#29 |
Cognite
Drives: 2013 Whiteout FRS
half of u trols making fun of this guy will end up spinning the car at one point or another. talk shit after winter when u wreck urs.
as for OP, its a rwd car, id recommend u take it out for a good spin on some back roads outside the city etc. just to get the feel for the back w.o much stuff to go into. good to hear all is well OP Last edited by nos145; 10-22-2013 at 05:31 PM. Reason: smrt |
#30 |
Drives: 2014 BRZ Limited DGM
#31 |
Drives: Subaru BRZ Sport Tech Satin White
Interestingly this car is easier to drive with the traction control switched off.
The car is a bit tail happy especially in the wet but oddly it is easier to provoke a sudden oversteer event with the traction control on. Any reasonably skilled driver will find the BRZ quite benign with the traction control off as long as you drive correctly. The stock tires are a problem because their breakaway is a bit abrupt. My snow tires are much easier to drive on. I concur this car is extremely twitchy in the wet. Again, the car slides progressively with traction control off if you use a bit of discretion. With proper tires this car should drive as on rails, wet or dry. |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 02:48 PM |
| Traction control issue? | mit_peid | Issues | Warranty | Recalls / TSB | 30 | 08-24-2013 05:17 AM |
| traction control question | Sileighty_guru | BRZ First-Gen (2012+) — General Topics | 9 | 09-26-2012 10:54 PM |
| CEL Traction Control ON then OFF | HATED1 | Issues | Warranty | Recalls / TSB | 5 | 09-24-2012 08:11 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
