#575 |
It's the Mad Cow
I believe someone else asked this and the answer for now is that it cannot. It might come much later down the line but it cannot do anything with it currently.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#576 |
#577 |
It's the Mad Cow
No Problem, with how many threads on OFT there are it can sometimes be confusing to find every little thing you are looking for or remember where you found it. Glad you were able to find your answer.
#578 |
Drives: Scion frs
if i have acess to 94 oct and have a headerback would stage 2 map still be too agressive without actually having a header im guessing 94oct is more knock resistant just wouldnt wanna do anything that would damage the car thanks alot for any input!
mike |
#579 | |
Drives: '13 DGM BRZ Limited
Stage 2 is only for catless headers. Has nothing to do with what octane gas you have. |
#580 |
OFT ordered this morning
#581 |
She said member
Drives: fr-s firestorm
@shiv@vishnu
Hopefully this is an easy question: how would I raise my cold idle rpm? I see several idle tables with -40, -30, -20... At current 1800 I have an extremely loud resonance, I can hold the idle up a bit and quiet it down a lot. I'm running borla uel and catless front pipe with stg2 |
#582 | |
She said member
#583 |
Drives: 2015 WRB Limited
A few pages back it was mentioned that the -40, -30 etc numbers were coolant temps I believe. And the other number is the RPMs (obviously). You could try editing the RPM numbers in the Idle Target tables and see if that works for your needs.
Superfast Jellyfish
#584 | |
I hear you on the resonance, especially when the car is cold. This was something I had on the K20A Honda as well and drove me nuts until I figured out that it was cam phase and ignition timing related. I believe the idea is to get the Cat heated up quickly upon start up. I was able to modify the cam phasing to minimize it on the Honda and I think we can do the same here especially since when we get rid of the cats, there is no need for this procedure anyways. |
#585 | |
this brings up a good feature request for tunerpro though, units (or anything other than just a bare number with no description) on the tables would be extremely useful in understanding what you're dealing with. tunerpro is great software, but the lack of any type of units or description on the tables makes the learning curve steeper than it needs to be. fwiw though you can always just poke around romraider to determine what tunerpro doesn't tell you, then transfer the knowledge over, but it'd be a 'nice to have' for people using tunerpro anyway. |
#586 |
Drives: frs
I've been playing with those tables...I presume those temps are in Celsius?
Also the temp vs maf is in g/s? Do you have the link in romraider you mentioned....I've been searching their forums and only find older info. |
#587 | |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
#588 |
Drives: '08 bmw 135i
nice work, shiv. the OF tablet works very nicely on my 335i. i'm considering picking up an FR-S and it's nice to see you here supporting this platform. cheers
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
