Old 11-06-2013, 11:06 AM   #1
jarviz
jarviz's Avatar
Drives: Raven FRS MT
Tire situation
My back tires are pretty worn but I still have some decent tread on the front tires.
I want to replace all four but don't feel like dropping $700-800 for replacing all four tires and doing an alignment.
Is there anything wrong with just moving the front tires to the back and getting brand new tires for the front? Or does anybody know of a decent set of All-season tires for a cheap price.
A bunch of websites says it's better to have newer tires in front, but I prefer to have my back end kick out somewhat rather than experience understeer.
jarviz is offline   Reply With Quote
Old 11-06-2013, 11:14 AM   #2
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
The car is RWD so your rears will wear faster. If your tires are non-directional, rotate the front and put the new set in the rear. Rotate side to side every 5k until the rear catches up to the front and then you can rotate normally. If you put the new tires in the front you'll have to buy another 2 tires a lot sooner. If you put them on the rear you'll have to wait longer and then will be able to purchase a full set.
However you mentioned you like the rear end to come out, so putting the new ones in the front will give you that, but you'll have to buy 2 tires more often and will never really buy a full set. Newer tires in the front are safer, especially in the wet. It depends on what you want.
I'm not a tire expert but that's the best I can tell you from my experience.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
jarviz (11-06-2013)
Old 11-06-2013, 11:19 AM   #3
frslee
Just drive it
Drives: 13' FR-S
You live in Queens, NY. Replace all 4 tires.. You can get alignment if you're OCD, but it's not really necessary unless you've hit lots of pot holes and curved wheels.
frslee is offline   Reply With Quote
Old 11-06-2013, 11:20 AM   #4
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Look at getting Hankooks. Great handling tire at a decent price. I used the Hankook ventus v12 in a previous car and it did well on the track. Tires did squeal a bit on highspeed turns on the track but overall did well.
355rockit is offline   Reply With Quote
Old 11-06-2013, 11:26 AM   #5
ayau
Drives: Some rust bucket
If you can't spend any money, move the good tires to the back. Easier to save a car when the front end loses grip before the back end.
Also check the for sale forum. A lot of people are selling their OEM tires for dirt cheap.
Old 11-06-2013, 11:28 AM   #6
Chee-Hu
Chee-Hu's Avatar
This. And I would like to add to not cheap out when it comes to tires.
Chee-Hu is offline   Reply With Quote
Old 11-06-2013, 11:31 AM   #7
jarviz
jarviz's Avatar
Ah, I didn't think about that logic. that's a good point. Thanks.
Old 11-06-2013, 11:32 AM   #8
jarviz
jarviz's Avatar
I thought alignments were pretty much implied when 4 tires are replaced. I don't plan on driving in the snow though... unless for fun
Old 11-06-2013, 11:34 AM   #9
jarviz
jarviz's Avatar
why are our OEM tires $200 a piece on tire rack when all i hear are bad reviews about them?
Old 11-06-2013, 11:36 AM   #10
ayau
Because people automatically associate these tires with a Prius and automatically think they're bad.
Old 11-06-2013, 11:37 AM   #11
ayau
You're probably thinking of tire balancing, which is needed after you mount a tire to a wheel.
Old 11-06-2013, 11:46 AM   #12
torqdork
torqdork's Avatar
Drives: RV-7
They're expensive LRR (low rolling resistance) tires built for fuel economy, not grip that most everyone here prioritizes over EPA ratings.
torqdork is offline   Reply With Quote
Old 11-06-2013, 12:10 PM   #13
Razz
Razz's Avatar
Drives: Fast
Go to Tire Rack.
Save money.
Razz is offline   Reply With Quote
Old 11-06-2013, 12:32 PM   #14
Yep, I agree.
I'd suggest you replace all 4 tires and then rotate the new set every 5,000 or so miles .....
All it takes is one good(bad) slide on a wet road and the cost of the other two tires wouldn't have seemed too expensive.....
WTB: 1 OEM FRS/BRZ Tire RedFR-s Canada Classifieds 3 11-08-2013 11:43 AM
Visconti situation completely out of control post_break Site Announcements / Questions / Issues 31 08-21-2013 11:47 AM
My situation MR WHAAKAKA Scion FR-S / Toyota 86 GT86 General Forum 31 05-22-2013 03:14 PM
WTB One (1) OEM Tire Trojan_SC Wheels and Tires 2 05-07-2013 03:59 PM
What tire PSI are you using SEC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-30-2012 09:09 AM
