Old 11-07-2013, 05:08 PM   #71
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Just curious as to why anyone would prefer speed density over MAF referencing on this platform?
Shiv@Openflash is offline
Old 11-07-2013, 05:11 PM   #72
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Isn't it better or ideal if you're running high boost ?
SmsAlSuwaidi is offline
Old 11-07-2013, 05:13 PM   #73
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Depending on how much boost you are running you might not have enough resolution for the loads the MAF reads. If you have to extend to the higher loads then you have to lose on the lower loads and driveability area. I prefer speed density from my Honda Uberdata tuning days personally. No worries of making sure the MAF sensor is happy and seeing correct air flow under all conditions.
King Tut is offline
The Following 2 Users Say Thank You to King Tut For This Useful Post:
SmsAlSuwaidi (11-07-2013), whitefrs (11-07-2013)
Old 11-07-2013, 05:26 PM   #74
Shiv@Openflash
Drives: 2013 FRS
You can always have enough resolution with a MAF by adjusting the MAF tube diameter. And you still are left with a load referencing system that measures airflow instead of estimating it. The days when speed density were preferred by tuners were back when MAFs incorporated restrictive flapper door type airflow sensors. In those cases, moving to speed density increased power and was worth the potential drivability drawbacks and tuning difficulties.
For a car that runs open loop fuel control under load, I'd take a MAF based system over speed density any day. NA or boosted.
Shiv
Old 11-07-2013, 05:32 PM   #75
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Regardless of MAF tube size you have X many columns for load and as you increase boost the MAF scaling has to be changed to account for that higher load. You still only have X many columns and that means each of the columns now refers to a larger area of load. As mentioned it is a resolution issue and the number of columns in the OEM ECU is the limiting factor. There is no guarantee that a speed density tune with X amount of vacuum/boost columns will work any better though, I will give you that.
King Tut is offline
Old 11-07-2013, 05:35 PM   #76
qoncept
qoncept's Avatar
It would be much easier to increase the resolution of a table than to implement full speed density tuning. From both engineering and tuning perspectives.
qoncept is offline
Old 11-07-2013, 05:36 PM   #77
Shiv@Openflash
Drives: 2013 FRS
What you described (fixed map resolution with bigger load range) applies to speed density systems too. In fact, speed density systems suffer more in such situation.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Scooby South (11-07-2013)
Old 11-07-2013, 05:42 PM   #78
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Which is why I mentioned that in my post. I have never seen the EcuTek adaptation but because it is custom programmed my guess is that it is not a fixed map resolution or is at least a much larger resolution speed density system.
King Tut is offline
Old 11-07-2013, 05:59 PM   #79
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Originally Posted by Scooby South View Post
I am hoping for SPEED DENSITY Tuning.. We'll see. been scouring Press-Releases.. Nothing yet.. Supposed to be a big announcement from NAMELESS as well.
Bill
EcuTek has had speed density tuning for the 86 platform for quite some time now. Also supports hybrid speed density tuning (MAF/SD, SD/MAF). Great flexibility.
The resolution of the speed density map is 30x24 and is completely scalable.
Circuit Motorsports is offline
Old 11-07-2013, 06:00 PM   #80
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
So...back to the topic, what's the announcement?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline
The Following User Says Thank You to ecko04 For This Useful Post:
OICU812 (11-07-2013)
Old 11-07-2013, 06:13 PM   #81
j.F.c.R.a.S
j.F.c.R.a.S's Avatar
Drives: rx8. frs.
j.F.c.R.a.S is offline
Old 11-07-2013, 06:39 PM   #82
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
My understanding is that the MAF range on the 86 is limited without going to speed density. Is that not true???
Scooby South is offline
Old 11-07-2013, 08:05 PM   #83
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Well, maybe they are going to announce how to fail at announcements.
Sent from my Nexus 7 using Tapatalk
pixel67 is offline
The Following User Says Thank You to pixel67 For This Useful Post:
Mike86 (11-16-2013)
Old 11-07-2013, 08:09 PM   #84
Shiv@Openflash
Drives: 2013 FRS
Not exactly. MAF range is limited by the combination of the MAF sensor element and the diameter of the MAF housing. Keeping the MAF sensor element constant, you can increase the maximum range by simply increasing the diameter of the housing and modifying the MAF calibration table to compensate.
*** SAVE $275 *** on an E-Tune with EcuTek Programming Kit w/Cable Rental Circuit Motorsports Announcements, Contests, Giveaways 23 11-27-2013 04:22 PM
Anyone with an ECUTek Tune get Service Program WQC-39 done? Foobar Engine, Exhaust, Transmission 6 12-17-2012 06:58 PM
JRP LIVE @ SEMA 2012 *updated daily@SEMA* Stav CANADA 22 11-21-2012 02:56 PM
Scion FR-S to SEMA Caravan Event - [Part 1] ichitaka05 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 46 11-15-2012 03:30 AM
Scion FR-S to SEMA Caravan Event - [Part 2] ichitaka05 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 11-12-2012 05:07 PM
