Old 11-05-2013, 09:24 AM   #15
utekineir
blowhard
Drives: frs, project forester
borla header?
utekineir is offline   Reply With Quote
Old 11-05-2013, 10:18 AM   #16
bfrank1972
Drives: 2013 FR-S Argento
Yeah I was gonna ask if I missed what header it was for $600? I've read time and time again the Borla EL ain't that great. Wonder what it would look like *without* the header.
Old 11-05-2013, 10:47 AM   #17
autobrz
Drives: Mazda 3
Can the OFT do flexfuel?
autobrz is offline   Reply With Quote
Old 11-05-2013, 11:48 AM   #18
mkivsoopra
Originally Posted by garfull View Post
How sensitive will the tune be to ethanol ratings? E85 has a wide spec can range from 51-83% ethanol, lower in the winter blends. We dont have the benefit of an ethanol meter that flex fuel vehicles have. Would be have to do a test tube ethanol content test prior to fill up to be safe?
How did you do the swith over to e85, did you have to drain the tank fully, or could we fill up with e85 with a gallon of 91oct mixed in?
I've been anxiously waiting for this tune. Looks like the bayarea has a good selection of E85 stations. This is a link to locate E85 stations and other good information regarding E85.
http://www.afdc.energy.gov/fuels/ethanol_locations.html
@garfull, I've been on e85 for the last 10k miles and fill up mainly in San Jose and Redwood City. I've only ever seen fluctuations between 75-81%. I think the advertised minimum is 70% too. Not sure if they change the blend for The winter... but I guess I'll find out soon
mkivsoopra is offline   Reply With Quote
Old 11-05-2013, 12:01 PM   #19
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
X3 on what EL header is 600$?
Nolan
pheoxs is offline   Reply With Quote
Old 11-05-2013, 12:11 PM   #20
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I should have some info on this soon
And to answer garfull's question, running your tank low (not necessarily empty) is all you would need to do to run the E85 map. I think I had about 1 gallon of residual 91oct in there before I filled up with E85 before I dyno tested the car. Now I'm running straight E85 (filled up twice already) and no change to the tuning requirements. Also, I don't expect this car to be particularly sensitive to fluctuations in E85 formulation as it gives more than enough cooling and octane than any NA car will ever need. What a fantastic fuel!
Shiv
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
garfull (11-05-2013)
Old 11-05-2013, 12:13 PM   #21
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Its a shame my closest E85 is 24 miles from work..and 38 from home
Old 11-05-2013, 12:49 PM   #22
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Just curious, do you know what mileage your getting with this tune?
alexand3r is offline   Reply With Quote
Old 11-05-2013, 01:11 PM   #23
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
So this car has a fully stock exhaust... with the exception of the mystery header?
TouchMyHonda is offline   Reply With Quote
Old 11-05-2013, 01:21 PM   #24
Shiv@Openflash
Drives: 2013 FRS
Yep. Will be testing an UEL version of the header next week to see the difference (if any).
Old 11-05-2013, 01:24 PM   #25
Shiv@Openflash
Drives: 2013 FRS
Hard to give a fair mpg number because I've been trashing the car around relentlessly for testing purposes. But if expect a 20-25% reducing mpg all things equal.
alexand3r (11-05-2013)
Old 11-05-2013, 02:00 PM   #26
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
wow very nice!
Old 11-05-2013, 02:38 PM   #27
forzajuve
Drives: Ultramarine 86 - 6MT
in those 10,000 miles have you replaced anything due to the faster wear and tear e85 causes?
forzajuve is offline   Reply With Quote
Old 11-05-2013, 03:01 PM   #28
Shiv@Openflash
Drives: 2013 FRS
Only been running e85 in the frs for a few hundred miles. Apart from a more frequent oil change schedule (every 2-3k miles) there really is no increased wear and tear to speak of. This has been the case of every e85 tuned car I've driven in the last 10 years. The reason for the more frequent oil changing is because of a faster oil contamination rate when running ethanol.
Have you hit 200whp NA? empower-auto Engine, Exhaust, Transmission 323 11-26-2015 07:49 PM
2013 for $1200 off msrp AllStar0419 Scion FR-S / Toyota 86 GT86 General Forum 21 08-26-2013 05:00 PM
Dyno take 2, 200whp on 92Octane ?! AJ PwR Engine, Exhaust, Transmission 76 07-31-2013 02:14 AM
Bespoke upgrade = $1200? madpcsupreme Electronics | Audio | NAV | Infotainment 4 06-13-2013 10:19 AM
