Old 11-07-2013, 08:54 AM   #99
Stevo22
Stevo22's Avatar
Drives: GR86
GT V03
Size and cost plox
Sizing and MSRP is on the SSR website. Seems like if you want 17s the only wheel that got a decent fitment in 5x100 is V02 (17x8). V01 and V03 are only 17x7 on the website.
Stevo22 is offline   Reply With Quote
Old 11-07-2013, 11:17 AM   #100
Cesium Rainbow
Cesium Rainbow's Avatar
Drives: '13 dgm brz
Originally Posted by Bad Habits View Post
I'm new to the whole staggered wheel thing but I like the concept of wider rear/skinny front. And I like this wheel at the prices being thrown around versus the TE37 SL's that I'm in love with. Trying to educate myself on the specs and offsets and just want to clarify. With a stock suspension or with a 1" drop all around what would be the needed offset for the GT V01's? I am assuming nothing wider than a 9.5 without getting into body mods etc?
Thx
Sounds right to me, although at that width you have to be pretty spot on with offset to make sure you're rubbing neither strut nor fender. Best to err to an offset too high because if you're rubbing on the strut you can always get baby spacers to push it out. If you're rubbing on the fender the only solution is getting the fender out the way. You're also limited on the tire width you can fit on a 9.5. I think it requires a bit of a stretch without any other modifications. There's a shitload of "does it fit" threads in the wheels technical subforum.
If you want a set of these SSR's, though, they only go up to 8.5 unless you're doing a hub/spacer conversion. But if we all stick with the stock 5x100 when we buy rims the market will continue to grow and more manufacturers will release applications for the twins.
You might already know this but a staggered setup makes the car understeer and a wider wheel is heavier and robs power, especially on the driven wheels which are the ones you'd be putting the wider wheels on if you're going staggered. If you're going FI and have extra power, not such a big deal but at 150 lb/ft of torque there's not alot there to sacrifice for style. I did read that auto-x guys are running 9.5s at stock power levels and doing fine so if traction is your #1 concern that would be fine but then you'd want the widest contact patch you can get in front as well.
Cesium Rainbow is offline   Reply With Quote
The Following User Says Thank You to Cesium Rainbow For This Useful Post:
Bad Habits (11-09-2013)
Old 11-07-2013, 11:59 AM   #101
nonicname returns
Drives: 4 wheels
I'll wait for rota to make these.
nonicname returns is offline   Reply With Quote
Old 11-07-2013, 12:22 PM   #102
L4NDO
L4NDO's Avatar
Drives: '13 WRB BRZ
I like the GT V02, but need to know the weight before thinking about ordering a set.
L4NDO is offline   Reply With Quote
Old 11-07-2013, 12:58 PM   #103
Stevo22
Stevo22's Avatar
Drives: GR86
Ditto.
Old 11-07-2013, 03:02 PM   #104
tinma
Drives: '13 BRZ
id like to ahve the V01 with flat black.. i think it the best offset for stock suspension is 44?
tinma is offline   Reply With Quote
Old 11-07-2013, 03:10 PM   #105
Chee-Hu
Chee-Hu's Avatar
I wouldn't mind any of them to be honest. More info please!
Edit: some size and price info are on SSR's website. MSRP for 18 x 9.5 40 o/s is $420
Chee-Hu is offline   Reply With Quote
Old 11-07-2013, 08:05 PM   #106
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Chee... The 18x9.5" are 5x114 pattern no good for us, and if you run a conversion plate there will be horrible poke at the given 40 offset of those.
Old 11-07-2013, 08:06 PM   #107
OICU812
Just a dude
OICU812's Avatar
Did "Anyone" get and side on shots to see if there is any concave to these wheels in the 8.5" width???
Old 11-07-2013, 08:24 PM   #108
Struckbylitenin
Struckbylitenin's Avatar
Drives: 10 Series FR-S
one day someone will remember to sneak a scale into SEMA, and that person will be a hero
Struckbylitenin is offline   Reply With Quote
The Following User Says Thank You to Struckbylitenin For This Useful Post:
OICU812 (11-07-2013)
Old 11-08-2013, 09:13 AM   #109
PSORngr
Drives: FR-S 10 Series
If the GT V01's come in under the weight of the stock wheels it looks like I'll probably be buying a set. I've wanted 17.0x7 since I just DD the car and don't really need or want any more grip (not enough to justify the drop in mpg or rise in price of tires). I wish we could get the 42mm offset though.
If I can find the "street price" of $230 per wheel as mentioned on the first page I'm sold.
PSORngr is offline   Reply With Quote
Old 11-08-2013, 01:11 PM   #110
Chee-Hu
Chee-Hu's Avatar
I meant to type 5x100 o/s 40. The size is available for the V02. Oopsie!
The Following User Says Thank You to Chee-Hu For This Useful Post:
JB86'd (01-13-2014)
Old 11-08-2013, 01:26 PM   #111
OICU812
Just a dude
OICU812's Avatar
Guessing based on Ravspecs comment in another thread they will be in 350-400 per wheel price range.
Old 11-08-2013, 06:59 PM   #112
Titanmotorsports
Titanmotorsports's Avatar
Drives: Supra
Send a message via AIM to Titanmotorsports
We have the pricing for the SSR wheels for the FRS/BRZ fitment.
http://www.titanmotorsports.com/wheels7.html
Titanmotorsports is offline   Reply With Quote
DCT Motorsports Steering Wheel on 10 series FRS Pablitomarrero Cosmetic Modification (Interior/Exterior/Lighting) 31 09-10-2014 05:37 AM
FR-S/ SBRZ (2013 Al) -PTUNING Braided Stainless Steel Teflon Brake Line Kit!! Freddy@PTUNING Brakes, Suspension, Chassis 33 12-07-2013 02:01 PM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 05:12 PM
CA-FI Dashlinq line 2013 TIE Pilot Electronics | Audio | NAV | Infotainment 26 01-17-2013 06:47 AM
