Old 11-08-2013, 01:10 AM   #1
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
Sound generator delete for $1.06
So currently my car is prepped to have fa20club's turbo kit installed and long story short I don't have the rest of my turbo kit yet and I need to drive my FRS for a few days. I do not want to re-install the sound generator so I took a couple measurements and headed to home depot and picked up one of these(sorry for the blur, its a 1.5" schedule 40 threaded pvc cap) :
Got home, tried to fit it in and no bueno. So I grabbed a file and vice grips and went to work:
Sanded it down with the highest grit sandpaper I had lying around(800 grit), washed it, and tried again. Here is the result:
It was a bit of a struggle but I managed to get it on with the help of a flathead. The hex tip of the cap prevents the cap from being sucked in and the tight fit + hose clamp ensures that it wont fall off. If I wasn't going to be installing a turbo and this was going to be more permanent, I would probably round out the hex head and paint it black. But since its a temp fix, its going to stay fugly.
Hope this helps some of you just trying to get rid of the sound generator.
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Old 11-08-2013, 01:22 AM   #2
B L U E S L A T E
Drives: BMW E84
Paint it black!
B L U E S L A T E is offline   Reply With Quote
Old 11-08-2013, 01:28 AM   #3
PineappleFriedRice
Truuu
Originally Posted by B L U E S L A T E View Post
Paint it black!
please see below:
Originally Posted by PineappleFriedRice View Post
So currently my car is prepped to have fa20club's turbo kit installed and long story short.....
.....If I wasn't going to be installing a turbo and this was going to be more permanent, I would probably round out the hex head and paint it black. But since its a temp fix, its going to stay fugly.
Old 11-08-2013, 01:56 AM   #4
B L U E S L A T E
Drives: BMW E84
Paid too much attention on those pictures only. Sorry didnt read through. lol
Old 11-08-2013, 02:03 AM   #5
PineappleFriedRice
Truuu
Glad someone likes the blur
Old 11-08-2013, 04:21 PM   #6
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Isn't there a hole in the cabin you have to plug as well? I'm not sure how easily water could get in so it might not even be a big deal.
EvilBeaverFace is offline   Reply With Quote
Old 11-08-2013, 05:08 PM   #7
jamesm
i used it to run my wideband wires through, which were enough to pretty much block it up. if you weren't using it for that purpose it'd probably be a good idea to block it off (and maybe even if you are).
The Following User Says Thank You to jamesm For This Useful Post:
PineappleFriedRice (11-08-2013)
Old 11-08-2013, 05:08 PM   #8
FR-S Matt
I plugged mine with the cheap plug from Home Depot. I think it was like 70 cents. Took it from the other post on here.
Old 11-08-2013, 05:22 PM   #9
ramiram1984
Drives: 2016 STi DGM
please see below:
Regardless, paint it black.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 11-08-2013, 05:41 PM   #10
PineappleFriedRice
Truuu
I dont think its that much of a big deal. I have a 0 gauge amp wire going through it lol
Old 11-08-2013, 05:57 PM   #11
B L U E S L A T E
Drives: BMW E84
I plugged that hole with this.
Spent less than a dollar. I also bought the correct size o-ring to seal the hole extra tight.
The Following User Says Thank You to B L U E S L A T E For This Useful Post:
Old 11-08-2013, 08:07 PM   #12
Toxicmilk45
Toxicmilk45's Avatar
Drives: White out FRS
There's actually a 12v outlet I think in the glove box
with a plug on it which you can use to plug the hole in the cabin,
it's like they knew we didn't want it there
Toxicmilk45 is offline   Reply With Quote
Old 11-08-2013, 08:31 PM   #13
fstlane
fstlane's Avatar
Drives: BRZ Limited
A 1-1/4" glue in PVC plug fits perfect and looks much better but nice job!
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
Old 11-10-2013, 01:28 PM   #14
Philly758
Drives: GMC
Removed my aftermarket intake and had to put the stock airbox back in temporarily, didn't want to bother with the sound generator and the firewall is already plugged. This is what I used, 70 cents out the door at Home Depot.
Philly758 is offline   Reply With Quote
Noise Generator Delete for $10.00 xcelir8brz Engine, Exhaust, Transmission 85 11-23-2014 02:39 PM
Sound Generator to keep or not to keep? FRS86edition#3 Scion FR-S / Toyota 86 GT86 General Forum 73 11-24-2013 02:26 AM
Sound Generator Tube Delete Anthony Engine, Exhaust, Transmission 8 09-01-2013 05:25 AM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 12:31 PM
