Old 10-28-2013, 02:11 PM   #1
frs10
Drives: tezla
front strut bar/tower question
has anyone removed the factory stock "V" strut braces and just run a strut tower bar?
just curious on impressions
frs10 is offline   Reply With Quote
Old 10-28-2013, 02:49 PM   #2
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
I wouldn't..considering the strut to firewall braces are there from the factory, they're there for a reason. The engineers would not put a chassis brace in that spot for show on a car where they were trying to shed as much weight as they could to begin with.
Rather than ditch one and get the other, why not run a strut tower bar in addition to the V braces? They will compliment each other if nothing else by triangulating the strut towers to the firewall.
Zach3794 is offline   Reply With Quote
Old 10-29-2013, 01:52 PM   #3
frs10
Drives: tezla
just a random thought i had to see if anyone went to try this out
Old 10-29-2013, 02:00 PM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
That would kind of defeat the purpose of adding bracing, in this case, the strut tower bar.
Old 10-29-2013, 02:14 PM   #5
DKEddy90
DKEddy90's Avatar
Drives: asphalt grey scion frs
Hotchkiss makes a triangular strut tower brace.
Sent from my SGH-T999 using Tapatalk 2
DKEddy90 is offline   Reply With Quote
Old 10-29-2013, 02:18 PM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
removed mine to clear turbo setup.
no notiecable difference after removal
86_ZN6 is offline   Reply With Quote
Old 10-29-2013, 02:19 PM   #7
Zach3794
Really anything that triangulates is going to be your best bet, rather than deleting. Hotchkis and AEM make a one piece, idk if FT86speedfactory's is one piece or not. I run TBPerformance's strut tower bracing. They're separate pieces but they interlock at the strut towers and the strut to firewall braces are adjustable for preload.
After feeling the difference they make I'll likely never remove any of them.
Old 10-29-2013, 03:05 PM   #8
frs10
Drives: tezla
interesting, this was what i was wondering... do you track ur car?
Old 10-29-2013, 03:08 PM   #9
frs10
Drives: tezla
i was interesting if there was any real difference from using
a) stock
b) strut tower alone
c) triangle bars
d) strut + stock
and see what differences they make while driving
Old 10-29-2013, 04:23 PM   #10
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
yes!
Old 10-29-2013, 05:02 PM   #11
Piercemotorsports
Piercemotorsports's Avatar
Drives: 2013 Subaru BRZ
I agree with Zach---I'd leave the firewall braces in or add a one piece bar that ties the towers together with the triangulation. I've been making braces for years and made a chromoly one for our BRZ---the material is crazy strong/rigid and fairly light so it has a big impact/noticeable difference vs the 3 pc designs with rodends/bolts that are only really able to control compression/tension...
Piercemotorsports is offline   Reply With Quote
Old 10-29-2013, 06:27 PM   #12
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
I've seen them replaced with lighter bars but not removed.
DoomsdayJesus is offline   Reply With Quote
Old 10-30-2013, 08:27 AM   #13
s2d4
s2d4's Avatar
How did go with your sheared bolt from installing the strut tower bar?
Front Strut Tower Bar $89 and Chassis Brace Kit! Hal@Dynosty Brakes, Suspension, Chassis 41 04-22-2014 04:15 PM
FS Cusco Strut Tower bars front and rear Wes Brakes, Suspension, Chassis 17 01-10-2014 12:54 AM
Tanabe front and rear strut tower bars .. FriedRicr Brakes, Suspension, Chassis 1 04-06-2013 05:40 AM
Front Strut Tower Bar Question russv Scion FR-S / Toyota 86 GT86 General Forum 29 05-22-2012 03:00 AM
