Old 10-19-2013, 09:12 PM   #29
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
How does the dampening quality compare to say the ST coilovers or KW var 1? If I wanted to upgrade to Swift springs with higher rates later on is that a possibility?
mokinbird87 is offline
Old 10-19-2013, 09:21 PM   #30
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Can I use my swift springs which I've been using with my stock struts??? o_O
hanabie is offline
Old 10-20-2013, 01:02 PM   #31
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
Originally Posted by hanabie View Post
It is not about the spring compressor. The allen hex and a hollow ratchet. So the struts are not spinning.
Socket + locking pliers(vise grips) + allen key of allen key socket do the the trick as well. If you're budget concision you can get all those tools cheap at Harbor Freight or Northern Tool.
MPI_Jack is offline
The Following User Says Thank You to MPI_Jack For This Useful Post:
hanabie (10-20-2013)
Old 10-20-2013, 07:28 PM   #32
Racecomp Engineering
Nope.
- Andy
Racecomp Engineering is offline
Old 10-20-2013, 07:31 PM   #33
The Bilstein is a monotube with decent gas pressure so you get a little more response and more precise reaction from the dampers.
IMO the Bilstein will lend itself better to bigger bumps while the KW, ST, or our RCE T0 will be smoother on smaller bumps. That's generally the case with a good monotube vs. a good twintube. It's going to be good ride quality either way.
- Andy
chanomatik (02-28-2014), mokinbird87 (10-21-2013)
Old 10-22-2013, 11:24 AM   #34
ayau
Drives: Some rust bucket
Just contacted Bilstein directly and got some spring rate info. Springs are sourced from Eibach and have a 2.5" diameter. Length is unknown. Same spring rates for both the B14 and B16 kits.
Front: 257 lbs/inches = 4.59 kg/mm
Rear: 378 lbs/inches = 6.75 kg/mm
ayau is offline
Old 10-22-2013, 05:42 PM   #35
Ro_Ja
Drives: TOYOTA
Springs are also progressive, not linear.
After a few days of driving, I'm very pleased with the kit. Ride quality is better than I expected. Early reports stated that you will feel more imperfections of the road, which I found to be true. However, the bumps are definitely less jarring than they were on the stock suspension. Car stability is also improved. Great value for the money, IMO. Bilstein is also a great brand to invest in for ease and availablity of service and rebuilding once you grow out of the stock settings.
Ro_Ja is offline
The Following User Says Thank You to Ro_Ja For This Useful Post:
RYU (11-14-2013)
Old 10-22-2013, 06:12 PM   #36
ayau
Do you know the progressive rates? Does the B16 kit include camber plates?
ayau is offline
Old 10-22-2013, 06:53 PM   #37
mike156
Drives: EVO
They LOOK like a linear spring with a bit of a "helper" section that likely compresses out with the weight of the car. This is done to get more droop travel. This seems to be the case when there are the plastic overwraps on a couple coils anyway.
I wish you could get 2.25"/60mm springs like this for coilovers so you don't have to deal with the spring adapters and buying 2 springs per corner. Being able to buy an 8" "helper/linear" spring that acted just like a 6" linear + helper would be perfect for so many applications.
Dont have the right tool to install the top hats. Do I have to buy the tools? That would be another cost.
Sent from my SGH-T999 using Tapatalk
If you don't have to assemble the strut again with preload, an easy way to do this is simply remove the top nut while the car is still on the ground then just jack the car up to remove the load from the springs. If the springs going back on require preload that can't be done with just your body weight, good luck getting it back together without the right tools though.
mike156 is offline
Old 10-22-2013, 09:03 PM   #38
Ro_Ja
Drives: TOYOTA
From Bilstein Japan's site (all B14 and B16 kits share the same valving across world markets):
Front spring rate 2.5 ~ 4.5kgf/mm
Rear 3.0 ~ 7.0kgf/mm
No camber plates.
Ro_Ja is offline
Old 10-26-2013, 02:14 PM   #39
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
These PSS coilovers are an excellent investment into your car. I bought a set of these for my S2000 early in my ownership. As I got more into tracking and time attack, I decided I wanted something more aggressive. I was able to pull the shocks off and send them down to Ramon @ theBilstein service center in SoCal for a revalve to a much more aggressive set of Swift springs. Great thing is, I ended up paying less for the revalve than I would to revalve a set of Koni's or most other shocks.
My suspension feels top notch and makes me highly competitive against local track competition.
Highly recommend!
AyJay is offline
Old 10-28-2013, 11:33 AM   #40
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
The specs says it lowers 30-50mm, does that mean even at it's highest possible setting it's still 30mm lower than stock??
Fizz is offline
Old 10-28-2013, 05:13 PM   #41
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
That is correct.
ETA on the Bilstein B16?
Showed up today.
FT-86 SpeedFactory is offline
Old 10-28-2013, 06:52 PM   #42
PRORICAN
PRORICAN's Avatar
Will these work with other springs? I'm running wide wheels and narrow springs that coilovers usually come with are needed to clear without rubbing.
PRORICAN is offline
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
