Old 10-24-2013, 04:46 PM   #15
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by Shizuma View Post
Why? unless you're like 6"6" and hitting the roof having it super low is the worst possible position for driving.
Porsche seems to think it's the best position for driving, as long as you're able to see out (it looks like sprinter already linked to the video).
chrisl is offline   Reply With Quote
Old 10-24-2013, 04:51 PM   #16
zoomzoomers
zoomzoomers's Avatar
I've seen someone selling their seats on here in the sale area. How about buying a driver's side seat, with the height adjustment, and trying to install it in the passenger side?
Old 10-28-2013, 09:18 AM   #17
Shizuma
Shizuma's Avatar
Drives: 2015 Dodge Challenger SXT
Just because Porsche for some reason thinks so doesn't make it true, the lower you are sitting the worse you visibility of the road in front of you is, particularly closer to the car, sure it will make the center of gravity of the car a fraction of an inch lower, but that's a poor trade off for visibility.
Shizuma is offline   Reply With Quote
Old 10-28-2013, 09:27 AM   #18
nalc
Drives: 13 BRZ Limited 6MT GBS
Bolts are M10x1.25, if you go that route.
nalc is offline   Reply With Quote
Old 10-28-2013, 01:05 PM   #19
chrisl
With my seat in the lowest position, the car still only blocks visibility of the pavement a few feet in front of it. Visibility of that area is pretty much never critical, and even if you raise the seat all the way up, it only allows you to see a little bit of extra space anyways. As I recall from test drives, the BRZ is similar. There's really no problem with forward visibility in that car - the hood doesn't block your view much, no matter what seating position you are in.
As for why low is a benefit? It's not for CG purposes - as you said, that isn't going to be a significant difference across any reasonable range of seat adjustments. Instead, it puts the driver in a better position to feel what the chassis is doing, since it puts the driver closer to the chassis and closer to the axis around which the car rolls in corners. As a result, it helps the driver react faster and be more confident in the way the car performs.
Old 10-28-2013, 02:01 PM   #20
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
I feel like the brackets or right drivers side seat should work. All just to make the wife happy, oh man.
Marcoscrdo is offline   Reply With Quote
Old 10-29-2013, 12:28 AM   #21
cbf
Drives: 2013 BRZ Limited, GBS
Yeah, when I have time to crack open the service manual, I'm going to check what the mechanism looks like. But I'm guessing it won't be easy to mirror it for the passenger side -- and there's definitely no room to the left of the passenger seat for the mechanism. Obviously the longer bolts solution would be the simplest -- but not sure I want it that permanent (my wife's not the only possible passenger!).
Thus the solution to get the relevant bits from a UK driver's seat -- once I'm sure what the mechanism looks like so I can make a sensible query of a UK dealer. (UK obviously being an easier shipment the AU, NZ, JP.. etc.)
As for the driving position question -- yes, I sit higher for slightly better lines of sight (I'm about 5'7"+), but also because I find the seating position a little more comfortable. But the Porsche video was amusing.
cbf is offline   Reply With Quote
Old 10-29-2013, 09:41 AM   #22
Shizuma
Shizuma's Avatar
It kind of puts you in a worse position for feeling what the chassis is doing really, the further you are away from the axis the car rotates on the more you can notice subtle movements in the chassis, the closer to a rotation point the less resolution you have in changes. Yes you will feel things more exactly what the car is doing perhaps, but that doesn't necessarily equal better if you can't notice the smaller changes in the chassis, granted the difference between the two is minimal anyways since you're talking a couple inches at best.
Old 10-29-2013, 07:53 PM   #23
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
Just tell her you need the extra weight to be as low as possible
Kwisak is offline   Reply With Quote
Old 10-30-2013, 12:47 AM   #24
TurboBrett
Drives: 13 BRZ
Subscribed (for the useful comments, anyway).
My wife is 5', a higher seat would be great.
TurboBrett is offline   Reply With Quote
Old 11-07-2013, 12:19 AM   #25
cbf
I'll try to update this thread if/when I do something about this. Have other things to attend to for now.
Old 11-14-2013, 07:10 AM   #26
dontpanic
Drives: shiny side up.
make sue you match the grade of the bolt also. probably at least a grade 5 or metric 10.9 if not higher. you may find you need a star socket, the seat bolts are easy to round off with a regular socket.
dontpanic is offline   Reply With Quote
Old 11-14-2013, 09:22 AM   #27
nalc
To take them off, use a breaker bar, go to harbor freight and buy the external torx sockets for $7, E10 is what you need.
The bolt head is extremely small (it's narrower than the threaded section), and they're torqued to like a million foot-pounds. I tried to get them off with a regular ratcheting Crasftman socket, and had a very difficult time of it, and I'm not a weak guy. Ended up rounding off the head of one of them and had to use a bolt remover to get it out, then got a replacement for $2 from Amayama. Don't take these things lightly, the heads are very weak and they are torqued almost as tight as lug nuts, get the right socket and a nice long moment arm.
Old 11-14-2013, 09:31 AM   #28
Ben_G
Drives: Blue BRZ
Originally Posted by cbf View Post
That's a much more expensive solution!
No, she's not that short, but neither of us are particularly tall. It has more to do with the seating position. She's not fond of legs straight out.
A little late, but if she's not fond of the legs straight out position, i'm not sure the seat height adjuster would be right for her. It seems to lift the back of the seat more than the front, not the whole seat up at the same rate.
A pillow would definitely be your most economical choice for now.
You could do as someone else here has suggested and add washers, but that has already been pointed out to be not ideal from a disassembly and safety point of view, especially if your wife is looking for several inches of height.
Ben_G is offline   Reply With Quote
legs!, seat height interior
Passenger Seat Belt Warning Chime goes on even though there's no passenger. idreamofdrifting Issues | Warranty | Recalls / TSB 58 10-11-2017 11:31 AM
Passenger seat belt warning when I put phone on seat!??? Kayzer Soze BRZ First-Gen (2012+) — General Topics 20 09-13-2013 12:29 PM
Height adjuster on passenger seat DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 2 08-28-2013 10:06 AM
Passenger Seat adjust ? rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 6 06-09-2013 11:37 PM
passenger seat gusbarragan Scion FR-S / Toyota 86 GT86 General Forum 4 04-23-2013 06:57 PM
