Old 09-23-2013, 11:17 PM   #1
nakamur21
Drives: 2013 BRZ limited
RCE Tarmac 0, KW V1, and ST coilovers
Seeing that these three systems all use the KW damper, what tangible differences are there between them?
I understand there may be some differences in spring rates, also apparently RCE makes their own unique valving system. Other than that, is there any reason to buy one over the others?
If price is your main concern, ST wins by a mile.
Reading through the RCE thread, they sound awesome, but the price is significantly higher, and I've never seen a direct feature by feature comparison with the STs elaborating on why they are any better.
V1s, haven't heard much about them for the 86 yet, seem to be well received on other platforms though.
Anyone with knowledge about these coil overs care to chime in? Thanks
nakamur21 is offline
Old 09-24-2013, 12:00 AM   #2
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
ST uses a different housing that is not going to deal with corrosive environments as well as the V1's or RCE units. Then valving, spring rate, and support all plays a role as well.
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Racecomp Engineering (11-05-2013)
Old 09-24-2013, 06:43 AM   #3
FR-S Matt
I'm running the Tarmac 0's, maxed lowered in the front, matched in the rear. The performance is outstanding and the ride isn't too bad. I've definitely added more bounce into grooves on the road but that is to be expected with coilovers. Feels more like a racecar!
FR-S Matt is offline
Old 09-24-2013, 11:02 AM   #4
autobrz
Drives: Mazda 3
Max low looks cool to some people but it means you are hitting the bump stops much more often when the roads are uneven. That's probably why it's bouncy. I know you didn't complain or ask about it but it's important to point that out because other people will think coilovers are "supposed to feel bouncy and stiff." RCE made the same observation for one of their customers with T0s on their T0,T2 thread.
p.s. I don't have any RCE products on my car nor am affiliated with them.
autobrz is offline
Old 09-24-2013, 11:07 AM   #5
autobrz
Drives: Mazda 3
ST and V1 perform the same except V1's body is more corrosion resistant because of different material.
T0 has higher front spring rate than ST and V1 so it's a little more performance oriented.
autobrz is offline
Old 11-05-2013, 10:54 AM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Anyone know why KW website doesn't list the V1 as an option for the frs? I even asked a couple of US vendors and both say it doesn't exist? Or has it been discontinued now that there's the ST available?
Fizz is offline
Old 11-05-2013, 11:07 AM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by FR-S Matt View Post
I've definitely added more bounce into grooves on the road but that is to be expected with coilovers.!
nope
nope
a race car isn't supposed to be bouncy, if it's bouncy then it's losing traction and time. You've improperly setup your coilovers for the road conditions and are using incorrect adjectives to describe the feel of your car. Please don't be part of the problem of spreading misinformation.
7thgear is offline
Old 11-05-2013, 11:09 AM   #8
FR-S Matt
Originally Posted by 7thgear View Post
nope
nope
Yep. By bouncy I mean over small bumps where the travel is longer. The coilovers are still tight and doesn't bounce like the bounce you're thinking of. There's nothing to adjust on the Tarmac 0's but ride height so I highly doubt I "set" them wrong.
Old 11-05-2013, 11:16 AM   #9
FR-S Matt
you "set" them to the lowest setting and are driving them on the street.
i'd go ahead and say that you've set them up wrong.
consider raising them to OEM height along with a corner balance then post back on your results.
No one is raising these coilovers to OEM height.... Do you even have these on? Have you even been in my car? How about you stop saying I'm spreading misinformation when I'm simply just sharing my experiences. My coilovers are fully broken in and perfect right now.
My fronts have 1-2 threads left, the rears are matched with the front in ride height. No clunks, no "traction loss", just longer travel over small dips in the road that make it travel more than the stock suspension. That's the only difference.
Old 11-05-2013, 11:19 AM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes, your experiences are clouded in misunderstanding of vehicular physics.
No, i have not been in your car, but i have been in racecars. They are not bouncy.
7thgear is offline
Old 11-05-2013, 11:23 AM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
height adjustable "coilovers" were designed with the intention of corner-balancing a vehicle after establishing a proper spring/damper combination for the design and weight and inteded use of a particular vehicle.
putting them all the way down and bailing down the street claiming race-car status was not the intention, but you, among a sea of other "tuners", have unfortunetly made it so.
7thgear is offline
Old 11-05-2013, 11:36 AM   #12
Holy crap, settle down people.
- Andy
Racecomp Engineering is offline
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 03:43 PM
FS: RCE Tarmac 0 coilovers r4m3n Brakes, Suspension, Chassis 2 08-13-2013 08:35 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
