Old 10-20-2013, 12:05 PM   #1
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
What Class do you think the Twins would go to for SP???
The Twins is not officially Classed in SP. What Class do you think it would go to?? I think it would go to DSP??? or CSP??? not sure as no one has built a NA motor on this thing yet. Thoughts??
Scooby South is offline   Reply With Quote
Old 10-20-2013, 12:18 PM   #2
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Seems like a better match for DSP than CSP, but lack of update/backdate to take advantage of weight savings really hurt this car right now vs. the other cars in SP.
neurokinetik is offline   Reply With Quote
Old 10-20-2013, 12:52 PM   #3
Eric1855
Drives: LP DSP / CSP '13 BRZ
I wrote my letter asking for them to be classed in DSP and for the BRZ and FRS to be on the same line.
I think I am going to do SP next year depending on where it gets classed, or SM if I can't fight the desire for more power. Just getting tired of street tires.
Eric1855 is offline   Reply With Quote
Old 10-20-2013, 01:56 PM   #4
Scooby South
Conedancer
understand.. Street tires are 'almost' as sticky as R'comps.. but I am thinking the boosted route down the road.. SM is a nasty place for the twins to end up against some pretty formidable competition at a National Level for sure. However, R-comps are an interesting addition to a already awesome handling car.. it would need about 300whp to be competitive tho.. I think.. then theres the AERO aspect to think about also..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
whataboutbob (12-05-2013)
Old 10-20-2013, 06:54 PM   #5
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I'd assume DSP would be a better fit as well, but I'm unsure of how competitive the twins would be in SP trim.
G_Ride is offline   Reply With Quote
Old 12-05-2013, 10:48 AM   #6
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I submitted a letter for DSP since my mods will force me out of STX. It was reviewed yesterday and will be sent to the Solo Events Board. I think CSP is a little ambitious.
PoorMansRacing is offline   Reply With Quote
Old 12-05-2013, 07:54 PM   #7
Eric1855
So what are people thinking for wheel size and tires in SP?
I have seen pictures 285 Hoosiers on 18"x10s on this car, is that really doable?
A 275/35/17 Hoosier would work too I think
Old 12-05-2013, 08:06 PM   #8
Scooby South
Conedancer
275's Definitely fit.. and 285/18's would be optimum.. with a MLA or Rocket Bunny2 Kit. Not sure how much more NA power can be extracted from the SP ruleset over the ST ruleset.. not alot more options there.. except the TB, inj. and Fuel System upgrade. I see 'Maybe' 205 NA Wheel Hp at best maybe .... Weight wise.. in SP trim it might loose another 50lbs??? over ST... but its offset with all the other allowable stuff in SP..
just thinking.....
Bill
Old 12-05-2013, 08:07 PM   #9
Eric1855
just thinking.....
Bill
I think with the rule change the biggest power gain will be from running e85 in SP which you wont be able to do in ST next year.
Old 12-05-2013, 08:28 PM   #10
Scooby South
Conedancer
agreed....however I didn't run E85 all year.. 93 only, anticipating the no E85... My dyno numbers are 192/154...on 93.. however you can run C16 in SP..which may be worth a few ponies..
Bill
Old 12-17-2013, 11:00 AM   #11
Scooby South
Conedancer
Preliminary : For Jan Fastrack.
Street Prepared
#10365 FRS/BRZ Classing Proposal
Per the SPAC, add the following listings in class C Street Prepared:
Scion
FR-S (2013-2014)
Subaru
BRZ (2013-2014
Street Prepared
#11722, 11866, 12411, 12427 FRS/BRZ Classing Proposal
Please see item #10365 elsewhere in these minutes
So.. whos up for a CSP build.. wow.. I really thought it would be a DSP Car.. but I guess others found that it could compete in CSP. We'll see
Bill
Old 12-17-2013, 05:14 PM   #12
G_Ride
G_Ride's Avatar
CSP should be interesting.
Old 12-17-2013, 05:51 PM   #13
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Difference in the fastest STX overall time and CSP overall time at nationals was 9.9 so roughly 5 seconds a day. I realize that even Andrew's car, who placed second and was the first 86 was far from maxed out. Seeing pictures of the car he had the stock battery, seats, and many other things not modified. I stopped putting money into the CSP car in 09 when everyone went to 275/15's, building VVT engines, etc. cause I couldn't justify the cost.
Assuming you take an STX car that has been maxed out to the rules how much time are you looking at with:
275/285 slicks with flairs
Removal of all the emissions equipment
Aftermarket flywheel
Front wing and rear lip spoiler
Radio and all the speakers
AC system
Non-airbag steering wheel
(for the really serious)
Intake manifold
Overbore
Mill heads
These all being the changes that would be able to be done beyond STX trim within SP guidelines that I can think. Besides the last but not least OIL COOLER that I wish they would just amend already so I don't have to make a sandwich plate with dry quick connect fittings that are $200 so I can install for NASA Time Trials and remove for Pro and Tour events
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 12-17-2013, 06:24 PM   #14
neurokinetik
No way in hell this car will compete with the Miatas in CSP. It weighs alot more (and has no provision for update/backdate to get the big weight reductions the Miatas get), is much wider, and we can't get much, if any more tire on the car than the Miatas do.
Sure, we can make more power, but in every other aspect, this is the inferior car.
Mercedes A class AMG v BRZ? Suberman FR-S / BRZ vs.... 20 09-24-2013 02:37 PM
Proposal for CDC FT-86 Class Areddi Mid-Atlantic 37 05-11-2013 06:59 AM
FRS No class? WTF ggpaul Scion FR-S / Toyota 86 GT86 General Forum 135 01-15-2013 12:07 PM
Anyone for a class? Fuzzysmith Northwest 21 08-13-2012 12:02 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
