Old 11-11-2013, 07:43 PM   #323
DoctorNick
DoctorNick's Avatar
Drives: '13 BRZ
About how much machining needs to be done to get the flanges to be flat. 1-2mm? Is this something I should expect to do when I buy the kit?
DoctorNick is offline   Reply With Quote
Old 11-11-2013, 07:50 PM   #324
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Originally Posted by nataku View Post
Let me know how you go about fixing the leak. I think I might still have the slightest leak but at this point I'm not doing anything but machining it if it doesn't go away.
It's very minor now, I think a new set of gaskets will do it.
h4nh is offline   Reply With Quote
Old 11-11-2013, 07:51 PM   #325
h4nh
h4nh's Avatar
I don't think they're all that severe. Should be just the gasket. Instructions didn't say to replace them so we are all learning that that should be a simple fix.
Old 11-11-2013, 09:43 PM   #326
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Its whatever it takes to make them flat. Nothing incredible, but might be more than 2 mm.
Hopefully thats it, but most everyone has had to remove the manifold machine it and reinstall.
Old 11-11-2013, 09:52 PM   #327
ZionsWrath
Thanks
ZionsWrath's Avatar
What type of shop would be able to check and machine if necessary? Does tuner shop have this capability?
Old 11-11-2013, 10:10 PM   #328
Sportsguy83
Drives: Limited BRZ
Any shop that has the tools to resurface (i.e. rotors) can do it. I payed $80 to have mine resurfaced (this only for the resurface, on top of shop time to remove-reinstall the manifold). Close attention needs to be paid as there are shops that might do it wrong and resurface them at an angle, essentially removing material and fixing nothing.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ZionsWrath (11-11-2013)
Old 11-12-2013, 05:07 PM   #329
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by Draco_PR23 View Post
The first one is the upgraded PCV valve and the second will replace the factory PCV in the block. I just had a look at it and I see some very small threads at the beginning, I think you kinda see it in the pic.
Thanks!
Yeah....thats pretty much exactly how mine looked. Alost no thread at the beginning. This will not work, you probably got the same one as me from a batch of bad castings/threadings. Contact Paul and have him send you a new one. The correct one should look just like any other threaded bolt, and the threads should be thicker through-out.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Draco_PR23 (11-12-2013)
Old 11-12-2013, 08:25 PM   #330
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Thanks!
i see i see. I only was offered the first pcv choice when i bought mine, so power to you for getting a block fitting. I eliminated mine, due to it leaking boost, and causing my oil reservoir to puke at times. I'd suggest as seen above, requesting a new one, and in the mean time venting it.
killerkid08 is offline   Reply With Quote
The Following User Says Thank You to killerkid08 For This Useful Post:
Old 11-15-2013, 01:32 AM   #331
h4nh
h4nh's Avatar
Issues with AVO kit
My kit was running great for two days then all the sudden it was at zero boost. Felt like it was back at stock. It wasn't a boost leak.
Found the problem to be the cotter pin that holds the acuator lever on was too small. It probably fell off or broke off.
Drilled the hole with a bigger drill bit.
Installed a bigger cotter pin. Hopefully it should hold up better now.
Second issue was it was leaking oil behind the oil pump where the camshaft is. RTV sealant was used as directed in the instructions but it didn't hold up well.
Pump removed with old sealant.
All the pieces cleaned up and old sealant removed.
New sealant to be used. This is what toyota uses from the factory. It sets in about 15 minutes so you don't have to wait 24hrs before it can be driven.
The block side was cleaned off and new sealant applied.
Final assembly.
Done for now.
Got these Forester turbo gaskets that will be installed soon. There's a minor leak but not that noticeable now.
Hope this helps in case you guys run into issues. The car feels good now.. dyno tune next week!
The Following 5 Users Say Thank You to h4nh For This Useful Post:
andrewFT86 (11-15-2013), Draco_PR23 (11-15-2013), nataku (11-15-2013), Pitman (11-15-2013), ZionsWrath (11-15-2013)
Old 11-15-2013, 01:48 AM   #332
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Thanks for keeping us posted. I've been using grimmspeed gaskets with rtv copper sealant with success so far for the exhaust leak. As for oil leaks from the pump / motor connection I've noticed the same but it hasn't been nearly as serious for me. I'll keep an eye on it though.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 11-15-2013, 02:29 AM   #333
DAMotorsports
Drives: 2013 Scion FRS "Raven"
We have found that on any import motor you should only use the gray sealant or the factor sealant. Which in most cases are the same thing in different packaging. I'm glad you got the problem fix.
DAMotorsports is offline   Reply With Quote
Old 11-16-2013, 02:00 AM   #334
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
I usually use Toyota's FIPG or Permetex BLACK when I'm out. No issues with either, but I certainly use ALOT more than what's pictured so I don't have to do it a second time, like I did with the original AVO car.
Not sure what happened to your cotter pin though...
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 11-16-2013, 02:03 AM   #335
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Sure lots of having to fix this and that posts in reference to this kit lately? Are these concerns being addressed or parts and sections revised??
The Following User Says Thank You to OICU812 For This Useful Post:
Sportsguy83 (11-16-2013)
Old 11-16-2013, 07:46 AM   #336
killerkid08
Cool Stuff
Drives: Cool Car
Final assembly.
Done for now.
Had the same issue with my actuator rod but I bought a assorted pack of pins and just got one that fit better. Nice fix though.
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
