Old 11-03-2013, 09:00 PM   #351
Harrisk
Drives: Toyota GT 86
Originally Posted by slicktop View Post
Can you guys stop posting pics if you aren't going to list wheel/tire specs? Thanks!
Yep, sorry forgot to put the specs in. 18x9.5 +30 on 245/40 Hankook z221
Harrisk is offline   Reply With Quote
Old 11-03-2013, 09:10 PM   #352
Brzfly320
Drives: Ssm brz
Great stance. Any rubbing issue? Camber setting? Coilovers or springs? Tnx
Brzfly320 is offline   Reply With Quote
Old 11-04-2013, 09:12 PM   #353
E46toFT86
Drives: IB '05 E46 M3 ZCP
Figured I'd post in this thread.
Stance SS Coilovers
CCW LM5T 18x9.5 +44, 18x10+38
Hankook Ventus V12 255/35 & 265/35
Front fender is rolled near the sidemarker. Plenty of clearance up front, could prob add 6 MM Spacer give or take to make the tires even more flush with the body. No tire stretch at all, FUNCTION + FORM Rears are pretty perfect flush fitment with minor camber. At my current ride height I dont rub @ all, but I havent really tested by putting a lot of load on the suspension. I can also achieve full lock at the front wheels.
Still wanting to buy Rear LCA so I can get a proper alignment & get the most out of the tires.
'05 Interlagos Blue
E46toFT86 is offline   Reply With Quote
The Following 9 Users Say Thank You to E46toFT86 For This Useful Post:
Baldoak (06-24-2015), boxer 2.5 (11-05-2013), btune (11-04-2013), chris x sway (01-21-2014), Enraged21 (11-07-2013), Jive Turkey (11-18-2013), Mr. (01-01-2014), PRORICAN (11-05-2013), SkAsphalt (11-08-2013)
Old 11-04-2013, 10:11 PM   #354
Junebug
Junebug's Avatar
Drives: 2013 scion frs firestorm m/t
@Jive Turkey im running a mad stretch but i am looking to switch over to the same set up you have, im getting a good deal on some 275/35/18's do you think i would be rubbing alot? My fenders are already rolled flat so im hoping i can fit them but figured you might be able to help me out in knowing how or if these would fit.....
Junebug is offline   Reply With Quote
Old 11-04-2013, 11:13 PM   #355
mfbmike
Drives: 2013 FRS, 2008 R32
18x9.5 et 40 nt03's all around
265/35 michelin pss
fenders being rolled tomorrow in the AM, alignment immediately thereafter to dial it in
can't wait. love the way this car handled before, love it even more now.
I really need to get some better pictures taken. lol.
Thanks for the help @Jive Turkey and @PRORICAN
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
Old 11-04-2013, 11:27 PM   #356
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
you will have to be a little higher in the front than me. but otherwise it should be okay to fit those, just will have to run a little bit more camber.
265/35 michelin pss
thats looks bad ass man!
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
Junebug (11-05-2013), mfbmike (11-04-2013)
Old 11-05-2013, 01:20 AM   #357
Junebug
Junebug's Avatar
@Jive Turkey did you have to do alot of fender rolling on your to fit the 265's?
My car is pretty low and id like to stay low, in your pics it seems the rear has a lil more room so i might just do 265 up front and 275 in the rear and try running the least camber possible even if it requires me to do a slight pull on my fenders, hope i can get away with it... Btw Thanks for the info!
Old 11-05-2013, 06:03 AM   #358
Harrisk
Cheers mate, rubbed a bit, dropped on coilovers and - 2.5 camber up front and - 2 rears
Old 11-05-2013, 05:00 PM   #359
PRORICAN
PRORICAN's Avatar
265/35 michelin pss
No problem man! Looks great!
PRORICAN is offline   Reply With Quote
The Following User Says Thank You to PRORICAN For This Useful Post:
mfbmike (11-06-2013)
Old 11-06-2013, 10:09 PM   #360
DIM
Originally Posted by E46toFT86 View Post
Post some more pics up! Looks goood.
DIM is offline   Reply With Quote
Old 11-07-2013, 12:06 AM   #361
toby714
Drives: whiteout
My car at buttonwillow raceway =D
toby714 is offline   Reply With Quote
Old 11-08-2013, 09:37 AM   #362
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Gramlights 57Xtremes 18x9.5 40 offset
BFGoodrich G-Force Sport Comp 2
275/35/18
Will be updating soon with pictures!
DesertFrs is offline   Reply With Quote
Old 11-12-2013, 08:39 PM   #363
mrdanyo
Drives: 2014 BRZ Limited (World Rally Blue)
275/35/18
275 wow!!
mrdanyo is offline   Reply With Quote
Old 11-12-2013, 09:33 PM   #364
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
wheel and tire specs?
smbstyle is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
