Old 10-28-2013, 08:29 PM   #43
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by PRORICAN View Post
Will these work with other springs? I'm running wide wheels and narrow springs that coilovers usually come with are needed to clear without rubbing.
Yes you could use a small diameter spring with a similar rate. We can customize that option. Will add money to the cost of them though.
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
PRORICAN (10-28-2013)
Old 10-28-2013, 10:52 PM   #44
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by Ro_Ja View Post
Springs are also progressive, not linear.
After a few days of driving, I'm very pleased with the kit. Ride quality is better than I expected. Early reports stated that you will feel more imperfections of the road, which I found to be true. However, the bumps are definitely less jarring than they were on the stock suspension. Car stability is also improved. Great value for the money, IMO. Bilstein is also a great brand to invest in for ease and availablity of service and rebuilding once you grow out of the stock settings.
Can you post some pics of these on the car?
By the way....can anyone explain whether adjusting the height on coilovers affect the spring rate in any way? i.e. does it increase stiffness the more you preload the spring and vice versa?
Fizz is offline
Old 10-29-2013, 01:23 AM   #45
Ro_Ja
Drives: TOYOTA
By the way....can anyone explain whether adjusting the height on coilovers affect the spring rate in any way? i.e. does it increase stiffness the more you compress the spring and vice versa?
Not sure on the exact drop, but it's definitely quite conservative. About an inch or so. There is a decent amount of height adjustment left on the shocks.
Ro_Ja is offline
The Following 6 Users Say Thank You to Ro_Ja For This Useful Post:
*KID* (10-29-2013), chanomatik (03-28-2014), diss7 (11-01-2013), Fizz (10-29-2013), FT-86 SpeedFactory (10-30-2013), rcm47 (10-31-2013)
Old 10-29-2013, 11:27 AM   #46
Racecomp Engineering
Only with a progressive rate spring.
- Andy
Racecomp Engineering is offline
Old 10-30-2013, 04:12 PM   #47
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Wow these look great, I prefer the stock top hat as it reduces the harshness of the coilovers, also should keep them quiet.
Definitely at the top of my list for the price.
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline
Old 10-30-2013, 09:46 PM   #48
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
- Andy
Thanks....so would that mean it's not recommended to corner balance a coilover with progressive springs? Because by doing so one side of the axle may end up with more preload than the other thereby giving uneven spring rates on that axle?
Fizz is offline
Old 10-30-2013, 11:02 PM   #49
FT-86 SpeedFactory
Looks great.
Old 10-31-2013, 02:17 AM   #50
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Your drop looks perfect. What wheels are those? Size?
Fizz is offline
Old 10-31-2013, 02:32 AM   #51
Ro_Ja
Drives: TOYOTA
Thanks. Prodrive GC-07J 17x8 +43 with 225/45 Michelin PSS.
Ro_Ja is offline
Old 10-31-2013, 03:39 AM   #52
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Noob question: when adjusting vehicle ride height, does the increments on the shock body translate to equal increments in actual ride height?
i.e. say you wanted to lower/raise your car by 5mm, would you adjust the spring perch by that same amount?
Fizz is offline
Old 10-31-2013, 10:31 AM   #53
Hmmm, well one way to look at it is that if you really feel the need to corner balance your car then you likely should be running linear rate springs with a helper anyway. Also, if you set the car for a perfectly even ride height (but not corner balanced) you may have slightly different preloads on the springs anyway because each corner does not weigh the same.
In reality though the differences will be extremely minor and I wouldn't worry about it.
This depends on the motion ratio...for the front it will be close but not the rear. Ballpark yes but a little fine tuning would be necessary.
- Andy
Fizz (10-31-2013)
Old 10-31-2013, 10:59 AM   #54
mid_life_crisis
Drives: FR-S 10 #103 AT
At what driver weight should you start considering setting the driver's side a little higher to allow for additional compression to make the ride height be level when your lard butt is in the car? Yes, I'm large.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline
Old 10-31-2013, 12:05 PM   #55
mike156
Drives: EVO
Throw some bags of salt or concrete in the car to match your weight while setting the ride height. The softer the spring rate, the more pronounced the ride height change will be.
Of course, doing it this way, it's purely cosmetic and you are likely messing up the corner balance. Myself, I measure spring free length and then compressed length with my weight in the driver’s seat. Even up the spring length change left to right on the car and you should be pretty close to 50/50 cross weight. This of course assumes you are using good springs, like Hyperco or Swifts. I wouldn't try this with Ebay junk.
mike156 is offline
The Following User Says Thank You to mike156 For This Useful Post:
mid_life_crisis (10-31-2013)
Old 10-31-2013, 03:48 PM   #56
mid_life_crisis
Whatever comes with the coilovers. I'm either going very basic with a set of springs (probably "Yellows" based on reviews and product description) or entry level coilovers like ST or maybe step up to the Bilsteins. Obviously there won't be any adjustment to worry about if I go with springs.
Now that I think about it, I suppose I could just get in the car and have the wife measure the fender heights to see how far off they are.
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
