Old 11-05-2013, 06:17 PM   #659
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by jamesm View Post
the sti has a 25% larger engine than the fa20. but you may very well be fine with it if you're interested in highway pulls. driving around town it'll be very laggy though.
The added cr helps though doesn't it ?
Old 11-05-2013, 07:25 PM   #660
jamesm
a bit. probably not that much though. an ej25 will still spool a much larger turbo than an fa20 for a given amount of perceived lag.
The Following User Says Thank You to jamesm For This Useful Post:
SmsAlSuwaidi (11-05-2013)
Old 11-05-2013, 08:37 PM   #661
SmsAlSuwaidi
Boosted
Anybody who installed this kit got issues with the piping hitting the headlight?
Old 11-05-2013, 08:58 PM   #662
JerryMichaels7
Drives: Whiteout FRS
You are the first UEL turbo are you not??
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 11-05-2013, 09:02 PM   #663
SmsAlSuwaidi
Boosted
no another guy has it on, and frs300 car should have it too.
Old 11-05-2013, 09:03 PM   #664
Ross
Drives: 85 corolla gts
I will have the rest of the uel kit I ordered here tomorrow. I will not be starting the install till Thursday though. I dought you are willing to wait that long for my take on it. As well I have quite a few other things to install and build for that car, been waiting on the kit to get here as that will take up the most room.
Ross is offline   Reply With Quote
Old 11-05-2013, 09:35 PM   #665
Dan@AWD
Drives: 2013 Argento FR-S
It's a tight fit around the passenger headlight.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline   Reply With Quote
Old 11-05-2013, 09:36 PM   #666
Frs300
Frs300's Avatar
Drives: Pile of junk
easy fix...just remove the headlight housing lol
Frs300 is offline   Reply With Quote
Old 11-05-2013, 09:57 PM   #667
SmsAlSuwaidi
Boosted
How did you work around it? Shave anything?
Old 11-05-2013, 10:23 PM   #668
Dan@AWD
No. It just ended up fitting.
Old 11-05-2013, 10:25 PM   #669
pmccut
Drives: Blue Subarus
Originally Posted by chiefshayan View Post
Hey guys, I asked Andy at fa20club this question but I think he's busy with some stuff so I'll ask here since you guys know first hand what this kit is/can be capable of. I have an automatic FRS looking for around 350-400 whp & 300 TQ on 91 pump gas around 10-12 psi. I was debating between the 60 trim, gt2871r or the gt3076r turbos. What do you think I need to achieve that power? Would it even be possible? Unfortunately there aren't any e85 stations where I live. I wouldn't say my build is an open ticket, but I understand the costs that go into a 400 whp build.
Thanks for your help!
A built engine or meth or e85 to see 300+ on Cali piss
Yup. I had crap numbers with a gt28 on the stock block. Currently running 350/275 on 91 with @FullBlown's 9:1 engine build. FWIW 350 feels quite excellent with how light of a car it is. I certainly wouldn't want a larger turbo with this 2L.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
The Following User Says Thank You to pmccut For This Useful Post:
chiefshayan (11-06-2013)
Old 11-05-2013, 11:29 PM   #670
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
So no more turbo with the built engine? When you had the gt28 what numbers was it producing on the stock block and at what psi? I wonder if the automatic tranny can handle that torque..
chiefshayan is offline   Reply With Quote
Old 11-06-2013, 02:23 AM   #671
pmccut
Super confusing statement ^^.
I still have the same gt28. With the stock block I was somewhere in the low 200s (bad tunes) on 91 @ 7psi. A decent E85 tune @ 7psi made 293whp.
I went for FullBlown's built block w/ lower compression pistons so we could safely shove more boost. 353/275 @ 16psi were the numbers I saw on 91.
It's true the stock clutch can't handle that power. I've had both the exedy stage 1 and CM FX300 which have no issues with these power levels. The automatic trans is certainly fine at these power levels as well.
Old 11-06-2013, 03:44 AM   #672
chiefshayan
Thanks for the detailed reply. Really helps. I see you live in Palo Alto, where did you have your work done for the built motor and turbo? Installing a built motor sounds scary but the turbo seems doable with a partner. So I'm in theory looking at around 10k in parts for around 350-400 rwhp.. Seem right?
Ever thought of installing a water methanol injection system? Since gas is terrible and the closest e85 station is in San Jose (I live in Berkeley), I'm looking at alternatives.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
