I had tree saplings overnighted from Japan to me. Just got to plant them, water them, then in a couple years I can cut them down and turn them into authentic JDM wooden wheels.
Then I'll spray all over them with Plasti-Dip.
nalc is offline   Reply With Quote
The Following 5 Users Say Thank You to nalc For This Useful Post:
Ammonia (11-13-2013), Anthonytpt (11-13-2013), Guff (11-13-2013), JustBoostin (11-14-2013), Sportsguy83 (11-13-2013)
Old 11-13-2013, 12:54 PM   #10
Deadspool
Much title. Wow.
Deadspool's Avatar
Sick man.
When you go into production with these, can i choose a stain instead of dip? A nice cherry wood finish gives me the chub.
The Following 2 Users Say Thank You to Deadspool For This Useful Post:
Anthonytpt (11-13-2013), Sportsguy83 (11-13-2013)
Old 11-13-2013, 01:02 PM   #11
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
LOLOL im fckin dying at work reading that
Ammonia is offline   Reply With Quote
Old 11-13-2013, 01:44 PM   #12
hmong337
Emperor JDM
hmong337's Avatar
It's the abundance of parts and aftermarket support that makes me curious about the ej20 swap.
I can get a jdm ej205 engine for cheap all day. They're everywhere these days. A swap for this motor and I'm already pushing what others are getting with their expensive turbo kits on the FA20.
Now, I'm far from knocking the FA20 motor. But the high compression turns me off with any sort of forced induction. Whereas the EJ205 was built from factory to handle boost. That's a HUGE advantage!
The center of gravity and such will be closely retained; unlike a 2jz or lsx swap. The EJ motors, although old tech, are still very potent.
In the end, power is power is power. Doesn't matter what lies under your hood. It's how it gets there. HOWEVER, the major underlying factor for this swap is trying to not upset the car's delicate balance.
EJ motors can handle like 350whp at medium boost on pumpgas all day and do it for years. Try that with your FA!
Old 11-13-2013, 01:49 PM   #13
Deadspool
Much title. Wow.
Deadspool's Avatar
You need to read more.
More compression means we need less boost to make power. Did you know that a turbocharger increases the CR of an engine under load?
This isnt the fucking 1970's anymore. We have this thing called technology.
JustBoostin (11-14-2013), SirBrass (11-13-2013), Sportsguy83 (11-13-2013)
Old 11-13-2013, 01:52 PM   #14
Sportsguy83
Drives: Limited BRZ
EJ motors can handle like 350whp at medium boost on pumpgas all day. Try that with your FA!
Well, it all depends. Obviously there are things to be liked about the EJ motors. It also depends what is your expectations from it. An EJ motor can achieve 350 whp on "medium" boost (read about 20 psi), but the combination of cams and turbo it has has it falling off the face of the earth after hitting a peak torque at 4-5K RPMS.
FA20 motor can make from 300-350 on pump gas at around 12 psi and not fall off at higher RPM's. Powerband between both motors are quite different so I can see if you like that instant hit of torque how you would prefer an EJ motor. They have also proven to not be too reliable aside from adding a downpipe, intake and tune (on stock form). By contrast, slap a turbo kit on the FA20, put E85 on it and you see 400 + whp. This motor is still new and we don't know how it will hold up long term, but so far it seems to be doing ok considering it starts at 170 whp.
Lastly, the 12.5:1 compression ratio is the secret of this car. The CR coupled with the Direct Injection allows it to have a room to play that has not been seen much. Everyone's jaw drops when they hear you say "12.5 CR motor holding 20 psi of boost". It sounds crazy, but it is happening.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
2JZ swap? jordydiaz Engine Swaps 44 05-21-2015 10:19 PM
2UR-GSE Swap czar07 Engine Swaps 9 08-29-2012 01:43 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
Trunk Swap? Coconut Cosmetic Modification (Interior/Exterior/Lighting) 1 04-25-2012 09:47 PM
swap brz front end with fr-s? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 17 02-07-2012 03:23 AM
