Old 10-21-2013, 08:29 AM   #43
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Originally Posted by sw20kosh View Post
Delicious Tuning released preliminary dyno's that showed just the cooling effect of the intercooler kit. I believe it was +10 hp from just that.
Then he added timing on top of that and gained +13 hp.
Found it:
http://www.ft86club.com/forums/showp...postcount=1413
thanks for that. I missed that info somehow. Im guessing the numbers spread even further apart once back to back pulls are done or on the street where the heat exchanger gets more air.
cruizin01 is offline   Reply With Quote
Old 10-21-2013, 07:43 PM   #44
xjohnx
Grip>Slip
xjohnx's Avatar
which of you vendors can get me this the quickest? lol
Old 10-21-2013, 07:59 PM   #45
CSG David
CSG David's Avatar
Where are you located?
Old 10-21-2013, 08:00 PM   #46
xjohnx
Grip>Slip
xjohnx's Avatar
Richmond, VA 23229
Old 10-21-2013, 09:49 PM   #47
xjohnx
Grip>Slip
xjohnx's Avatar
@Innovate Motorsports @mines13 - do you have intercooler upgrade installation docs yet so i can see what all is involved with the upgrade install?
Old 10-21-2013, 10:25 PM   #48
utekineir
blowhard
Drives: frs, project forester
the upgrade kit manual has been on the sprintex site for a month or more,
http://www.sprintex.com.au/sprintex/...s-Rev-1-01.pdf
http://www.sprintex.com.au/sprintex/manuals/
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
xjohnx (10-21-2013)
Old 10-21-2013, 10:25 PM   #49
Ross
Drives: 85 corolla gts
The spintex / bullet instructions are available on line and many of the parts are very similar, some may be the exact same. The install is not very difficult at all.
Ross is offline   Reply With Quote
Old 10-21-2013, 10:47 PM   #50
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks, didn't think to check there. I figured that innovate would documentation since they're selling it now.
Old 10-21-2013, 11:44 PM   #51
sw20kosh
Drives: 2013 Black FR-S
Got a track day or something?
Old 10-22-2013, 12:33 AM   #52
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by Unicorn View Post
Dear Calum,
There's some 'strange shit' going on with all the intercooler jive. Sprintex released their charge cooler kit with a Bosch 2.5 bar MAP sensor. This MAP sensor also had an integrated air temperature sensor. This sensor has the same linearisation curve as the temp sensor in the OE MAF sensor (Unicorn Tested (tm)). For some reason Sprintex didn't want to, or be smart enough, to do a one-wire change to enable usage of this on-a-plate feature. Unicorn spec does.
Rumour on the rainbow has it that Sprintex have stopped supplying the 2.5 bar MAP sensor and are recommending use of the OE sensor. This may or may not be due to strategy issues in the ECU.
Who knows what Innovate are doing.
Yours knowingly,
Unicorn
Just found this out the hard way. 2.5 Bosch sensor supplied with the kit is a waste of money, caused endless problems while trying to tune. Fitted the OE sensor back on, tuning could be done and car running smooth.
Fitted the IAT sensor with OE map sensor, no problems identified, sent in logs to the tuner to check.
One thing that does concern me with the Intercooled version, Is the power only seems to start kicking in properly from around 4500rpm, where I notice from the non IC it starts from 2500rpm.
Is this something Only I'm expiriencing?
Ryan86 is offline   Reply With Quote
Old 10-22-2013, 12:48 AM   #53
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I have no issues forking over the cash for this upgrade. I am a bit skeptical until I see actual members running this IC. As much as I'd like to be one of the first to get this I will sit back for a few and see what happens.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 10-22-2013, 12:50 AM   #54
KSpider
KSpider's Avatar
Drives: '14 S4
Mine ships friday. I have to wait for it to go to iowa then back to me in ca, but once installed ill dyno and post numbers.
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
The Following User Says Thank You to KSpider For This Useful Post:
evo4g63 (10-22-2013)
Old 10-22-2013, 01:50 AM   #55
Unicorn
Drives: GT86
Dear Ryan86,
I think this will come down to your tune. Boost on the rainbow starts around 2000rpm.
Yours sincerely,
Unicorn
Unicorn is offline   Reply With Quote
Old 10-22-2013, 01:52 AM   #56
KSpider
KSpider's Avatar
Drives: '14 S4
Richmond, VA 23229
Go Spiders!
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 01:49 AM
Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! Xero-Limit Forced Induction 12 03-10-2014 09:56 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 02:06 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 10:14 PM
FS: Innovate Motorsports OT-2 pixel67 Engine, Exhaust, Bolt-Ons 0 01-05-2013 11:13 AM
