Old 10-14-2013, 10:24 PM   #43
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Data Logs! Post them here.
here are mine
e85 tune at 11-12 psi
1) idle
2) cruise
3) 3rd gear pull
The Following 2 Users Say Thank You to whitefrs For This Useful Post:
gdrider77 (10-15-2013), pixel67 (10-15-2013)
Old 10-15-2013, 08:06 PM   #44
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Originally Posted by whitefrs View Post
here are mine
Thanks for putting these up. Any WOT logs? Those are the ones that are interesting to look at and compare.
pixel67 is offline   Reply With Quote
Old 10-15-2013, 08:08 PM   #45
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
The last one is a 3rd gear pull
1) idle
2) cruise
3) 3rd gear pull
Sent from somewhere
Old 10-15-2013, 09:41 PM   #46
pixel67
pixel67's Avatar
I must have opened the same one twice as i didn't see but one or two rows with Throttle position greater than 80. I'll download again...
The Following User Says Thank You to pixel67 For This Useful Post:
whitefrs (10-15-2013)
Old 10-15-2013, 09:49 PM   #47
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I have been seeing a lot of you logging a/f learn values? and a lot more then 25 parameters being logged at a time. I was under the impression that you wanted to keep the parameters you were logging to 25 and under since the more you log the more the values could be incorrect?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-15-2013, 10:23 PM   #48
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
The more parameters you log simultaneously the less resolution you get (number of rows of data in a time-frame). It shouldn't make any parameter inaccurate, but you want a decent amount of resolution, especially if you are troubleshooting a specific issue.
If you logged a WOT run for example, log too many parameters and you would see large jumps in RPM, like one row would show data for 3200rpm, the next row would show data for 3800rpm, and you would be missing a lot of data between 3200 and 3800rpm.
Logging fewer parameters would give you rows with 3200rpm, 3233, 3275, 3290, 3310, etc. as an example. That's increased resolution and gives you more detail to work with.
Always follow your tuner's requests on what parameters to log for them, as they are asking for specific parameters to make the adjustments needed.
For your own use, 25 parameters or less is a good rule of thumb.
Circuit Motorsports is offline   Reply With Quote
Old 10-18-2013, 07:43 PM   #49
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
New Tune, New Logs
at Wot it Pulls Much Harder and Feels better but cruising feels a little weird.
maybe ECU needs to learn
I also saw -4.5 knock while cruising but only once and it didn't happen again
welp my tuner is informed and here are the logs
Old 10-25-2013, 08:11 AM   #50
Jacques Blom
Turbo 86
Jacques Blom's Avatar
Drives: Toyota 86 Turbo
Hi Tuners .. Cry of help \ advice ..
I am about ( month from now ) to instal my GReady Turbo Kit in my 86. I will use ECOTEC .. any of you out there that can share a basic start up map for me to start from - Turbo installed .
The Local Tuners in South Africa is new to ECUTEC and most 86 setups run SC - Vortec.. So I will be th first to play in the Turbo Space.
Pls PM me if you can help \ share info .
Thanx
Jacques Blom is offline   Reply With Quote
Old 10-27-2013, 04:01 PM   #51
feldy
feldy's Avatar
Thanx
As far as I know the maps are tied to your vin or dongle Id info. I could be 100percent wrong.
Anyone care to correct me?
Old 10-27-2013, 09:54 PM   #52
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I am under the same assumption.
gdrider77 is offline   Reply With Quote
Old 10-27-2013, 11:49 PM   #53
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Thanx
Isnt greddy come with a basemap?
Old 10-28-2013, 05:21 AM   #54
Jacques Blom
Turbo 86
Im an not sure about the base map ? Any of you installers of the gready Kit .. have any feedback?
Old 10-31-2013, 11:38 PM   #55
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
I just flashed back to stock after my second tune, and I still like it better. I'm just not sure about the afr - the minimum was 12.17. What are safe values for an intake and exhaust?
I mean I really love where it is now.. the torque dip is not as noticeable. It pulls in second and in third and a bit in fourth (Automatic). Without the mods, I would feel the pull from 2k to 2.5k, then you would feel the lag above that until you hit 4.5k. Right now it almost feels linear.
I'd rather keep this then get a tune if it doesn't feel as good. I sent my logs, so we'll see what happens next time I flash. I do see the knock, but I've read that been reading that the stock rom does have tip in knock.
Mike
mike_ekim1024 is offline   Reply With Quote
Old 11-03-2013, 08:32 AM   #56
brn12345
brn12345's Avatar
Ok so I have been logging my car for some time and had been very disappointed with the IAM falling all the way to 0.45. Today I flashed a stage 1 rom and as expected the IAM started at the set 1.00. I went for a drive normal cruise for few minutes then did a 2nd,3rd,4th full throttle run. Very slight knock and IAM went from 1.00 to 0.98 (fair enough). Then I started another log a few minutes later and during that log, normal driving, IAM fell massively from 0.98 to 0.85 to 0.65 in less than a few seconds. I tried going through all the logged items to try and find a correlation to what was causing this drop and couldn't find a thing. I am attaching JPEGs of the logs and also the log files themselves. If anyone wants to do some analysis and figure out why the massive IAM drop would be much appreciated.
brn12345 is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
