Old 11-11-2013, 12:26 PM   #85
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by bakerr6 View Post
Yea looking forward to it. How much ahve you spent on teh ESC so far? I know they are talking about a kit being available soon. PM me if you'd like.
I'm not really interested in the product as I plan on going turbo, but I would like to make a reference for cost/performance for future people I talk to.
I only spent the cost of the kit + batteries (estimated cost will be around $1600-1700 including batteries thus far.) Though I did install a nexus 7 as my headunit recently and I'm running torque to get data from the odb2 port.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
bakerr6 (11-11-2013)
Old 11-11-2013, 12:35 PM   #86
Cross
It's the Mad Cow
Cross's Avatar
I have been trying to keep up with your install it made me decide to revisit my Eaton Clutch Supercharger days from years ago with V6 Mazda's. (They are found on the C230 Kompressor from around 2003) I bought one and will be running that on my FR-S. I think meeting up some day at a mutual meet would be fun to see the results.
Glad to hear your getting ready to have the project finished up!
Old 11-11-2013, 12:47 PM   #87
Sojhinn
Sojhinn's Avatar
That's cool! Let me know when we can meet up.
Installed Mods:
Cross (11-11-2013)
Old 11-12-2013, 02:53 PM   #88
jeebus
What duty cycle are the injectors sitting at with the e85 tune?
jeebus is offline   Reply With Quote
Old 11-12-2013, 06:35 PM   #89
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
To be honest, I didn't even calculate this. But it was no where close to being at the static limit.
Shiv@Openflash is offline   Reply With Quote
Old 11-12-2013, 07:11 PM   #90
bakerr6
Drives: 2013 raven black fr-s
Nvm, covered in otehr thread, thanks!
bakerr6 is offline   Reply With Quote
Old 11-17-2013, 10:23 PM   #91
Malt
Drives: 2015 WRX
Would be interesting to go back to the dyno with a cat-delete, over-pipe and cat-back installed. I ran this configuration for a month but it was too loud for my 40yr old ears. But I think the car might be able to make 210whp fully modded on E85. But that remains to be seen.
Shiv, have you had a chance to dyno any cars with this tune and a full 3" exhaust to see what gains there were over just a header and filter?
Also, its been almost 2 weeks since you announced the E85 maps, any idea on when they will be released to the general public?
Malt is offline   Reply With Quote
The Following 2 Users Say Thank You to Malt For This Useful Post:
Cross (11-17-2013), merino_frs (11-18-2013)
Old 11-18-2013, 01:00 AM   #92
Shiv@Openflash
Drives: 2013 FRS
I haven't done any controlled tested that would tell me how much extra hp an full exhaust would give over just a header. I'd guess around 10hp but I don't know for sure since we removed the midpipe, cat delete and catback the same time we converted over to running E85.
The E85 map is done and testing in a few local cars. I've just decided to hold out on releasing it publicly until we get advance multiplier added to the list of datalogging channels. That should be this week. Hopefully early this week.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Malt (11-18-2013)
Old 11-18-2013, 06:43 AM   #93
RacerDrews
Drives: 2013 WR blue BRZ
Hey Shiv, are we going to see a stg 1 as well as stg 2 E85 tune so those of us without a catless header yet are able to run it or are you going to simply tweak the tune via the 195 remote tune package for those not running a header as of yet or those of us out there that have a header option that has a high flow cat incorporated into the design?
RacerDrews is offline   Reply With Quote
The Following User Says Thank You to RacerDrews For This Useful Post:
Cross (11-18-2013)
Old 11-18-2013, 08:54 AM   #94
Malt
Drives: 2015 WRX
Wow, looks like so many people are eagerly anticipating the release of the E85 maps that it killed your website. Looks like you ran out of bandwidth Shiv
http://www.vishnutuning.com/
Old 11-18-2013, 12:12 PM   #95
sirsol66
Drives: 2013 FRS- Hot Lava
Two questions (and I'm sorry if these have been answered):
1) How does the transition from gas to E85 go? Should you just let your tank get very low, fill up the car with E85 and flash it? I assume the car is not tuned to the ragged edge of performance on E85...but how much mixture is too much mixture?
2) How does this work with changing ethanol content, such as E70 or whatever it happens to be in the colder states? I only plan on running this in the spring/summer/fall anyways, but I'm curious.
sirsol66 is offline   Reply With Quote
Old 11-18-2013, 01:45 PM   #96
Shiv@Openflash
Drives: 2013 FRS
If you run your gasoline down to E (so at least the low fuel light comes on) and then fill up with E85, you will be golden. Over the next few days I'm going to test how sensitive/tolerant the tune is to e85/gasoline mixes. I suspect it will be happy with running a few gallons of gasoline in there because straight E86 is overkill as far as octane/cooling go. I will report my findings.
Shiv
Old 11-18-2013, 01:59 PM   #97
CajunFRS
Drives: Challenger R/T, CRX SI,
Shiv
With a flex fuel kit from fa20 club will the OFT ever support Flex Fuel?
CajunFRS is offline   Reply With Quote
Old 11-18-2013, 02:05 PM   #98
Shiv@Openflash
Drives: 2013 FRS
To support true flex fuel (reading and adjusting mapping based upon flexfuel sensor input) requires some custom code to be written. Something that I have no had time to look into. Ideally, I'd like to develop a map that allows anywhere from E40 to E85 and automatically adapts without the need for any additional sensors/hardware. This would give most people enough flexibility to mix fuel for the most part. Only needing to return to the standard gasoline map when ethanol content gets really low. This is one of the things on my to do list this and next week.
Shiv
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
bakerr6 (11-18-2013), CajunFRS (11-18-2013), Cross (11-18-2013), DAEMANO (11-26-2013), Luckrider (11-18-2013)
Have you hit 200whp NA? empower-auto Engine, Exhaust, Transmission 323 11-26-2015 07:49 PM
2013 for $1200 off msrp AllStar0419 Scion FR-S / Toyota 86 GT86 General Forum 21 08-26-2013 05:00 PM
Dyno take 2, 200whp on 92Octane ?! AJ PwR Engine, Exhaust, Transmission 76 07-31-2013 02:14 AM
Bespoke upgrade = $1200? madpcsupreme Electronics | Audio | NAV | Infotainment 4 06-13-2013 10:19 AM
