| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
I got BFG Rivals, 245/40/17 on 17x9 +45 RPF1. Used for Auto X once by me and was very sticky. DD'd for few hundred miles and was extremely happy with the grip and comfort.
I'm also on Coils. |
#16 | |
Drives: 2013 Scion FR-S Firestorm
Oh, and they do wear fast, as would be expected. I got I think about 8000 miles out of mine (not completely gone, but just to the wear bars), with about a dozen or so auto-x events (and since my local regions tend to be very efficient, we probably get about twice as many runs at one of our events as most locals - on about a 45 second course). |
#17 |
Drives: 2013 swp brz
while we're on this topic can anyone verify if the v12's run wide? Wondering because I have 245/40r17 coming for my 17x9.5 wheels and don't really want anything more than a very slight stretch. I've seen quite a few 245 wide setups on 9.5 wide wheels and they don't look as stretched as some other 245's ive seen. For reference, this is 245/40 on 18x9.5 wheels:
#18 |
Drives: 2013 WRB BRZ
Surprised no one mentioned the Bridgestone RE-11A.
- Unidirectional - great dry/wet traction - good noise levels - extreme summer tire and cheaper than PSS - wears well after a weekend track HPDE at TWS and I daily drive these - I run -1.6 to -1.7 degress camber all around - got them at $164 each at Costco - I run on 17x9 +35 RPF1 square setup
#19 |
Country Boy 4 Life
Michilen pilot sports are awesome! I bought some 245/40/17s yesterday. They look soooooo much better than my 225/45/17 pilot sport A/S!
245/40/17 on 7.5 I thought it would look pinched. I like the way it looks. I need to wash my car.
#20 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I'd look at the Max Performance summer tire category as that is where you will find the best wet/dry tires, Extreme Performance summer tire category is more about dry grip at the expense of wet grip...
Personally I'll be going with Kumho Ecsta Sport LE's in 205/45-17 size when it's time to replace the Primacy HP's...they have a slightly wider tread @ 7.7", fitting nicely on 7.5" width wheels. I have the Sport LE's on my Tacoma (205/55-16 on 16x7.5 Kosei K-1s), and they were the best overall tire I ran on it, which included wider Hankook RS-2, BFG KDW's, and Kumho Ecsta MX's (from 225-245 width). Phenomenal wet handling and dry handling that is better than the Primacy HP's. Same weight as the Primacy HP's but with a higher load rating and only costing $80 each... And there's a $50 rebate offer now.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#21 | |
#22 |
AutoX-10/10ths every run
As much as I love my Z2s for AutoX, I went and bought 225/45ZR17 Pilot Super Sports to mount on my factory wheels for DD today.
#23 |
Just a dude
Drives: Scion FR-S 2013
Thanks for all the great comments fellas, I've decided I will flip a coin between two choices, at this point either rivals or MPSS for these wheel and their purpose. I truly appreciate everyones feedback. Now just to make some final other thoughts on camber and stuff and a street wheel setup to make up my mind on camber etc... thanks again!
#24 |
If street is the focus - I would stick to the MPSS. Rivals can be driven in rain but I would put them up there with the RS3's in the wet. Can be done, but wouldn't if I had the choice.
#25 | |
Just a dude
#26 |
Drives: Attitude
My previous tires from this category were BFG KDW2 which had amazing wet traction, but terrible noise in the past. The sidewall on the two is comparable in stiffness and you WILL have road noise from the PSS, but I don't think it's terrible or bad. As I said, comfort is relative to the rest of the tires in this category as the sidewall IS stiff, but with the 45 series sidewall and my suspension setup I don't find bumps or cracks to be anymore uncomfortable than stock.
#27 | ||
Drives: '23 BRZ
As for camber: as much as you can get within reason. IMO ~2.5 negative is a reasonable street/track compromise. |
#28 |
I absolutely LOVE my Rivals. I shaved around 5 seconds off 100 second AutoX lap times with them and they are insanely comfortable and capable on the street. In the wet they work, but I wouldn't drive them as hard as PSS or Conti DW in the wet. Those tires SUCK for AutoX though. Not sure if that matters to you.
| Tire recommendations | Shenks | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 09-24-2013 11:46 PM |
| Tire Recommendations | Re~Mix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 09-16-2013 11:06 PM |
| Inexpensive but Safe Tire Recommendations? | Anthony | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 08-13-2013 11:18 PM |
| Best $100 Summer Tire in 225/45/17 | Black Tire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 03-07-2013 06:22 PM |
| Need Tire recommendations please, non track use | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 01-03-2013 04:15 PM |
