CANADA Canada
Old 10-29-2013, 11:51 AM   #1
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Fuel Efficiency Drop
I have notice my efficiency drop from about 7.3 L/100km to 8.5 L/100km with the colder weather on the exact same daily commute. Has anyone else had their cars drop this bad? The only other change was i put winter tires on, but the first week they were on i still got 7.5 L/100km.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 10-29-2013, 12:14 PM   #2
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Well colder weather will have an impact. And it can be significant if the trip is not long enough to achieve full enough warmup to balance off the richer running when cold. Are your winter tires the same diameter? Some folks think the car can compensate for this somehow, but I have never seen an explanation of how it would do this?
smbrm is offline   Reply With Quote
Old 10-29-2013, 12:19 PM   #3
R2
That's about what I saw over the last year, summer average was ~ 8L/100km in the city, winter went to ~10-10.5L/100km once it got cold. I track every tank and I also noted that the dash fuel consumption reports roughly 0.4 to 0.5L/100km lower than the actual. And this has been consistent for every single tank I have put in it. So, you're likely doing even worse than you think unless you calculate the numbers yourself.
R2 is offline   Reply With Quote
Old 10-29-2013, 12:53 PM   #4
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Winter blend gas is here bud. The specific blend of fuel at the same octane rating will have less energy per litre of fuel.
http://jalopnik.com/what-you-should-...g-i-1450089585
drewbot is offline   Reply With Quote
Old 10-29-2013, 01:55 PM   #5
voyager2285
voyager2285's Avatar
Drives: WRB BRZ
Yeah I started noticing that too on the BRZ. Same thing when I had my Civic, I tracked every tank for 4 years with the exact same trend.
voyager2285 is offline   Reply With Quote
Old 10-29-2013, 05:10 PM   #6
Steve
Steve's Avatar
Drives: 6MT
Yep.
Steve is offline   Reply With Quote
Old 10-29-2013, 05:49 PM   #7
RedFR-s
RedFR-s's Avatar
I figured all that. My tires are the same and I track every tank with an app on my phone. my Cobalt wasn't affected as bad, just wanted to make sure this was more or less normal. Thanks for the replies guys.
Andy
Old 10-29-2013, 11:05 PM   #8
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
It's a combination of longer warm up times (less efficient while warming up), the different blend of gas, and typically slower commute time when roads are bad
Sent from my Nexus 4 using Tapatalk 4
Nolan
pheoxs is offline   Reply With Quote
Old 10-31-2013, 12:53 AM   #9
stateless
Double Dragon
stateless's Avatar
Drives: 2013 6MT BRZ Limited
The stock tires too are made for better fuel economy and putting on winters (in particular, but really any tire) will lower the fuel economy slightly (if you were running the stock summers).
stateless is offline   Reply With Quote
Old 10-31-2013, 01:29 AM   #10
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by drewbot View Post
That sucks. I hate being at the mercy of big corporations.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-31-2013, 07:17 AM   #11
l8apexr
l8apexr's Avatar
Drives: hybrid + racecar + FR-S
Higher density air due to it being colder means the matching and appropriate air/fuel ratio mixture must be compensated for accordingly.
More air, more fuel. Simple stoichiometric balance being maintained.
Team Lexus IS300 race car
'14 Lexus RX450h Sport Design daily driver
'14 FR-S fri/sat/sun car: SARD LSR wing, Downforce front lip, Mann Engineering dampers, TRDsways, Milltek xhaust, AEM Intake, RAYS 57xtreme, OnPoint Dyno ECUTek tuned: +30rwhp!
l8apexr is offline   Reply With Quote
Old 10-31-2013, 09:31 AM   #12
Thorpedo
The SquadWhisperer
Yes, that is true. But due to the air being more dense you would actually require less throttle to accelerate the same. "The air being more dense" isn't the reason you burn more fuel. Longer warmup times + thicker oil on startup + winter gas + less efficient tires is your reason.
Thorpedo is offline   Reply With Quote
Old 11-05-2013, 10:31 AM   #13
stevstevd
Drives: Mazda6
Air density is one of many reasons.
http://www.metrompg.com/posts/winter-mpg.htm
stevstevd is offline   Reply With Quote
Old 11-05-2013, 11:03 AM   #14
Thorpedo
The SquadWhisperer
The only part related to air density in that link was aerodynamic drag. They generalized that aerodynamic drag increased 2% per 10 degrees f. It isn't anywhere near that simple, and can't be generalized that way. Speed would be a variable which throws that number out the window. Also the Source for that info was a Cummins engine website, likely referring to large transport vehicles.
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Badass Drop-In Fuel Injectors - 350cc, 450cc, 550cc 750cc 1150cc Visconti Engine, Exhaust, Bolt-Ons 28 06-07-2013 02:43 AM
*** Introducing the SBD290 DROP-IN Fuel Pumps for the BRZ/FRS/GT86 *** Visconti Engine, Exhaust, Bolt-Ons 21 03-08-2013 01:50 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
