Old 10-20-2013, 02:04 PM   #29
stugray
Drives: 2013 GBS BRZ Limited
Nitrogen filed tires helps in only one way.
It purges the tire of any moisture.
If you have moisture in the tire, temperature changes result in less predictable pressure changes.
That is the ONLY benefit as "air" is about 70% nitrogen already....
Old 10-20-2013, 05:18 PM   #30
[quote=Clembo;1281302]
Ahhhhhh............yep, whatever happened to ...... oh, never mind .....
Being older too l know what you're thinking...
Hey @Clembo, I see you are from SE CT. I lived in Newtown and worked in Westport for several years. You live anywhere around there .... ??
sklimo (10-23-2013)
Old 10-20-2013, 10:14 PM   #31
DSlayerZX
Drives: 2010 Corolla, 2013 Fr-s
it's interesting, because my co-worker's 2012 Camry is able to display the pressure read out of each individual tire on his car... while the FR-S can't.
DSlayerZX is offline   Reply With Quote
Old 10-20-2013, 11:42 PM   #32
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
Originally Posted by Ozzman View Post
You don't lose air when the temp drops. The air in your tires loses energy. All the air molecules vibrating around inside a tire is essentially what creates the pressure. As the temperature drops, the molecules vibrate less thus exerting less pressure on the tire.
+++ The northeast has experienced a ridiculously mild fall. No TPMS warnings yet. This post just reminded me to check my pressures tomorrow morning.
Jertronic is offline   Reply With Quote
Old 10-21-2013, 09:21 AM   #33
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by Mikem53 View Post
It's not a useless system. I enjoyed having it in my corvette where you were able to display the psi reading for each tire. The scions half assed version is not near as useful since it's basically an idiot light warning, even though you can see each individual tire pressure via techstream. Toyota chose to cheap out on our system. It however helps the clueless ones who wouldn't notice low air or a flat tire because they are too busy talking on their phones..
If your TPMS displays real time pressure it isn't useless. It would be pretty nice if it would also display real time tire temperature as well, which it could do.
Only the idiot light TPMS are dangerously useless.
Suberman is offline   Reply With Quote
Old 10-21-2013, 09:22 AM   #34
Suberman
Originally Posted by Porsche View Post
Sure it does, although not much. The generally quoted figure is one psi per month pressure loss. Not much, to be sure, but it contributes to the overall reduction in tire pressure over time if one's tires are left unattended over long periods, as so many are.
I have had tires maintain pressure for several months or even longer.
Old 10-21-2013, 09:25 AM   #35
Suberman
Nearly 80% actually, and fortunately as 30% Oxygen would lead to interesting problems.
Otherwise you are correct that keeping water vapour out of your tires is a good idea.
Old 10-21-2013, 09:27 AM   #36
thill
It was in the low 30's this morning when I left the house. No TPMS issues for me....
Old 10-21-2013, 11:40 AM   #37
wparsons
wparsons's Avatar
It's been covered, but still...
These aren't TMPS issues, this is the system telling you that your tire pressures have dropped with the colder weather.
As for nitrogen, of course the dealership will tell you that. They want you coming to them for everything, MUCH easier to upsell you on things when you're there more often.
flickr
Old 10-22-2013, 10:46 PM   #38
Scionshaun
Aloha!
Drives: Whiteout
Originally Posted by Scionshaun View Post
anyone ever had their tpms light come on in cold weather?
I took my car back to the dealer and they said this is the cause of cold temperature drops. I had them take the air out of the tires and fill them up with nitrogen which doesn't expand during rapid temp dips for about $24 all around. You may want to invest in the nitrogen for all around.
Scionshaun is offline   Reply With Quote
Old 10-22-2013, 10:59 PM   #39
Jertronic
Jertronic's Avatar
Nitrogen is something that I have never once seen offered at any shop or dealership. Is this used more for racing or for climates with rapid temperature changes? I wouldn't mind trying some nitrogen once.
Old 10-23-2013, 08:48 AM   #40
Suberman
Nitrogen expands and contracts with temperature in exactly the same way as air or any gas. It's called Boyle's Law.
Ordinary air is 80% nitrogen.
Old 10-23-2013, 10:32 AM   #41
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I check my tire pressure all the time but saying the idiot light is useless isn't true, every bit of information is good to have. If you get a tire puncture on the highway you'll have enough time in some case to pull over before running out of air. But I also hate them because they are useless in the winter since the sensors stay in my summer wheels lol
Rayme is offline   Reply With Quote
Old 10-23-2013, 10:51 AM   #42
sklimo
[quote=humfrz;1281869]
He lives in New London I believe. Where did you work in Westport?? I'm in Norwalk
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
These cars love cold weather! CTB727 BRZ First-Gen (2012+) — General Topics 33 03-07-2013 08:20 PM
This car really hates the cold weather Craig Issues | Warranty | Recalls / TSB 55 01-28-2013 06:42 PM
rattling in cold weather mezdup Issues | Warranty | Recalls / TSB 2 01-22-2013 09:32 AM
Cold-weather morning shifts NetMagi Scion FR-S / Toyota 86 GT86 General Forum 11 11-08-2012 11:05 AM
