#3571 |
Drives: 2013 FRS 10 Series #2072 (6MT)
Definitely! I needs to be soon though. Maybe next meet I should be able to. I don't have my morning class so I'll be good to go that evening.
If anything, I'd be caught dead smiling.
#3572 |
Drives: Attitude
I don't get off with warnings too often...but last time I did, I was playing race car and apexed over the double yellow.
#3573 | |
#3574 |
Drives: 2013 FRS Whiteout
Follow @pure_automotive_performance on Instagram for all my 86 pics from SEMA
#pureautomotiveperformance
#3575 |
Gettin SIKKY sideways
| The Following User Says Thank You to BoostinIX For This Useful Post: | IloveBaldEagles (11-07-2013) |
#3576 |
Drives: Gray.
Me and @No Brakes are going to watch Thor tonight at Tyson's at 8:45. Anyone else interested in coming in hopes of breaking the awkward date?
#3577 |
Drives: pinto power
i think i might go back to stock suspension for winter. the noises im getting even after going with the whiteline rear end links are frustrating me.
#3578 |
#3579 |
Drives: pinto power
well, from the front drivers side i get a sound like something is loose, but ive double checked everything there, so unless its just a noise from compression on the thrust bearing i've got no clue. from the rear, ive got clunks, and either end link on lca contact or the end link joints are popping. all low speed sounds, little bumps, inclines, turns, just pop pop ping boing.. sounds like i forgot to connect my sway bars, but that's not the case.. this time
![]() i'm on ISC N1 coils, maybe 2" drop, using the supplied end links in the front. hotchkis sways, greased up, whiteline rear end links, stock LCAs. 18x9.5 +38 rpf1's with 225/40 tires. |
#3580 | |
#3581 |
Drives: pinto power
fronts are not. no binding though. and the real kicker is i can push down on the strut tower on that side and hear noise, but cannot find any place its coming from.
rear endlinks are adjustable, short as they can go. [ame="http://www.amazon.com/Whiteline-Rear-Endlinks-2008-Subaru/dp/B004ZZVVM2/ref=sr_1_1?ie=UTF8&qid=1383856602&sr=8-1&keywords=whiteline+sti+endlinks"]Amazon.com: Whiteline Rear Endlinks, 2008+ Subaru WRX & STI: Automotive[/ame] |
#3582 | |
My rears were stock and the roll bar was at 45deg under load. I used KLC182 from whiteline and now they are probaby 15deg which is still not enough but I know it's not slamming on the endlink when I go over bumps. One thing I did notice while putting on and after a test drive of the new endlinks is the knocking may be coming from the springs compressing and uncompressed. So I need to preload them some more. I was able to wiggle them in the spring perch under load and the knocking noise sounded the same. Not sure if these were your symptoms but maybe some more ideas for you to consider. |
#3583 | |
Drives: pinto power
interestingly, i got the klc166 over the klc182 because the endlinks that came with the hotchkis were the same style as the 182, and i was convinced they were hitting the lca under load. wanted the 166 to get the endlink up and out from the walls of the LCA. |
#3584 | |
| Mid-Atlantic spotting thread | OMNOM | Mid-Atlantic | 7400 | 08-27-2021 08:30 PM |
| *Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread | peazs | CANADA | 1397 | 06-28-2019 12:17 PM |
| Its The Mid Week Chat! | vividracing | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 07-09-2012 01:31 AM |
| #ft86club chat room | ayau | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 03-02-2012 10:53 PM |
| FT86Club IIRC Chat | Zaku | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 12-12-2011 09:36 PM |
