Old 10-31-2013, 01:51 AM   #1
jkr
jkr's Avatar
Drives: '13 frs
how in the world do you...
get through the rubber wire holes in the firewall. I have a wire for the fog lights and it seams damn near impossible to get through that hole under the drivers side dash.
jkr is offline   Reply With Quote
Old 10-31-2013, 02:04 AM   #2
suaveflooder
Use a flat head screw driver and use it to put a hole in the rubber. I had to do it with my amp for my subwoofer. Started with a small one, and moved bigger. This is on the passenger side, but should work on the driver's side as well.
suaveflooder is offline   Reply With Quote
Old 10-31-2013, 02:19 AM   #3
jkr
jkr's Avatar
Drives: '13 frs
does it work going the opposite direction, inside the car to the bay ?
Old 10-31-2013, 02:28 AM   #4
suaveflooder
Should work either way. Just use the screwdriver with the wire taped to the end and push it through. Make the hole first, then follow through.
Old 10-31-2013, 09:51 AM   #5
rishi
rishi's Avatar
Drives: FR-S Series 10 #0059
If you're doing drivers side, there's a little capped tube on the grommet that's made for the purpose - just snip off the tip and you can run a wire through easy. Passenger side is closer to the battery though.
rishi is offline   Reply With Quote
Old 10-31-2013, 10:58 AM   #6
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
If you look at the rubber gasket, there is a little black rubber extrudes out. Just punch a hole on that with your screw driver, it will go straight into the inside and you can run the wire through there. This is how I run my fog lights wire through.
#944_10_Series_FRS is offline   Reply With Quote
Old 10-31-2013, 12:24 PM   #7
sparks
sparks's Avatar
Snip off the end of the tube in the engine bay, wires will pass through no problem. Use some silicone adhesive to seal
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 10-31-2013, 12:53 PM   #8
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Cut a slit with a razor blade. But, since you are only running one wire you can probably pierce it with a coat hanger.
Take a metal coat hanger, undo it, cut the ends (they will be nice and sharp), push it through the grommet (make sure you're NO WHERE NEAR the wires or that would be bad), then tape the wire to the end of the hanger (nice and tight - lube it up too with some spit), pull the other end from the hood and the wire will come with it.
rmjjensen is offline   Reply With Quote
Old 10-31-2013, 08:46 PM   #9
jkr
jkr's Avatar
Drives: '13 frs
thanks a ton everyone !
THE END OF THE WORLD White64Goat Off-Topic Lounge [WARNING: NO POLITICS] 6 09-16-2013 08:43 PM
Where in the world am I? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 57 09-09-2013 02:34 AM
World War Z JPxM0Dz Off-Topic Lounge [WARNING: NO POLITICS] 14 04-08-2013 07:41 AM
THE END OF THE WORLD IS UPON US.... White64Goat Off-Topic Lounge [WARNING: NO POLITICS] 0 02-28-2013 04:42 PM
Will they tell the world the pricing at TAS? Slide Scion FR-S / Toyota 86 GT86 General Forum 23 01-10-2012 07:57 AM
