#589 |
Boosted
Drives: Not a supra....yet
#590 | |
Drives: 2013 Argento FR-S
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2 |
#591 |
Drives: 13' BRZ
Its easy to tell by the trap speed that the car is making decent power. ET doesn't necessarily tell you anything about the power.
| The Following 2 Users Say Thank You to cruizin01 For This Useful Post: | Dan@AWD (10-31-2013), Sportsguy83 (10-31-2013) |
#592 |
#593 |
| The Following User Says Thank You to Dan@AWD For This Useful Post: | Sportsguy83 (10-31-2013) |
#594 |
Drives: Firestorm Scion FR-S
I think that was driver error. I ran a 13.4 at 112 on my street tires and I only have about 260-270 horses. for 116 ts your time is ok because our launches suck but I def think your trap speed should be a good bit higher
FA20 club 60 trim + flex fuel 467 whp 356 ft lbs @ 19 lbs Owner of Sidewinders Auto LLC. San Antonio TX |
#595 |
WOW! Impressive. My turbo kit is going on in a week or so. I'm sentenced to 91 gas where I live, but I AM going with WMI, so I'm hoping for some decent numbers, but I doubt I'll get anywhere near 430. I'd be pleased as punch with 350.
#596 | |
#597 |
Your in Dallas Correct? Which track are you going to out there? Also what size street tires are you using Im on 225 so Im sure if I threw some bigger tires on I would easily pull between a 12.9-13.2 depending on size. I just really think your Trap should be higher. I run consistently at 110-111 trap. Slick are definitely a world changer in our cars though because a hole shot is the biggest part of a pull.
#598 | |
#599 |
Oh crap I thought you were out of Dallas. lol I could be completely wrong but relative to what my traps it just seems like it should be higher with the difference in power and not to mention your tires should be a good helper at getting the power to the ground. Ive never seen a car with a weight of less then 3G with over 400 HP run that low of a trap. If I calculate correctly you should be running 125+. I guess I will see soon once I start running e85.
#600 |
Drives: Whiteout FRS
your traps should be higher...with your trap speed and a guess of 3000 pounds every HP calc is saying around 350 range. Also still using 3000 pounds assuming traction and a good run should be low 11 secs at around 125ish
life's greatest stories usually start with the words, "fuck it!".
| The Following User Says Thank You to JerryMichaels7 For This Useful Post: | bgibbsunc (11-01-2013) |
#601 |
Exactly my thought. When I calculate mine based off 3000 lbs and my time I get around 260 hp which is in the exact range that I guess and exactly what I get from Virtual Dyno
#602 |
Boosted
Our BRZ got dropped off at @Evasive Motorsports for the FA20club UEL 60 trim install
| The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | Tylub (11-07-2013) |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| FA20CLUB TURBO KIT T3/T4 60 | 86pro | Forced Induction | 50 | 07-26-2014 11:48 AM |
| Fa20club turbo install issues | Mikegraves777 | Forced Induction | 8 | 07-25-2013 12:56 AM |
| FA20CLUB 60 Trim Turbo 16 PSI Results Are In | FA20Club.com | Forced Induction | 148 | 07-22-2013 08:00 PM |
| FA20CLUB V2 Turbo Kit Progress | FA20Club.com | Forced Induction | 40 | 05-17-2013 01:26 PM |
