Old 02-07-2012, 10:09 AM   #631
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
Does anything like this exist?
Variable runner length, using solenoids with a 0-XX VDC output from an ECU source, to tune the runner length?
What about a similar concept for exhaust runners?
Just drew this up this morning and when it was fresh in my head.
The idea is to have infinitely variable runner length so that you can maintain the Helmholtz resonance.
bambbrose is offline   Reply With Quote
Old 02-07-2012, 11:06 AM   #632
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Yep, that's usually referred to as a telescoping intake runner. The Mazda 787B had them, but that's the only example that comes to mind. The main issue is getting them to move fast enough to keep up with the engine.
old greg is offline   Reply With Quote
Old 02-07-2012, 11:19 AM   #633
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
hahah wow that is eerily similar to what I had in my head and drew down
I think with modern linear actuators, the proper response time could be met, but cost is $$$$.
The 787B looks to be hydraulic?
Old 02-07-2012, 11:35 AM   #634
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
FYI the current Yamaha R1 motorcycle has variable tuning velocity stacks. It's a great idea!
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 02-07-2012, 11:57 AM   #635
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
yup nothing new. Already mentioned two examples I was going to site, as well as dozens of Formula SAE cars.
Homemade WRX is offline   Reply With Quote
Old 02-07-2012, 12:05 PM   #636
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
What about the exhaust side? Too much heat to deal with?
Old 02-07-2012, 01:32 PM   #637
Homemade WRX
sealing issues would seem more the thought.
Old 02-07-2012, 02:13 PM   #638
Dimman
Kuruma Otaku
Dimman's Avatar
What do the butterfly valves in bike exhaust/collectors do?
Because titanium.
Old 02-07-2012, 04:52 PM   #639
serialk11r
Drives: '06 AM V8V Coupe
Don't know if this was exactly correct but I think they increase pressure in the exhaust manifold (slightly) to change the speed of the exhaust waves.
Old 02-07-2012, 05:36 PM   #640
Homemade WRX
^^^my thoughts too. Only reason I could see it being useful. With such a broad powerband, opening and closing an extra tube would change effective diameter of the runner.
Old 02-07-2012, 06:24 PM   #641
madfast
Drives: 2010 Evo X MR-T
http://en.wikipedia.org/wiki/Four-st...r_valve_system
madfast is offline   Reply With Quote
Old 02-07-2012, 06:32 PM   #642
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by madfast View Post
Four stroke power valve? Interesting, thanks.
It sounds like it's in the middle of the collector on a 4-1 setup. If it can increase return wave strength for better scavenging at low rpm, it shouldn't matter if it chokes off some of the exhaust, as flow is minimal anyways, right?
Going to look for some with/without dyno charts now...
(EXUP, go Yamaha!)
Because titanium.
Old 02-07-2012, 07:56 PM   #643
serialk11r
Okay yea so I got it wrong, it's not to increase the overall pressure, but to change the way the exhaust wave reflects back.
So I have a question since I'm too lazy to crunch a few numbers, exhaust scavenging effect on a 4 cylinder comes from the cylinder firing 180 degrees after right? So with a twin scroll turbo you essentially eliminate exhaust pulse interference effects?
Old 02-07-2012, 08:28 PM   #644
Dimman
Kuruma Otaku
Dimman's Avatar
With wave scavenging the primary tube reflection can 'self scavenge', same with steps. Secondary tubes can too depending on their length, and looking at total exhaust length, the atmospheric return looks like it will be closer to the 180 cylinder. Inertial/gas flow scavenging would be for the 180 cylinder.
Edit:
Found Yamaha's explanation on their site:
http://www.yamaha-motor.ca/technolog...oup=M&tech=EUP
Because titanium.
Joke Thread VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 27 07-09-2011 01:44 AM
The Music Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 13 03-28-2011 12:35 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 06:10 PM
FT-86 to debut new GPS-track day technology for use on track and GT5! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 17 01-30-2010 12:30 PM
