Old 10-24-2013, 08:11 PM   #477
cnk
Drives: '13 DGM BRZ Limited
The launch RPM is set by taking the redline and subtracting the value in the RPM Delta.
Old 10-24-2013, 08:23 PM   #478
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by cjsporl View Post
ok thanks i got to the perameter. Currently the launch control RPM Delta is set to 2000. What do i change it to so that it launches at 7,400 rpms and i cannot find the perameter for flat foot shifting.
To set the launch control RPM to 7400, set the Launch Control RPM Delta to 200 (200=7600-7400)
To enable FFS, set Launch Control RPM Delta to 2000rpm. This means that a secondary rev limit set to 5600rpm (7600-2000) will be enabled when you press the clutch while driving (flat-foot shifting).
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 10-24-2013, 08:29 PM   #479
Shiv@Openflash
Drives: 2013 FRS
Also, keep in mind that if you try to open up the parameters for FFS or Launch control when a stock or 6AT ROM is loaded in Tuner Pro, the software will lock up. This is because FFS and Launch control is not defined in these ROMs. Only the 6MT tuned ROMs can have their FFS and Launch Control values edited
Old 10-24-2013, 08:42 PM   #480
Shiv@Openflash
Drives: 2013 FRS
is this right?
how bad is flat foot shifting on the clutch?
Yes, that's right. Just make sure to commit the changes to the ROM by clicking on the little disk icon on the top left of each window. Then Save the file (File->Save). And then load it to the OFT.
Flatfoot shifting is largely a gimmick as well. Really only useful on turbo cars to keep them from discharging boost (and needed to spool up gain) between each gear change. On a NA car, it's completely unnecessary IMHO.
Shiv
Old 10-24-2013, 10:17 PM   #481
cnk
ehhh i uploaded the tune but 7400 seems a bit high.. what value do i change it too for 7000.
As I stated earlier, the launch control RPM is determined by taking the redline (7600) and subtracting what you put in the delta value. So if you want a 7000 rpm, you would put in 600 because 7600 - 600 = 7000.
Old 10-25-2013, 03:34 AM   #482
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why would you want it that high?? I find 4k too much at times, even in the dry, to gain any real traction. 7k will just light up the rears.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-25-2013, 07:34 AM   #483
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I live at high elevation so 4500 is what I ended up with during autoX ....so 3000 ish for the setpoint.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 10-25-2013, 05:22 PM   #484
CajunFRS
Drives: Challenger R/T, CRX SI,
Will OFT attempt or tune any phantom electric systems? Once data logging and everything is a go.
CajunFRS is offline   Reply With Quote
Old 10-25-2013, 05:24 PM   #485
Shiv@Openflash
Drives: 2013 FRS
Absolutely. As soon as I get my hands on one locally. So far, the closest one is 500 miles away.
Old 10-25-2013, 05:27 PM   #486
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Yeah I need to get up there. I want shiv to tune this bad boy. Any chance you are going to be down this way anytime soon?
Installed Mods:
Old 10-25-2013, 05:36 PM   #487
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
If you can PM me your contact info so that we can get in coordinate a possible meet up.
Robert@Openflash is offline   Reply With Quote
Old 10-25-2013, 05:44 PM   #488
Sojhinn
Sojhinn's Avatar
Pm sent bro.
Come on down. I know some great spots to eat and drink!
Installed Mods:
Old 10-25-2013, 06:05 PM   #489
Cross
It's the Mad Cow
Cross's Avatar
There are too many intakes on the market (and some not very good) for us to support with customized mapping. So going forward, our maps will be intended for stock airboxes. And with the snorkel/duct removed, it performs just as well as any aftermarket intakes. But without the MAF signal misreadings. So unless you need underbood bling, it really makes most sense to stick with the stock airbox (with a decent panel filter). I ended up removing the airraid intake on my car and went back to the stock box
Does this mean those of us with the AirRaid need to make custom 1.3 and soon custom 2.0 tunes to continue to get the changes provided for the MAF Location change? NM just checked 1.3 Beta is Stage 2 and there is no longer an AirRaid Option. I will look for the changes between the AirRaid and Non-AirRaid to import over for my setup.
I don't see that being a big issue but I thought I would ask.
Can't wait to see the dyno results and soon the E85 maps I hope!!
Thanks, oh and maybe I overlooked it but how is data logging going? (Been gone for a week on our Honeymoon, no internet out in the middle of the Ocean)
Old 10-25-2013, 11:54 PM   #490
CajunFRS
Thanks for the info.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
