Old 10-17-2013, 12:35 PM   #253
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
Motor is fine!!! No sign of damage...new hks plugs and and an engine cleaning as we speak!
brz2013 is offline   Reply With Quote
The Following 3 Users Say Thank You to brz2013 For This Useful Post:
AVOturboworld (10-17-2013), DAMotorsports (10-17-2013), Sportsguy83 (10-17-2013)
Old 10-18-2013, 03:37 AM   #254
DAMotorsports
Drives: 2013 Scion FRS "Raven"
@brz2013 I glad to hear the motor is ok. I was looking at the pic with the broken fins, I can't tell from the pic but is the nut that hold the compressor wheel on still there?
DAMotorsports is offline   Reply With Quote
Old 10-19-2013, 06:19 AM   #255
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Adrian Smith (Owner of Fensport, the UK agents for AVO) finished mapping my car yesterday, after it was fitted with an Ultimate Racing 3" exhaust system.
Purely mapped for 99RON petrol (gas to you US guys ) - no corn juice in the UK. 10.5 psi on map 2, and wow, does it go!! just over 300 bhp (flywheel), which was my request, so I am one very happy customer. The logs are absolutely perfect - we are using Ecutec electronic boost control, which Adrian has totally got his head around. Looking at the log of how it is holding the target boost is really impressive. Also what is really good, once the final maps had been flashed, there was no trace of detonation, or det correction being required at all.
Dave
Pitman is offline   Reply With Quote
The Following 6 Users Say Thank You to Pitman For This Useful Post:
AVOturboworld (10-19-2013), DAMotorsports (10-19-2013), DesertFrs (10-20-2013), gdrider77 (10-19-2013), GT86-Ian (10-19-2013), Raven604 (10-19-2013)
Old 10-24-2013, 08:08 PM   #256
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Originally Posted by DAMotorsports View Post
You see the stock under tray. It you re having a hard time getting it lined you then loosen the impact beam and pull up on it as you tighten it up. Secondly make sure you have the IC up all the way. All the stock parts fit back in place. The side air panels (behind the grill) need a touch of a trim to fit. YOU NEED ALL OF THOSE PARTS TO KEEP YOUR CAR COOL, in both FI and NA.
Let me know if you need more help
Big thanks for this DAMotorsports! It solved the problem.
Decided to remove the headlight washers for now because they rub against the IC hoses. No real need for them where I live. Plan to use double adhesive to place back the washer cover.
Anyone else running stock catback with FI?
andrewFT86 is offline   Reply With Quote
The Following User Says Thank You to andrewFT86 For This Useful Post:
DAMotorsports (10-25-2013)
Old 10-24-2013, 08:10 PM   #257
andrewFT86
andrewFT86's Avatar
Dave
What's the rest of your set up, supporting mods, beyond the base AVO kit?
Old 10-25-2013, 11:07 AM   #258
Pitman
Living the dream
Pitman's Avatar
8psi actuator, Forge Dump valve, 3 Bar map sensor & overboost cut, AVO Breather System, 3" Ultimate racing exhaust and Helix uprated clutch pressure and drive plate.
The Following User Says Thank You to Pitman For This Useful Post:
andrewFT86 (10-25-2013)
Old 10-25-2013, 10:05 PM   #259
DAMotorsports
It was our pleasure to help you out. If you need anything else let us know.
We did some testing with the stock over pipe and exhaust very quiet with the base kit 6psi actuator we made 5 psi of boost and layed down 190wtq and 240 whp. We are testing some new stuff info to come.
The Following User Says Thank You to DAMotorsports For This Useful Post:
Old 10-26-2013, 03:18 PM   #260
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Updates (see the build thread for details):
- Exhaust leak fixed
- Car retuned with 770cc injectors, 4 bar MAF, and MBC
I am very pleased with these results. The minor fall off at the end is because it can't hold the boost (probably need stronger spring), but given I'm at the bleeding edge of 93 pump performance I'm satisfied.
The car is a maniac now. It spins my 235 Direzza ZIIs in 1st, rolling start or not. Can't wait to hop back on the 215 Blizzaks for the winter...
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
The Following 3 Users Say Thank You to nataku For This Useful Post:
andrewFT86 (10-26-2013), gdrider77 (10-26-2013), Sportsguy83 (10-26-2013)
Old 10-26-2013, 08:19 PM   #261
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Doesn't look too far off from my dyno today
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
nataku (10-26-2013), Sportsguy83 (10-26-2013)
Old 10-26-2013, 11:38 PM   #262
nataku
Negative Mass
nataku's Avatar
That's awesome. Did they just dial in your tune a bit more or did you change anything?
Old 10-27-2013, 01:07 AM   #263
spitfire481
Drives: 2JZ FRS
Messed with the open loop/closed loop transitions little since this turbo makes 5+ psi at 25-30% throttle haha. Did a little refinement at wot, the cooler temp probably made most of the gain from my last dyno there
Old 10-28-2013, 10:59 PM   #264
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Car is now with Bob @Drift-Office
soon my pretty... soon
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following 4 Users Say Thank You to Mr.Jay For This Useful Post:
DAMotorsports (10-29-2013), Drift-Office (10-29-2013), SkAsphalt (11-05-2013), Sportsguy83 (10-28-2013)
Old 10-28-2013, 11:01 PM   #265
nataku
Negative Mass
nataku's Avatar
Yeah I've been noticing the boost levels now that I have a gauge and we've upped it to 10 psi. I can hit 5 psi in less than a second at highway speeds at maybe 15% throttle lol. It's very quick spooling at the boost threshold.
Old 10-29-2013, 12:19 AM   #266
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Finally back in the game, running wastegate pressure (5psi currently) as I try to get all flexy with the e85 around here.
killerkid08 is offline   Reply With Quote
The Following User Says Thank You to killerkid08 For This Useful Post:
Sportsguy83 (10-29-2013)
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
