go_a_way1
Old 11-03-2013, 08:01 AM   #211
uncivilised
Drives: 86 GT
hey,
i got a few questions for you
i'm running 225/45/17 rs3 with 17x8 wheels, -2.5 camber and 0 toe on the front, -1.5 (i think, dont have the alignment result sheet on hand), 0 toe on the rear.
running 38psi hot front and rear.
What hot pressures should i aim for with those rs3's? (ill have to invest in a pyrometer at some stage)
also if you had a choice between 17x8 35 offset wheels or 17x8 45 offset wheels, which would be best suited for track (offset wise)?
thanks in advance
uncivilised is offline   Reply With Quote
Old 11-03-2013, 10:19 AM   #212
BRZ NA
Drives: WR blue
Does our car need oil cooler for track used when it's still NA ?
BRZ NA is offline   Reply With Quote
Old 11-03-2013, 11:21 AM   #213
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I had sustained oil temps over 270 at Roebling Road in August with no cooler. It was nearly 100 degrees out at the time. We can debate all day whether those temps cause synthetic oil to shear or not but I believe that the ECU is making major adjustments resulting in more power loss than we realize. According to my Solo data, my speed went from 104 at the exit of turn 9 to 120 at the entrance to turn 1 braking at the 100' mark. Gaining only 16 mph on that long of a straight does not reflect anything near 200hp to me. I have the Robi cooler going on this week and I will be back at that track the first week of Dec. I can't wait to see the straightaway change, would not be surprised to hit 125
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 3 Users Say Thank You to Deep Six For This Useful Post:
amram (03-28-2014), CSG Mike (11-04-2013), normancw (11-03-2013)
Old 11-04-2013, 12:02 AM   #214
CSG Mike
CSG Mike's Avatar
Originally Posted by uncivilised View Post
hey,
thanks in advance
38 hot is pretty close. Most people run 36-38 with RS3 on this car, including myself.
No way to tell if your alignment is good without either tire pics (not the best), or pyrometer readings (much more accurate).
+45 is better.
uncivilised (11-04-2013)
Old 11-04-2013, 12:03 AM   #215
CSG Mike
CSG Mike's Avatar
I've seen no correlation between engine failures and lap times, with oil coolers.
We need more data and feedback from the community to really judge this.
Does it hurt to have one? Absolutely not.
@Deep Six: 270F doesn't bother me. It's nothing to be worried about with a high quality oil.
Old 11-04-2013, 03:37 AM   #216
uncivilised
Drives: 86 GT
hey mike,
thanks for the advice
here is a pic of the front left tire (now swapped to the rear) this tire shows the most outside wear.
Old 11-04-2013, 04:13 AM   #217
atledreier
Drives: GT86 DGM
Regarding the oil cooler, my butt dyno tells me the car is down on power when the oiltemp goes up. Perrin had a great breakdown of this in their exhaust development thread. I'll try to dig it up.
atledreier is offline   Reply With Quote
Old 11-04-2013, 10:08 AM   #218
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by torqdork View Post
Also, about trail braking. Every HPDE instructor I've had including two this year says to complete all braking in a straight line before corner entry. ?
Originally Posted by ZDan View Post
It is almost impossible to drive a car anywhere near its limits "braking only in a straight line".
Originally Posted by SubiePig View Post
SubiePig's link is spot on.
I think the issue is poor word choice on behalf of the HPDE instructors. The word "ALL" should be replaced with the word "MOST." Most of your heavy braking should in fact be made in a straight line.. but you mustn't lift off the brake prior to the turn-in, but gently release as you transition into the turning arc.
It also depends on the type of turn. Fast-entry, low-speed, high-angle turns are a nightmare for true trail braking.. and would most likely overload a novice's abilitiy... because you'd need to adjust your entry and exit lines. A lil too much for beginners i think.
What to take away here is that there are many instructors that know what to do and what to say but they don't know why they are doing it and don't realize that the words coming out of their mouths don't relate to what they are doing.. but that's another matter.
The Following User Says Thank You to 7thgear For This Useful Post:
amram (03-28-2014)
Old 11-04-2013, 10:21 AM   #219
DarkSunrise
DarkSunrise's Avatar
I had an instructor tell me to start experimenting with trail-braking yesterday. It made a nice difference getting the car to turn-in on some of the slower/medium speed corners. It felt very natural, so my instructor thought I might have already been doing it subconsciously to some extent I don't know.
What I found surprising was how planted the rear end felt. I was almost expecting the rear end to come around under medium trail-braking, but that didn't happen. Is that normal or are some part of the nannies/EBD still active even though VDC/TC is fully off?
2022 BRZ Build
2013 FR-S Build
Old 11-04-2013, 10:39 AM   #220
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Originally Posted by WolfpackS2k View Post
Based on comments I've read on this website it seems like German made Castrol Synthetic oil is the best to use for our cars if Track Duty is in mind.
Im not sold on it; I ran it in my BRZ on track for two days and it caused the oil temps to get a bit higher than i'd like; in the 290's, once I switched to a 0w20 (Toyota OEM oil) it brought the oil temps down about 10 degrees. I did Blackstone UOA on the GC 0w30 and the Toyota 0w20 and the Toyota offered just as good protection as the GC in terms of wear metal readings.
Lower oil temps, good protection and cheaper/easier to get - I have been running the Toyota OEM 0w20 ever since. I change it out after 4 track days (2 weekends).
smbstyle is offline   Reply With Quote
Old 11-04-2013, 10:40 AM   #221
BRZ NA
Drives: WR blue
hey mike,
W -2.5 at the front it still worn the outside edge that much?Um...may be a wider size tire needed?how's the grip/performance increase from stock?
Old 11-04-2013, 10:43 AM   #222
BRZ NA
Drives: WR blue
Yeah thx,just trying to find out, if oil cooler is not needed then I could spend the money to some other parts
Old 11-04-2013, 10:49 AM   #223
smbstyle
smbstyle's Avatar
wanna see some sidewall wear? I'll post a pic of my left front from Sebring this past weekend, it looks like a full slick lol
Old 11-04-2013, 11:05 AM   #224
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if you're transfering weight properly (gently, evenly) it is in fact normal
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
