Old 07-19-2013, 01:10 AM   #127
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Originally Posted by rainmonkey View Post
I may just be dumb, but I can't for the life of me, notice a difference in sound O_o
It becomes very noticeable when you get up around 4,000 rpm's.
whaap is offline   Reply With Quote
The Following User Says Thank You to whaap For This Useful Post:
HotLeopardMama (07-19-2013)
Old 08-09-2013, 08:51 PM   #128
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
I didn't realized it it was on the passenger side. took me a minute of poking around before I caught on lol.
jimmillion is offline   Reply With Quote
Old 08-24-2013, 11:16 PM   #129
OnTheFence
Drives: 2013 BRZ Limited
Thanks to those who found the different plugs and the spot in the cabin. I just picked up a set of the Hillman plugs at Lowes for a whopping $1.47 and took the car for a spin after popping in it--the difference is noticeable and much appreciated
OnTheFence is offline   Reply With Quote
Old 08-25-2013, 11:14 AM   #130
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I notice my car at about 80ish mph has a new sound that comes into play. A whistle like sound. Is this sound tube allowing this or making this noise?
DrDuquette is offline   Reply With Quote
Old 08-25-2013, 12:52 PM   #131
mfbmike
Drives: 2013 FRS, 2008 R32
How funny. I used the same plug from Lowe's to do a rear wiper delete on my r32 a while back. lol. Awesome to see another use for it.
mfbmike is offline   Reply With Quote
Old 08-27-2013, 12:46 PM   #132
jumbo
Drives: Toyota 86 Manual Transmission
Thanks to all. Will plug my 86 tomorrow!
jumbo is offline   Reply With Quote
Old 09-02-2013, 10:25 AM   #133
Tech
Tech's Avatar
Drives: White MT GT86 with TRD extras
Hi Guys. As the OP of this simple DIY, I thought I would return to give you some further observations on this DIY tip.
The plug I originally used which has been subsequently dubbed the "Lowes" plugs are very cheap and effective. I later updated the post when someone discovered that the plug in the glove box 12V socket also fits the sound tube as well. I tried this mod and found it to be effective also, but still not quite as good as the original plug I used. I can only summised that it doesn't seal 'quite' as well, but still good.
Some months ago, I fitted a Perrin intake tube which deletes the sound generator and tubing completely. I did this for other reasons and not for the sound thing, so I removed all the tubing except the small peice that is left going through the firewall, which now does nothing. This made the engine bay a lot less cluttered and I guess you can say there is also a VERY small weight reduction since it doesn't really weigh that much to start with. Anyway, with the sound components completely gone, there is NO less noise in the cabin than when it is just simply plugged. Therefore, if anybody is planing to remove the tube to get better gains, then you are wasting your time.
THAT IS HOW EFFECTIVE THE "LOWES" PLUG IS!
Glad you are all getting great results with this simple DIY.
Cheers.
Tech is offline   Reply With Quote
The Following 6 Users Say Thank You to Tech For This Useful Post:
Acid18 (01-02-2014), Busybee (01-09-2020), jcw99 (10-04-2014), Pseud0logik (05-04-2014), SirBrass (01-27-2014), SkAsphalt (09-04-2013)
Old 09-27-2013, 03:12 PM   #134
whatsinaname
Drives: 1998 Ford ZX2
Just wanted to thank @Tech and @enouf for this thread. The fix works pretty well even in the lower RPM range (which is where I will be for the next few hundred miles). I used the 12V adapter cover from the glove box because I have my dash cam plugged in there anyway.
whatsinaname is offline   Reply With Quote
The Following 2 Users Say Thank You to whatsinaname For This Useful Post:
enouf (09-27-2013), Tech (09-28-2013)
Old 09-28-2013, 11:27 AM   #135
Ooops
Wannabe Enthusiast
Drives: 2013 BRZ Limited White Pearl
There's a 12v plug in the glove box??? Sweet! I learned 2 things on this thread alone!
Ooops is offline   Reply With Quote
The Following User Says Thank You to Ooops For This Useful Post:
JS + BRZ (01-27-2014)
Old 10-17-2013, 05:35 PM   #136
spineman
Drives: 2013 FR-S Argento
Me too! Thanks whatsinaname and ooops! (can't thank yet on forum?)
spineman is offline   Reply With Quote
Old 11-06-2013, 07:12 AM   #137
Ray_32
Ray_32's Avatar
Drives: '12 Toyota 86 (RED) MT
A big thanks to the OP for the glove box 12V adaptor cover tip!
I reckon that my cabin noise has gone down by 30-40%. It's significantly quieter now with none of that fake intake growl (I had the Red TRD Soundchanger Tube installed which was good fun until the header came in). Of course, it's much less aggressive on the inside but no less outside, which is a good thing. For once the cabin feels rather peaceful and I'm really enjoying the higher refinement levels. I have had the Borla UEL header, Perrin OP/FP, TRD drop-in filter and TRD Quadtip catback installed (plus a Ecutek tune), so yes it's rather loud.
The great thing is how easily it can be reversed - just take it off and go for a fun-filled joyride! Plug it in if you want some nice and easy cruising. I'll be sourcing for a generic 12v adaptor cover soon enough so the one in the glove box doesn't collect dust.
Can't stress how happy I am in discovering this thread. Kudos to the forum and its community!
Ray_32 is offline   Reply With Quote
Old 11-11-2013, 12:12 AM   #138
Dazza
Dazza's Avatar
Drives: Tornado Grey Toyota 86 GT
Wow....2 cars in one....I have unplugged again for something different
Dazza is offline   Reply With Quote
Old 11-11-2013, 07:41 AM   #139
projectXTR
Drives: Sterling Silver BRZ
This...
projectXTR is offline   Reply With Quote
Old 11-23-2013, 12:14 PM   #140
Binbear4
Drives: 2014 Scion FRS
I did the sound tube block off in wife's new 2014 FRS. In addition I also covered with scrap carpet sample...can't see it at all. Noticeably quieter at all speeds... distant engine roar is now upfront vice in passenger seat. No more blue tooth background noise interference. Thanks!
Binbear4 is offline   Reply With Quote
enouf is a damned genious, plug, sound tube, toyoburu kazoo banned.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 11:48 PM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 06:56 PM
