#323 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
#324 |
Updates?!
#325 |
Drives: Gx 460, FRS, Prius
Here's how the car looks with both rims and tires on. Not really happy with the speed sensor issue as its causing me to use a front tire size that im not exactly thrilled about. Will start doing research on coilovers later tonight. Anyone know of a coilover setup that has NO Minimum Drop? The slick I want to run is about an inch taller so I need the extra room.
Sizes are: Front 225/45/18 Rear 285/40/18 ![]() Edit: @TrogDor the Burninator Here is the side pic. Going to roll the fenders once I drop the car
#326 | |
#327 |
Drives: 2013 Hot Lava FR-S 6 MT
Do you have a profile view from the rear or from above the rear tires? Seems like at that off set and size of wheel/tire that you have poke outside the fender in the back. Trying to get an idea of the amount of camber you would need to get the wheels inside the fender. Simply lowering the car might not provide enough natural camber to get them inside the fender without some rolling or some RLCAs or bushings.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
#328 | |
Yup +48 all the way around, but Ive temperately got a 5mm spacer in the front until I get coilovers.
#329 |
Drives: Whiteout FRS
what slicks you gonna try and run? my guess is a 28inch tall of some type
life's greatest stories usually start with the words, "fuck it!".
#330 | |
Drives: Raven FR-S
someone pass me a fork and steak sauce plz. meaty as f*ck!!!
#331 | |
Drives: 13 CSB BRZ Ltd
I currently have 18x9.5 +40 Forgestar F14s with 265/35/18 Michelin PSS's mounted sitting in my garage. They've been there for a couple of weeks. I have freshly powdercoated RacerX Fabrication rear LCA's sitting in my room. I'm waiting on a small bushing issue to be fixed in the front that will give me the most clearance. I specifically chose to wait to put my wheels on until all of the issues were addressed and the correct hardware was installed. I'm waiting until the car is properly set up. I'm really disappointed to see an attempt to squeeze 285s on the car being prepped so poorly.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
#332 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
^your modding ideas and reasoning are not HIS. WHO ARE YOU to say whats right ant wrong here. you two more likely than not have difference goals in mind, so do not go and say what he is doing is wrong when he has not stated a purpose or stated what he has sitting or planned in the very near future.
is a 285 for an NA brz overkill. yes, but granted someone asking about minimal height and slicks must know what they are doing here. no need to bash, we are all enthusiasts here. i have KW v3's and it seems like they can go pretty high up, but i'm not sure if they drop you a few MM even cranked up. i'm sure this has been asked before somewhere. |
#333 | |
Have fun waiting for your the perfect moment, and best of luck when it finally comes...
#334 |
Drives: 2013 FRS, 2008 R32
![]() ![]() 18x9.5 Enkei nt-03's in SBC with 265/35 Michelin PSS waiting to go on. Can't wait. |
#335 |
Drives: Argento FRS
Got some cheap 245/40 to see how things fit, then a 255 RSR or RS3 in the Spring.
ig: @potatoglasses // @toastedbiscuits |
#336 | |
Drives: whiteout frs
I am trying to decide on 225/45 vs 225/40 on a 9in wide wheel. Apparently 225/45 is a stretch on even a 9in wheel but seems like you're fine on a 9.5in wheel ![]() is there enough room there to drop the car 1.5" with a 225/45/18 tire?
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
