Old 11-02-2013, 11:08 AM   #2073
whataboutbob
AutoX-10/10ths every run
Had the additional idler pulley develop a squeak over the last few days. Car has about 7K miles on it with the SC. Pulled the pulley off and rebuilt it. Repacked it with wheel bearing grease. Bearings had minimal slop. Silent now. While I was in there I checked the throttle body for oil. No sign of any blow by, clean.
Here's some photos.
Build thread:Here
The Following 4 Users Say Thank You to whataboutbob For This Useful Post:
cantholdanymore (11-02-2013), sw20kosh (11-09-2013), tech4pdx (11-02-2013), ZionsWrath (11-02-2013)
Old 11-02-2013, 11:38 AM   #2074
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Originally Posted by sw20kosh View Post
Stage 2 incoming! =)
Is that a ground control camber plate I see in this picture? If so I have them too......kinda disappointed ill have to remove my GC strut tower brace to fit my innovate in there
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 11-02-2013, 12:27 PM   #2075
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Originally Posted by Andy@FA20Club View Post
Pre SEMA the FA20Club CAI for the twinscrew
That's what mine will look like soon. Half of it is already done that way. Custom.
tech4pdx is offline   Reply With Quote
Old 11-02-2013, 12:38 PM   #2076
ZionsWrath
Thanks
ZionsWrath's Avatar
Here's some photos.
Sorry to bother but I really have no idea what I am looking at? What pulley is that exactly? One from the stock motor or the innovate? Why in one picture there are some bearings or balls and the other looks like just a gasket?
so confused
Old 11-02-2013, 01:23 PM   #2077
TemeCal
Drives: 86
Check with Adam at GC ( @GC_Adam ). I've been thinking about the Innovate, and simply made an inquiry with GC. They had me take measurements between the strut bar and hood, so they could design something that would work with the Innovate kit. They contacted me last month, but I was too busy to get back to them. I'm pretty sure they have a solution (or are very close to it). I believe it's just a simple spacer to raise the strut bar a little.
Feel free to PM me, if you want me to follow up with Adam. They're GREAT guys, and will figure out a solution so you can keep it.
TemeCal is offline   Reply With Quote
The Following User Says Thank You to TemeCal For This Useful Post:
CK_Bladesmith (11-02-2013)
Old 11-02-2013, 01:25 PM   #2078
sw20kosh
Drives: 2013 Black FR-S
After 10 hrs of installation of the FA20club intercooler kit (was not a bolt on job) we strapped her down to the dyno and ran the non-intercooled tune to see what the intercooler does on its own.
Very dissappointed to see it lost about 15 whp. I am guessing this is due to there being a restriction now in the air stream. This data is contrary to what Bill has seen in the past. Maybe he can chime in here.
Loaded up @DeliciousTuning new ROM he made for me that added 5 degrees of timing and made 230 whp. This is very preliminary but I thought it would be interesting to show you guys what happens when you install this intercooler and how much whp 5 degrees of timing advance gave (30 whp). Will be working with Bill to polish the tune hoping to match or exceed innovate's results of 244 whp considering they didn't have a 70 mm pulley, header and exhaust....
Graph shows the non-intercooler tune vs. the advanced timing tune. Both runs on 91 with the intercooler installed.
Tach signal was having issues all night so we lost some data on some runs.
The Following 4 Users Say Thank You to sw20kosh For This Useful Post:
akuhei (11-02-2013), Calum (11-02-2013), cantholdanymore (11-02-2013), TemeCal (11-02-2013)
Old 11-02-2013, 02:06 PM   #2079
ft_sjo
Drives: GT86
What map sensor are you using?
Old 11-02-2013, 02:49 PM   #2080
pmccut
Drives: Blue Subarus
Why have I not seen your car at the bay area meets ?
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 11-02-2013, 02:54 PM   #2081
tech4pdx
Make love
tech4pdx's Avatar
This site does a good job at describing Laminova intercoolers:
http://www.boostecus.com/index.php?o...d=35&Itemid=24
Yes there is a restriction just like with any intercooler. I think you will find your lost power in the tune.
Old 11-02-2013, 02:55 PM   #2082
tech4pdx
Make love
tech4pdx's Avatar
I would guess he's using an omni 3 bar.
Old 11-02-2013, 03:20 PM   #2083
xxscaxx
Drives: 2013 SWP BRZ
no way the IC makes less power. Like @tech4pdx said, it will be found in the tune, and probably more (and remember on less boost because of the pressure drop)
xxscaxx is offline   Reply With Quote
Old 11-02-2013, 03:27 PM   #2084
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
How do we order this?!
Sent from my SCH-I605 using Tapatalk
UltraMarine86 is offline   Reply With Quote
Old 11-02-2013, 04:08 PM   #2085
sw20kosh
It is a honda 11.5 psi sensor that my tuner installed a while back. Why do ya ask? Would I better off with a stock one?
Old 11-02-2013, 04:13 PM   #2086
sw20kosh
Yes the IC made less power on the same tune. When we upped the timing aggressiveness the power came up.
This is contrary to what was shown before where an IC showed 10 whp gain not loss on the same tune. The only difference is the pulley and that might be a reason why I lost power instead of gained... Dunno.
That was my only point.
I was seeing the exact amount of pressure pre and post intercooler measured via a mechanical boost gauge.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
