Old 10-16-2013, 06:16 PM   #15
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
So I recently purchased Enkei RSF5's. I want to use my 20mm spacer on the rear wheels but I wanted to ask first what exactly did you mean by "after market wheels will need to have a hole in the back".
Originally Posted by b2autodesigns View Post
Just a little info on our spacers guys.
Specs:
Aluminum/Magnesium alloy mix.
1pc design.
Hub centric to FRS/BRZ.
High quality nuts and stud bolts.
Easy bolt on.
Sizes are 15, 20 and 25mm
We have been selling these spacers for over 2 years. There is some feed back on many different forums. Check my post for some feedback from customers. Also installation video.
http://www.ft86club.com/forums/showthread.php?t=37407
These fit perfect with factory wheels. Aftermarket wheels will need to have the whole in the back of the wheel to fit. Feel free to message me with any questions.
Thanks
Charles
ericmpena is offline   Reply With Quote
Old 10-16-2013, 06:23 PM   #16
b2autodesigns
b2autodesigns's Avatar
Drives: 1991 Galant VR4
When you install the spacers the stock wheel stud will stick out past the spacer. So the wheels will need to have an indention in the back of the wheel for the extra stud to fit in. Most wheels have these. Take a look at the back of the Enkei wheel. Next to the lug nut whole. Or post a picture of the back of the wheel.
Charles
b2autodesigns is offline   Reply With Quote
Old 10-17-2013, 11:21 AM   #17
Excelerate
Excelerate's Avatar
Drives: Crystal Black BR-Z Limited
30mm spacers definitely make the rear sit flush. I'm running H&R DRM Spacers in the rear and just ordered Ichiba V2 15mm spacers for the front. I have the car lowered on H&R Super Sport springs. When I measured, 20mm was going to be a little outside of the fender so I decided to go with the 15's. Went with Ichiba V2's in the front because you don't have to replace the stud with the V2's. The H&R 15's required longer studs.
Excelerate is offline   Reply With Quote
Old 10-20-2013, 01:03 PM   #18
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
I just did 20mm front and 25mm rear on Eibach Sportlines. Car looks so much better. 30mm in the rear will match the front perfectly. But you really have to look for that. I see the car perfect finally.
MPI_Jack is offline   Reply With Quote
Old 10-20-2013, 03:00 PM   #19
KayC
Drives: 2013 whiteout FRS 6mt
Post some pics please!
KayC is offline   Reply With Quote
Old 10-20-2013, 09:45 PM   #20
MPI_Jack
Here ya go.
The Following User Says Thank You to MPI_Jack For This Useful Post:
DAEMANO (10-20-2013)
Old 10-20-2013, 09:52 PM   #21
suaveflooder
I'm running 20mm in the back only. Left the front stock. I had the 20mm front and 25mm back on for about 30 seconds. Poked out just a little too much for me. The 20mm only in the rear is MONEY.
(lowered on Eibach Pros)
suaveflooder is offline   Reply With Quote
Old 10-20-2013, 10:15 PM   #22
MPI_Jack
I think a 15mm front 25mm rear is money. And if you want like right at the fender 20mm and 30mm. On my Sportlines the 20mm up front barely poke, the edge of the rim protector on the tire is right at the fender line.
Old 10-20-2013, 10:16 PM   #23
suaveflooder
To each their own
Old 10-20-2013, 10:19 PM   #24
MR2TOY
Drives: 2013 Raven FR-S, 1991 MR2 Turbo
What would be the ideal setup (no poke) for stock ride height ?
15mm front, 20mm rear ?
MR2TOY is offline   Reply With Quote
Old 10-20-2013, 10:32 PM   #25
suaveflooder
20mm rear. 15 on front would look good too. I just decided to keep it stock.
25 on rear doesn't give you much poke, but to me, it looked like I had spacers. I'll post another pic in a bit of just the wheel well. You'll see what I'm talking about
Old 10-20-2013, 10:34 PM   #26
MPI_Jack
Also remember your camber will affect the look of the spacer as well!
Old 10-20-2013, 11:10 PM   #27
suaveflooder
alright, here's what I have.
This is the 25mm spacer.
And the 20mm. Slight difference (look at the tread of the tire if you can't tell, the bulge of the tire was just outside the fender). The 20 mm spacers put the tire JUST inside the lip of the fender. It fills out the rear without looking like you're trying to fill it out with a spacer
The Following User Says Thank You to suaveflooder For This Useful Post:
Astroboy (09-13-2015)
Old 10-20-2013, 11:24 PM   #28
DAEMANO
Time Traveller
**Point of clarity - When discussing "flushness" generally (on this board) it refers to being on the same plane with the top of the fender. I think @suaveflooder is talking about being flush with another part of the fender (the side or bottom perhaps), which is totally ok too. Just don't be confused at the varying recommendations due to this variable.
With that being said 20mm front and 25mm rear fits very well. There are probably a dozen examples on the board now with that combination (including my own car (posted earlier)). For perfect flush (with the top of the fender) 20mm front and 30mm rear is flush as an ironing board.
Keep in mind thick spacers like these weigh over 1lb each so you will be adding unsprung weight to each corner.
Wheel Size vs. Balance jellygorilla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-11-2012 01:23 PM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
