Old 11-13-2013, 07:31 AM   #1
CaptainSlow
CaptainSlow's Avatar
E85 issues with injectors?
I was thinking seriously of going with the ECUTek tune (+ and E85 tune) next summer, but before I drop that kind of money I was wondering if anyone has had any issues with E85 clogging the fuel injectors? A couple of my friends are running E85 in their Evos (highly built, so it might not be a good comparison), but they are constantly cleaning their injectors because they are getting clogged so frequently.
Thanks for any insight...wasn't sure if this was an issue or not, since the car isn't exactly built to run E85 from the start.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
Skidrcn (04-23-2015)
Old 11-13-2013, 09:03 AM   #2
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I've been running E85 in mine off and on for around 6 months, with no problems related to the fuel system stock parts. Not a lot of time, but that's been my experience. As far as the experience of the fuel itself - it's awesome. I'm back on 93 for the winter and I miss the extra little bit you get!
(Flex Fuel kits.... yeah I have some stories there... if you go that route - just pay attention to the kit you buy, save yourself the headaches and potential puddle of fuel under the car! )
mikalem is offline   Reply With Quote
Old 11-13-2013, 11:43 AM   #3
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
20k+ miles on E85 with some autox mixed in. No issues.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following 3 Users Say Thank You to Hawaiian For This Useful Post:
Choob (01-15-2015), Sportsguy83 (11-13-2013), TheMedakaBox (05-11-2016)
Old 11-13-2013, 12:02 PM   #4
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
This is the stuff I love to hear. Flex Fuel with maybe 8k miles still working just fine. Except that cold start.
post_break is offline   Reply With Quote
Old 11-13-2013, 11:16 PM   #5
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
This is the guy that got me hooked on the corn juice. 12k+ so far and enjoying every minute of it. Also, the car gets driven the way it's meant to be, so no granny shifting here
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following 2 Users Say Thank You to SportInjected For This Useful Post:
Old 11-13-2013, 11:29 PM   #6
coyote
coyote's Avatar
Drives: Slowly
Ethanol is an amazing solvent. If your friends are getting clogged injectors it's probably because the ethanol has dislodged pre-existing deposits.
coyote is offline   Reply With Quote
The Following 6 Users Say Thank You to coyote For This Useful Post:
Choob (01-15-2015), Frishkorn (09-04-2015), KSpider (11-14-2013), SportInjected (11-13-2013), Sportsguy83 (08-17-2015), zoth (08-05-2014)
Old 11-14-2013, 07:10 AM   #7
CaptainSlow
So, on a related topic, is this upgrade worth the money? I'm looking at the cost of headers, and of course, the cost of the big jump to FI, and it seems like the $950 cost for the whole setup (that is what I was quoted by FA20club for 30whp is a pretty decent ROI, but I just want to be sure before I really commit to it.
Old 11-14-2013, 04:33 PM   #8
cuddefred
Drives: Black 86 GT
Yes!
cuddefred is offline   Reply With Quote
Old 11-14-2013, 07:40 PM   #9
arghx7
Drives: car
How often do you put in E10? Every other tank? Once a month? One time since you initially switched to E85? Or have you literally run only E85 that entire time?
The reason why I ask is because Saab did some pioneering work on turbo [PFI] E85 applications back in the late 2000s. One of the things they found was that running E85 leaves deposits on the injectors, but occasionally switching to gasoline cleans them up very quickly.
Funny you mention that. If you read the Saab paper, they talk about how the deposits were not actually caused by the ethanol portion of E85. They were caused by additives in the gasoline portion. It's weird. Because of the way the fuel supply chain works they could never mix a blend of E85 that didn't have this propensity to cause buildup.
See attached paper, starting on page 29.
File Type: pdf GM flexfuel Ecotec 2.0 engine paper.pdf (1,015.9 KB, 4635 views)
The Following 6 Users Say Thank You to arghx7 For This Useful Post:
B L U E S L A T E (11-19-2013), clayrush (08-19-2015), Cross (09-04-2015), Fast_Freddy (11-15-2013), KSpider (11-19-2013), Sportsguy83 (11-14-2013)
Old 11-14-2013, 11:17 PM   #10
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Was kinda blown away and don't know if I should believe this. See for yourself!
[ame]http://youtu.be/HuOs1yap8mU[/ame]
texasbound972 is offline   Reply With Quote
The Following User Says Thank You to texasbound972 For This Useful Post:
smg1138 (05-06-2016)
Old 11-15-2013, 12:02 AM   #11
Hawaiian
That guy
Hawaiian's Avatar
I heard sonething similar so I will run a tank of 93 roughly every 5 tanks of 85.
I will be going to FI in the spring and with it I will upgrade my injectors. I'll post photos of my old injectors and plugs when I do.
Ultramarine mt FR-S
P&L stage 1 turbo
The Following 2 Users Say Thank You to Hawaiian For This Useful Post:
Boofneenee (06-17-2014), CxG (10-30-2015)
Old 11-15-2013, 01:50 AM   #12
1086
1086's Avatar
Drives: UM86 - 6MT
I am in California so we have 91 (any higher is difficult to come across) and I have nine E85 stations near me. Can anyone go to an E85 pump and put it in their stock FRS as long as their gas tank is near empty? Or do you have to get the flex fuel conversion kit? Or tune to make it work correctly?
Also, can someone please tell me - what parts (if any) would I need to make E85 work on my stock car?
1086 is offline   Reply With Quote
Old 11-15-2013, 01:55 AM   #13
Hawaiian
That guy
Hawaiian's Avatar
Without a tune to run E85 your car will run lean and you can damage the engine.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 11-15-2013, 02:05 AM   #14
1086
1086's Avatar
Drives: UM86 - 6MT
So at the minimum, a tune is a must for E85 to work properly/safely?
DIY Request- Port Injectors whitefrs DIY (Do-It-Yourself) Guides 37 08-22-2019 11:20 PM
Injectors installation kaybee123 Forced Induction 27 03-08-2016 09:26 PM
injectors and tuning? love 4 boost Software Tuning 8 11-09-2013 07:56 AM
Deatschwerks BRZ/FR-S Fuel Injectors! RallySport Direct Engine, Exhaust, Bolt-Ons 2 09-07-2012 06:29 PM
