#15 |
Drives: subaru brz
guys? lol, if you're gonna sit there, put every single point by hand, you got waay too much time to spare
![]() http://www.subaruxvforum.com/forum/i...ips-hacks.html http://fixmygps.info/forum/showthrea...23607#pid23607
2013 BRZ Limited 6speed Manual |
#16 | |
Codename: Stitch
So if I am reading this right, you found a way to download existing alert point data and add it to the SD card? Have you tried it and found it to work on the BRZ navi?
#17 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
This appears to be awesome. I may try it to confirm.
#18 | |
Drives: subaru brz
yes, exactly right. Redlight/Speedcameras is what i have put on SD card.
#19 |
Drives: BRZ Limited 6MT
#20 | |
As I understand it I have to download the trapster POI's and convert them to Primo format. I got the trapster POI's in garmin format just fine, but the (sketchy Russian) conversion software is nowhere to be found. EDIT: I looked around again...I think the POI's from this place will work: http://poiplaza.com/index.php?p=dc&c=49 EDIT EDIT: there is one on page 5 called "fix speed cam" (2013) and one called "speed traps" (2010) AND: page 10 has "redlight and speedcam" (2013) Both of these seem to have been updated in 2013. So, that's good news. I have to run some errands, but I may try this later today. AND: if you look at the map it seems that there aren't all that many POI's for all areas of the US (other countries might be different). I'll have to find an alternative conversion program to get the trapster stuff into iGo Primo format. Last edited by robot; 10-19-2013 at 05:22 PM. |
#21 |
I gave up. If someone figures it out let me know.
#22 |
Drives: subaru brz
i'll write something up this weekend, maybe that'll help
| The Following User Says Thank You to Nissanfan For This Useful Post: | DoomsdayJesus (11-04-2013) |
#23 |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
#24 |
Drives: subaru brz
sorry guys, didn't forget. I started on a write up in my spare time on friday, but gotta finish up working on my daily driver beater before snow comes in to Chicago. Will post step by step POI as soon as I finish it.
#25 |
Drives: TIE interceptor; BRZ13
bump. update? @Nissanfan
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
#26 |
Hey guys sorry if this is bumping an old thread but I saw it ended a bit abruptly and I wanted to share how easy this is. This is on a 2014 Subaru BRZ Limited:
First off here is the only link you need http://www.subaruoutback.org/forums/...am-alerts.html A couple of the steps below are copied and pasted directly from there. 1. With car off eject SD card (alternatively if you want the radio on while you do this for some reason go through the menu and eject the SD card properly don't just pop it out). 2. (Optional but recommended) Make a back up of your SD card. I used disk utility on a mac to make an image of the card. You can also use the HDD Raw copy tool that is on the link, I would not be able to help you as I did not need it. 3. Download the file at http://fixmygps.info/forum/showthrea...23614#pid23614 (If you are in the US of course). This is a zip which when unzipped makes a folder called "speedcam" 4. Rename your speedcam folder on your SD card to "speedcam_OLD" (navigation/content/speedcam) and copy the one you downloaded to this content folder. 5. To enable. Go to Map>Menu>More>Settings>Sounds and Warnings> (scroll down) Alert point settings (tick box) and enable alert types The end result is this: ![]()
#27 |
Codename: Stitch
that's awesome that someone got this to work!
EDIT: dinoniel sent me the ZIP file that you need and I am hosting it on my site for others to download as well. http://86drive.com/wp-content/upload...-speedcams.zip also, am I correct in assuming that if you replace the speedcam folder you will lose all your previously set custom alert points? (which would probably be fine for the 99% of people who never used it anyways but I have a few custom points set.)
Last edited by PMok; 09-30-2014 at 11:43 PM. Reason: added link to hosted ZIP file for download |
| Tags |
| alert, brz, fujitsu, navigation, warning |
| Philippines on HIGH ALERT vs. china's INVASION | phenoyz | Off-Topic Lounge [WARNING: NO POLITICS] | 46 | 12-11-2013 06:30 PM |
| protecting the pinch weld lifting points | midnitz | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-08-2013 09:36 PM |
| Car Jacking up Points? | J-Money | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 01-21-2013 02:55 PM |
| Installed Curb Alert system | sesmls | BRZ First-Gen (2012+) — General Topics | 17 | 07-27-2012 01:26 PM |
