Old 11-10-2013, 11:35 AM   #309
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Originally Posted by h4nh View Post
They're torqued down well. Check them 3 times. Used an inspection mirror next to the header to engine block flange and it fogged up while the engine was running so I can tell that's where it's coming out of.
What gaskets are you using? Did you reuse the stock gaskets? Most of the time when someone says they have a leak, they reuse the stock gaskets which we have found fail. You should upgrade the to the full metal gasket. Either the ones from AVO, or the turbo forester. We are running the new gasket kit with studs that AVO just released on two vehicle and there has not been any problems
DAMotorsports is offline   Reply With Quote
Old 11-10-2013, 12:09 PM   #310
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I would suggest @AVOturboworld to either include these better gaskets with their kits or specifically say they are needed, as I bought and tested the better gaskets by myself trying to find a metal gasket to use after resurfacing the manifold flanges, not by recommendation from AVO or anyone.
The AVO instructions give no direction about replacing gaskets and first logical choice to anyone who does not know the Forester gaskets fit will be to replace them with BRZ OEM ones which IMHO are garbage.
I just added them to the OP of this thread.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ZionsWrath (11-11-2013)
Old 11-10-2013, 02:17 PM   #311
tiny41
Drives: Subaru BRZ Limited
I immediately regretted not buying exhaust manifold gaskets when I first started my car after the install. I am not sure why the kit doesn't come with the gaskets. It came with a gasket for the overpipe connection. My reasoning for not purchasing it was because if they provided the overpipe gasket and not the exhaust gasket, it doesn't need it! Dumb assumption on my part.
PROTIP: BUY THE EXHAUST MANIFOLD GASKETS!
I plan on buying the gaskets and installing it sometime later this week. I'm hoping the exhaust manifold and turbo drops down enough to fit in the gasket so I don't have to completely remove the lines again.
tiny41 is offline   Reply With Quote
The Following 2 Users Say Thank You to tiny41 For This Useful Post:
Pete156 (11-11-2013), ZionsWrath (11-11-2013)
Old 11-11-2013, 12:22 AM   #312
DAMotorsports
It's not easy but yes it can be done. Let us know if you have any other problems of have questions
Old 11-11-2013, 12:40 AM   #313
ZionsWrath
Thanks
ZionsWrath's Avatar
@AVOturboworld
Old 11-11-2013, 01:38 AM   #314
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Originally Posted by Draco_PR23 View Post
I'm talking about the one that goes into the block, replacing the OEM PCV
yes i understand that. The upgraded pcv is not installed to replace it, unless they have released a newer version. The one i received is installed in line with the factory one, in order to limit boost from pressurizing the crankcase, but it does "replace" the factory one, its just supplemental.
killerkid08 is offline   Reply With Quote
Old 11-11-2013, 01:40 AM   #315
killerkid08
Cool Stuff
Drives: Cool Car
I paid for cable and license. That's what it says on the invoice.
I am not going to just live with an exhaust leak. I paid for a kit that claimed to be "well designed" which is why I chose this kit.
talk with your provider about the license. the company should provide you with information about applying your license and such.
Old 11-11-2013, 01:50 AM   #316
killerkid08
Cool Stuff
Drives: Cool Car
To anyone reusing the factory gaskets and such:
To ensure a "possibly" leak free operation, apply a gasket material, similar to:
Permatex® Ultra Copper® Maximum Temperature RTV Silicone Gasket Maker
to the oem gasket, then install, allow to set after torquing everything down. Ensure you apply loctite to your nuts also, and you "should" be good to go.
It's been working for me since i finished my AVO kit reinstall, will update if things start leaking or loosening.
Old 11-11-2013, 01:51 AM   #317
killerkid08
Cool Stuff
Drives: Cool Car
you can install the gaskets without completely removing the entire assembly. The drop down space is there. you will want to have a friend with you though.
Old 11-11-2013, 01:59 AM   #318
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I've been using the GrimSpeed gaskets (similar to the STi/Forester gaskets). No leaks so far (been running about a month). They have a nice beefy fire ring that seems to seal well.
FrX is offline   Reply With Quote
Old 11-11-2013, 02:17 AM   #319
gdrider77
gdrider77's Avatar
Has anyone installed the AVO breather tank? For some reason the Block fitting is kinda bigger than the PCV that will replace. Any ideas?
Also, I think I may have an exhaust leak too but I need to verify.
I have the breather tank installed. I had the same issue. The threaded portion of the block fitting was not threaded correctly. I had to get a new one from AVO. Be carefull. You do not want to force the one you got on if its not threading in there correctly. Only took about 4 months for me to get a replacement fitting.
If it looks kind of like the beginning threads are very "small"? is probably not threaded correctly. Basically mine looked like it was all stripped out. But was new, and looked freshly coated. I will dig up some pics that i took and post tomorrow.
As far as the leak.....as pretty much everyone states, get new gaskets. I had the same problem, had to put on forrester gaskets.
gdrider77 is offline   Reply With Quote
The Following 2 Users Say Thank You to gdrider77 For This Useful Post:
Draco_PR23 (11-11-2013), Sportsguy83 (11-11-2013)
Old 11-11-2013, 02:36 AM   #320
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Paul at AVO got everything fixed. Got the software loaded and it runs great. Still a minor leak but ill have it fixed soon.
h4nh is offline   Reply With Quote
The Following 2 Users Say Thank You to h4nh For This Useful Post:
DAMotorsports (11-11-2013), Draco_PR23 (11-11-2013)
Old 11-11-2013, 05:32 PM   #321
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
The first one is the upgraded PCV valve and the second will replace the factory PCV in the block. I just had a look at it and I see some very small threads at the beginning, I think you kinda see it in the pic.
Thanks!
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 11-11-2013, 05:56 PM   #322
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Let me know how you go about fixing the leak. I think I might still have the slightest leak but at this point I'm not doing anything but machining it if it doesn't go away.
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
