Old 10-20-2013, 12:47 AM   #43
koevasi
koevasi's Avatar
Drives: 1
did you manage to weigh these at all before the install? thanks.
koevasi is offline   Reply With Quote
Old 10-20-2013, 10:57 PM   #44
whataboutbob
AutoX-10/10ths every run
No, sorry. I am pretty sure they weigh a bit more than stock.
Build thread:Here
Old 10-20-2013, 11:05 PM   #45
koevasi
koevasi's Avatar
Drives: 1
Thanks. It would have been nice to shave some weight (even by a tiny amount) but I guess it's no biggie.
What I do find a little iffy is the bright gold color of the LCAs - just so ostentatious for what I think should be a low profile part!! No viable alternatives though with Whiteline probably being the only company who can offer replacement parts or accept warranty claims lol
Old 10-22-2013, 05:47 PM   #46
Turn in Concepts
Turn in Concepts's Avatar
then just have them anodized black.
Turn in Concepts is offline   Reply With Quote
Old 10-23-2013, 07:23 AM   #47
koevasi
koevasi's Avatar
Drives: 1
but then how would the world know i just spent 500 bucks? lol
btw i have your steering bushings. they are fantastic.
The Following 2 Users Say Thank You to koevasi For This Useful Post:
Turn in Concepts (10-25-2013), Zzzquil (04-04-2015)
Old 10-23-2013, 12:41 PM   #48
mike156
Drives: EVO
I was told that it would give the car a slightly lower ride height and better turning behavior. I'm still on the factory struts and RCE springs so this is really my only dynamic ride height adjustment on the car.
It will bring your motion ratio closer to unity using the outer bolt. This will increase the wheel rate of the spring/shock package. (aka it makes the rear suspension stiffer)
I would guess it makes maybe a 10% change just looking at the relative lengths. Thus you can likely adjust rear stiffness over a 20% range by moving the mounting location. Pretty awesome feature really as it lets you hone in on spring rate without having to buy new springs. Any chance we can get some measurements on them to nail down this adjustment range a little better?
Same goes for the sway bar mount.
Is whiteline releasing a bolt-on ride height sensor or something? Cool feature for the hardcore track guys.
mike156 is offline   Reply With Quote
The Following 2 Users Say Thank You to mike156 For This Useful Post:
unsurety (06-15-2014), whataboutbob (10-23-2013)
Old 10-23-2013, 03:47 PM   #49
whataboutbob
Mike,
I'm booked this weekend as I'm going to the SCCA match tour stop in St George UT, but I'll try to get some measurements next week and post them here.
Bob
Build thread:Here
Old 10-24-2013, 01:00 PM   #50
vanetix
vanetix's Avatar
Drives: Subaru BRZ - GBS
Do any of you guys running the Whiteline LCAs recommend them over the Cusco? Looking to probably pick these up with my suspension upgrades...
vanetix is offline   Reply With Quote
Old 11-17-2013, 12:07 AM   #51
whataboutbob
Still no measurements, I lag.
This setup is amazing on AutoX courses. Car feels really good. No issues with any of the camber/toe adjusters coming loose.
Build thread:Here
Old 03-06-2014, 12:11 PM   #52
NinjaRxMan
NinjaRxMan's Avatar
Great writeup! @whataboutbob , I'll be putting in the LCAs and rear adjustable toe arms this weekend! What were the torque tightening specs on the castle nut and inner arm nut of the rear adjustable toe arm. I've been looking through the forum and couldn't find any info.
Old 03-07-2014, 12:10 AM   #53
whataboutbob
Thank you. Here's the install doc: http://www.whiteline.com.au/docs/ins...ides/Z5263.pdf
Honestly, I just tightened them to feel. I haven't had any issues with them loosening up at all.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
NinjaRxMan (03-07-2014)
BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS OAKOS Automotive Brakes, Suspension, Chassis 226 01-19-2015 01:46 PM
Rear Whiteline UCA bushings, possible dealer F**Kup? OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-19-2013 01:22 PM
WORKS Rear Upper Control Arm Bushing - Inner Camber Correction 86_ZN6 Brakes, Suspension, Chassis 0 02-06-2013 12:20 AM
