Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 09-27-2013, 09:07 PM   #57
KAR
Drives: Whiteout 6spd
I'm SIKED TO GET MY RELAY FLASHER... Yes I was yelling.. Bump for good company.. Will post video as soon as I get it..
KAR is offline   Reply With Quote
Old 10-22-2013, 01:54 PM   #58
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
how much to ship to Singapore ?
Sookainian is offline   Reply With Quote
Old 10-22-2013, 02:34 PM   #59
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Any way to have hazards only be wig wag? As in push button, receive wig wag? No stalk mumbo jumbo?
post_break is offline   Reply With Quote
Old 10-23-2013, 12:38 AM   #60
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
$10
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
Old 10-23-2013, 12:43 AM   #61
scottmcphee
Are you asking for a custom mod? Then sure, I could make a perma wigwag as hazards for you, whenever you push the hazards regardless of stalk position. PM me if interested in going farther with that. Got to warn you though, your alarm lock confirmations will only show on right side of car with such a thing. Because these confirmations are just the car computer pressing the hazard button for a moment, that's how it does it.
Anyone with tapturn can check this theory out for themselves... Park the car, off. Put signal stalk up, it will flash once thinking you're trying to program the blink count... But ignore that and just leave the stalk clicked up in right position... And then lock your car from the remote. See what I mean! Only on the right side. Put your stalk back to center. Lock again... Normal confirmations.
Old 11-02-2013, 09:01 AM   #62
scottmcphee
Wigwag came in handy on Halloween, a conversation starter too!
Boo!!
Old 11-14-2013, 09:12 AM   #63
post_break
post_break's Avatar
Is there any way to quiet the clicks? I suppose wrapping the device in something is an option but I don't know if it's supposed to breath.
Old 11-14-2013, 10:31 AM   #64
scottmcphee
I could make a VERY QUIET one for you if that's a requirement.
I would cancel the noise from mods inside of the unit so it still has all the same physical appearance and installation convenience of snapping into place. Just use a note on the PayPal payment with your wishes and I'll make it come true.
There'd be little concern about restricting airflow around this flasher if you have one already and want to wrap it to make it quiet, using whatever I guess, maybe sound dampening material for stereo installations... Dunno. But not a problem.
(Thanks for asking tho! )
Old 11-14-2013, 10:47 AM   #65
post_break
post_break's Avatar
Well crap, I already have the unit installed. I'll see if I can hush it up by enclosing it in something.
Old 11-14-2013, 02:23 PM   #66
scottmcphee
You might be interested to know that I receive about as many inquiries about "making it louder" as I do "making it quieter". Poking holes through the case, sticking an empty Tic Tac box to the side, wrapping with foam, ... there's lots of "aftermarket fixes" you can apply to tune the sound to make it "juuuust right", like what Baby Bear would want.
..sorry I didn't get your request until after you ordered. I have no problem doing stuff like this for free at customer request.
Cheers
Scott
Old 11-20-2013, 08:59 AM   #67
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
I have replaced every stock bulb in my FRS to the correct LED. I first got switchback front LEDs and they came with a resistor that I had to plug into the car under the steering wheel. I have recently just upgraded the reverse lights to LED and the rear turn signals to LEDs as well.
My problem is I have now is that when I flick the switch to put the lights on, my left and right green arrows on the dash board are lit. If I turn the control to take a left turn, the left arrow gets slightly brighter and does flash at the correct speed.
What can I do to fix this problem?
Thank you for your help
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 11-20-2013, 09:27 PM   #68
scottmcphee
There's no Tapturn flasher in this equation, is there?
I'll try to help you diagnose your issue by PM. I see we've already started a conversation there.
The cure here might be yank those resistors out and just install a Tapturn, you don't need resistors for it to work!
Old 11-21-2013, 04:27 AM   #69
AG3NT_5CARFAC3
Drives: Toyota GT86
PM sent
Old 11-24-2013, 07:00 PM   #70
tranat
tranat's Avatar
Drives: Subaru BRZ SWP Limited
[ame="http://www.youtube.com/watch?v=ZwBIalGl_64"]SCION FRS SIDE MARKER BLINKER - YouTube[/ame]
I'm thinking of making my sidemarkers blink link the one in the video, will the Tapturn reslove the wigwag (back and forth) blinking like the one in the video?
Also will the Tapturn support LED sidemarker bulbs if I do decide to swap the stock ones out?
Thanks a million.
tranat is offline   Reply With Quote
TapTurn - best signal flasher upgrade for FR-S BRZ scottmcphee Audio/Visual, Electronics, Infotainment, NAV 160 03-30-2015 11:15 PM
LED lighting upgrade and Flasher Relay. jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 20 07-22-2013 08:44 PM
WTB: OEM Flasher Relay CanibeatNoel Audio/Visual, Electronics, Infotainment, NAV 2 05-01-2013 02:58 PM
FS: TapTurn module KRAZYK Interior Parts (Incl. Lighting) 6 04-25-2013 02:31 PM
WTB: OEM Flasher Relay CanibeatNoel Interior Parts (Incl. Lighting) 1 03-23-2013 01:19 AM
