Old 10-28-2013, 04:10 PM   #15
Dezoris
Dezoris's Avatar
I say this in every post, but about this, disconnect the rear sway bar end links at the bar and zip tie them up and test drive.
The end links connect to the OEM with such low torque and are so easy to strip that if they have any play when you lower it will clunk like as if you had a blown shock. It's impossible to re-create except at low speeds.
I also went through and replaced both control arms (precaution) and all suspension bolts as recommended by service manual when doing any removal and install. If you don't at the very least use red thread lock on bolts as that is how the factory pieces come.
See picture
Old 10-28-2013, 04:36 PM   #16
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
See picture
Thanks. Another possibility here.
I was just praying that its not a issue of axis.
So if the problem is like this, I only hav to change the end links, not sway bar, correct?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-28-2013, 04:52 PM   #17
Dezoris
Dezoris's Avatar
Yes simple replacement endlinks bolt and nuts, not bar. Simple to test before you jump to conclusions.
If you are lower than -2.0" then you should just go straight to adjustable endlinks as the OEM links will be heavily pre-loading the bar.
Old 10-28-2013, 04:54 PM   #18
Figo
Figo's Avatar
I think I am about -2'', so can I change the endlink without changing sway bars?
Thanks
Old 10-28-2013, 05:01 PM   #19
Dezoris
Dezoris's Avatar
I think I am about -2'', so can I change the endlink without changing bars?
Thanks
Disconnect and test first. If that the links are the issue just replace the ends with adjustable links to avoid issues in the future and eliminate pre-load. (Bar does not need to be replaced)
If it's not your links, find the problem first before changing anything else.
Old 10-28-2013, 06:11 PM   #20
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
it would make sense why i dont have the noise you speak of...i put in kartboy endlinks when i put in my coilovers.
Jive Turkey is offline   Reply With Quote
Old 10-28-2013, 07:40 PM   #21
Figo
Figo's Avatar
Did you have both front and rear end link when u install the coilovers?
I remember you have front sway bar only, correct?
I dont have any noise from front suspension, which is strange. Cus I drop more at the front and the front link is recommended to be changed.
I will try to figure it out tomr. Thank you so much. Btw if the problem is the end links, can I drive it for weeks without damaging my car?
Old 10-28-2013, 10:17 PM   #22
Jive Turkey
the tuna, no crust.
stock front bar/endlinks.
rear kartboy endlinks.
Old 10-28-2013, 10:23 PM   #23
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Man why have there been so many threads about clanky KW V3s lately? It makes me hesitate on buying some.
campy is offline   Reply With Quote
Old 10-28-2013, 10:25 PM   #24
Dezoris
Dezoris's Avatar
Yeah no issue as long as you tie the bar out of the way and the end links.
It may just under steer a bit more other than that no mechanical risks.
The Following User Says Thank You to Dezoris For This Useful Post:
Figo (10-29-2013)
Old 10-28-2013, 10:33 PM   #25
Figo
Figo's Avatar
I dont think the clanking comes from KW V3. Cuz it doesnt hav any issue before. I heard the clanking after drop the car alot.
Old 10-28-2013, 10:34 PM   #26
Figo
Figo's Avatar
sounds cool...why not get front endlink? lol.
Old 10-28-2013, 10:39 PM   #27
Jive Turkey
the tuna, no crust.
didn't think i'd need it? i'm going to do the front swaybar come spring anyway so i'll do that together.
The Following User Says Thank You to Jive Turkey For This Useful Post:
Figo (10-29-2013)
Old 10-29-2013, 04:13 PM   #28
Figo
Figo's Avatar
thank u so much.
I fixed the problem already. It was the springs on my coilovers. when they adjusted height, the springs moved a little bit and was not at the correct position.
Suspension DEALS from Moddiction! AVO, Whiteline, Perrin, KW, Eibach, Tein, Cusco+++ Moddiction Brakes, Suspension, Chassis 122 03-02-2018 08:34 AM
**BLOWOUT SALE ON ALL SUSPENSION PARTS FROM CUSCO AND WHITELINE!!** genometuning Brakes, Suspension, Chassis 163 01-12-2015 07:21 PM
B2autodesigns Suspension and Brakes Cusco, Eibach, Tein, H&R, Whiteline and Stoptech b2autodesigns Brakes, Suspension, Chassis 44 01-17-2013 11:18 AM
Whiteline|Cusco|TEIN|Perrin|KW & More! All your suspension needs here @ CMS Circuit Motorsports Brakes, Suspension, Chassis 64 12-18-2012 02:25 PM
