Old 10-23-2013, 05:04 PM   #701
ptuning
ptuning's Avatar
Drives: White FR-S
We did some back to back testing with our PTUNING Spec-SS GT3076R equipped FR-S shop car running only a base 6psi 93 pump gas tune vs. a bone stock FR-S. Both cars are equipped with a 6-spd manual transmission.
We tested what we believed were some common day to day driving scenarios to show the versatility of our turbo system's powerband. These times were determined through careful examination of the acceleration videos that we'll be posting tomorrow. All acceleration runs were done on the same stretch of road for consistency.
PTUNING Turbo FR-S vs. Stock FR-S
3rd gear, 2-4k rpms: 3 secs vs. 6 secs
3rd gear, 3-5k rpms: 3 secs vs. 5 secs
3rd gear, 4-6k rpms: 3 secs vs. 5 secs
4th gear, 3-5k rpms: 5 secs vs. 8 secs
4th gear, 4-6k rpms: 5 secs vs. 8 secs
5th gear, 60-80mph: 5 secs vs. 9 secs
10mph rolling start to 100mph
*Note that this will be slower than a proper launch from a stop*
13 secs vs. 21 secs
ptuning is offline   Reply With Quote
The Following 8 Users Say Thank You to ptuning For This Useful Post:
andrew20195 (10-24-2013), GT 86 Brah (10-23-2013), kayhettin (10-24-2013), Lawnik (10-23-2013), MadFRS (10-24-2013), MooKz (10-23-2013), SnapOv3st3r (10-24-2013), sw20kosh (10-23-2013)
Old 10-23-2013, 06:47 PM   #702
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
This is some interesting data.. Can't wait for the videos! From what I got with questions through PM's if I was to purchase the Tomei 80r exhaust the only downfall would be that the exhaust flow would dip to 2.5" exhaust to the 3" correct? Because of the use of the exhaust adapter right
MooKz is offline   Reply With Quote
Old 10-23-2013, 10:09 PM   #703
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
Love the turbo placement and general setup of this kit. My only concern is running it on the stock header, is this wise in the long term due to the cat?
I would think the cat is going to start to fail and material could end up in the downstream turbo, no?
A header is easily added, but why not include it in all kits?
Is there a full package? Kit, ecutek w/tune, 3" exhaust, header, cutch and fuel
Lawnik is offline   Reply With Quote
The Following User Says Thank You to Lawnik For This Useful Post:
MDSubarubrz (10-24-2013)
Old 10-23-2013, 10:41 PM   #704
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
13 secs vs. 21 secs
Y no 0-60
Old 10-24-2013, 09:43 AM   #705
andrew20195
Drives: 2013 Subaru BRZ
Originally Posted by SmsAlSuwaidi View Post
Y no 0-60
They were specifically trying to show the flexibility in more normal driving. Drag launches on the street (required for a good 0-60) aren't normal driving. Furthermore, 0-60 times are heavily influenced by gear ratios and number of shifts, not to mention the fact that their shop car has sticky aftermarket rubber compared to a stock FR-S.
Personally I feel 0-60 times are pretty much useless. For standing acceleration, 1/4 mile times are much more revealing, and the testing Ptuning has done here is quite useful and appreciated.
andrew20195 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew20195 For This Useful Post:
MooKz (10-24-2013), SnapOv3st3r (10-27-2013)
Old 10-24-2013, 12:27 PM   #706
SmsAlSuwaidi
Boosted
I just felt like asking, if they had the time to do such timing, one or 2 launches would've looked cool. Plus you don't have to drag launch a car for a 0-60, a normal start w/ flooring it would do alright, it's not a drag strip. Regarding gearing, most people have their rev limiter up'd to achieve 60 in 2nd
Old 10-24-2013, 03:02 PM   #707
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
We'll get those performance data in more detail once we setup the VBOX.
In the mean time...here's the custom PTUNING cone filter for the FRS Turbo System.
MrC
Mrc@ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Mrc@ptuning For This Useful Post:
kanundrum (10-24-2013), SnapOv3st3r (10-27-2013)
Old 10-25-2013, 12:46 PM   #708
andrew20195
Serious question for ptuning: Turbosystems controlled purely by wastegate spring pressure often have issues with boost spikes. What kind of spikes are you seeing, if any? If so, could this cause longevity issues for the engine. If not, what have you done to eliminate this undesirable trait?
Old 10-25-2013, 01:12 PM   #709
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Probably a manual boost controller with overboost protection programmed into the tune.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 10-25-2013, 01:23 PM   #710
sw20kosh
Drives: 2013 Black FR-S
He posted boost plots in an earlier post. No boost spikes.
The only wastegates that I have seen be troublesome are internal wastegates.
Old 10-25-2013, 01:29 PM   #711
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I think he's referring to longevity. Perhaps on a new kit there may not be any, because everything is new, but over time spikes may occur. Even external wastegates can have boost spikes. I think he wants to know how this potential problem can be solved before it happens.
Old 10-25-2013, 02:05 PM   #712
sw20kosh
A wastegate is a spring loaded valve. If there is no spike initially when you install it there will be no spike down the road untill/unless that wastegate is malfunctioning/worn out. At that point you would want to fix it or get a new one.
I believe he is talking about unsatisfactory boost control of certain setups. Design/dimensions of the wastegated bypass system play a role in this. The design of this system has been proven to control boost satisfactorily judging by the supplied dyno and boost graphs.
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
andrew20195 (10-25-2013), ptuning (10-25-2013), SnapOv3st3r (10-27-2013)
Old 10-25-2013, 03:08 PM   #713
andrew20195
Thanks for the answer, that makes sense. I didn't see the boost curve in the original post, but found it by looking through the thread again.
However, a dyno pull from low rpm doesn't show what the boost does on quick shifts at higher rpm, when the turbo is already well above the boost threshold, which is more where my concern lies. If ptuning or someone who has the kit can either post or PM me some datalogs of a full throttle run, I'd be really interested to see them.
Old 10-25-2013, 03:36 PM   #714
Dephective
Drives: '13 Whiteout FRS
If you are concerned with boost spikes running off wastegate spring, spend another ~$85 and get a boost controller for piece of mind. If they were worried about spikes, I'm sure that they would have addressed this in their car, as I doubt they want to grenade it. I will be purchasing one with my kit, its not that difficult.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
The Following User Says Thank You to Dephective For This Useful Post:
ecko04 (10-25-2013)
over 9000, ptuning, turbo kit
FA20CLUB.com Turbo Kit Sneak Peek.... FA20Club.com Forced Induction 98 12-14-2013 01:34 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 02:24 PM
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. P&L Motorsports Forced Induction 179 01-31-2013 07:32 PM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 01:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) — General Topics 19 06-23-2012 11:13 AM
